Question about Craftsman Garden
I have a craftsman 917.296040 I lost drive capability still have tine rotation capability. Shift indicator moves freely no visible leakage from trans. What can I look for? thanx. clabrosse50@yahoo.com Was working properly and all of a sudden lost the drive mode
steve_lima
  • 181 Answers
SOURCE: what type of lube is used in 917-294261 tiller gearbox?
80-90 gear lube
Posted on Jan 09, 2009
  • 376 Answers
SOURCE: what is counter rotating tines on 62966 rear tine tiller
Not really sure what you're asking, but counter rotating tines turn the opposite direction you're traveling.
Posted on Jun 09, 2009
harlan301
  • 205 Answers
SOURCE: Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Posted on Oct 13, 2009
heatman101
  • 43501 Answers
SOURCE: Own a "Craftsman Rear Tine
Can you move the tines by hand???
They should turn by hand if you try to move them...if not then they are bound up by something...
either a bearing has gone bad, something has wrapped around them, or there is something stuck in there that will not let them turn...check for a rock stuck between one of the tines and the housing around them...
Get the tines moving freely and you will be okay again...
heatman101
Posted on Mar 31, 2011
  • 316 Answers
SOURCE: my craftsman rear tine tiller m# 917293202 will not move tines will move but wheels will not
hello, upon inspection of the parts brake down looks like you have broken the drive chain inside of the trans to drive the wheels,there is no mencion if the belt and pulley turns and the wheels don't,did you check the belt and pulley?hope this helps,oh bring it over abd i will repair it,
Posted on Feb 21, 2012
Craftsman rear tine tiller
If you cant move the tines by hand then I wouldn't think you sheared the pins, more like a gear box problem.
Mar 21, 2014 | Craftsman Garden
I have a 1988 troy bilt horse 8hp the tines rotate when its engaged or in disengaged
check the shift linkage sometimes the pins fall out when you shift it does it move to freely
Apr 19, 2012 | Garden
My craftsman rear tine tiller m# 917293202 will not move tines will move but wheels will not
Feb 12, 2012 | Craftsman Garden
I purchased a Craftsman 205cc dual rear tine tiller (17" width) in 2009. I used it very little to break ground for a small garden (32'x12') after purchase then to till it a couple of times a...
It appears that the gear case on your model is not capable of being serviced. The cost is over 300 dollars. There is a shear pin or similar connection in the case where the shaft connects to the pulleys. It has broken off and the shaft has no torque now.
Mar 05, 2017 | Craftsman 205 cc 13" Dual Rotating Rear...
I have a 19" 7 horsepower dual rear tine tiller and can not find out what size belt it takes. It is a craftsman bought at Sears. I lost my manual for it.
If you're talking about the dual-rotation rear tine 900 series, produced by AYP, sold by Sears as Craftsman, also sold by Husqvarna, the actual belt size is 51-3/8". A 51 should work.
Apr 19, 2010 | Craftsman Rear Mount Tiller
I have a craftsman 19 in dual rotating tines, rear tine tiller. # 917-293493. In mid till, the tines quit turning. Won't shift into any gear. Wheels are locked. Any ideas?????
It is going to be a transmission issue. You can try with the engine off, turning the trans pully by hand in the opposite direction that the motor was turning it.
Some gears in the trans got crossed up and locked.
Aug 12, 2009 | Craftsman Rear Mount Tiller
Tiller will go into every gear except forward/till..whats going on?
check the shift lever where it goes into the transmission. a lot of times, the lever will get sloppy where the roll pin goes through and it won't shift into till. sometimes you can drive the roll pin out, pull off the lever and peen the holes over. sometimes you have to drill the lever and shaft and put in a snug fitting bolt and nut. OR, the chain driving the tines is broken, and that means a new transmission. hope it's simple
Jul 19, 2009 | Craftsman 8.50 Torque Rating Dual...
I have power to the tines but the wheels are locked
Tines only spin in the T position.with cutch engaged.If thats not it split the case and check to see the shift fork operating properly. Or that chains are not broke. NOTE This is a serious job!!!
May 11, 2009 | Craftsman 8.50 Torque Rating Dual...
Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Mar 22, 2009 | Craftsman 8.50 Torque Rating Dual...
Garden Logo
112 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
