Question about Canon ZR85 Mini DV Digital Camcorder
Zr85 camcorder will not turn no lights no power
Zr85 Canon camcorder will not turn no lights no power, battery ok charger ok
  • Canon Master
  • 3,083 Answers
Ok, let's try the "easy fixes" first. When this problem happens, it can be a oxidized power switch contact, or oxidized battery contacts on the camera. Clean the battery contacts and the contacts on the camcorder with an eraser gently (they are gold plated). See if the camcorder works now. The next step is only if you're not planning on taking the camcorder apart. There are times when you can give the camcorder a slightly hard "whack" with the palm of your hand, somewhere near the power switch, while the power switch is on, and if the camera works, then you know it's most likely a dirty or oxidized contact inside. See if you can get it working with these methods. If you can't, you will have to disassemble the camcorder or have it serviced. Get an estimate if you get it serviced, since it can be expensive, and you might just opt for a replacement.
Posted on Apr 24, 2010
Canon zr85, battery won't charge
It sounds as if your battery is shot. If it does it with any battery then that's not the case, of course, but a Batteries Plus store can test it for you or you can just order a replacement from Amazon. I've had good luck with Wasabi Power replacement batteries from Amazon.com.
Apr 21, 2014 | Canon ZR85 Mini DV Digital Camcorder
Power battery
is the unit charging but you cant see the light for charging or it's not charging at all?
Sep 24, 2013 | Canon ZR85 Mini DV Digital Camcorder
I have a canon digital video camcorder NTSC ZR85. I am unable to charge the battery. I have changed the battery but still there is no charge for the battery. I am unable to see the charging light. What are...
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
May 23, 2011 | Canon ZR85 Mini DV Digital Camcorder
Computer reconized canon zr85, but not the zr800
load or reload the drivers for the zr 800,you should be able to get the drivers off of canons website
Dec 03, 2009 | Canon ZR800 Mini DV Digital Camcorder
My Canon ZR85 has no light in the view finder for recording images. It will play back tapes, but no images when you want to record. Battery is fully charged.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Jan 12, 2009 | Canon ZR85 Mini DV Digital Camcorder
Image distorted in both modes canon zr85 camcorder
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced to back in business.
Canon will repair your camcorder free of cost as per announced scheme for ccd imager issue.
Click Canon CCD Advisory for details, how to get free repair.
Good luck.
Dec 25, 2008 | Canon ZR85 Mini DV Digital Camcorder
Canon zr85
You should probably take it to the camera shop and see whats going on with the power supply.
Jun 14, 2008 | Canon ZR85 Mini DV Digital Camcorder
Canon ZR85
THE COMPARTMENT IS OF TRACK THIS WILL NEED REPAIR SORRY THIS IS ALOT OF MONEY
Feb 02, 2008 | Canon ZR85 Mini DV Digital Camcorder
Not able to record the image
I had a similar thing happen to me...the video would not come one when I turned it on, but the audio would work, and it would play back tape fine. I happened upon the following solution (though I don't know how long it will last). I charged the camera, and then noticed it worked fine when the charger was plugged in. As soon as I unplugged it, the video would go black. So...I plugged it in, turned it to record, and unplugged it, and it worked! Almost like something got reset. I have no idea how long this will last, or if it means the battery is going...but, give it a try!
May 06, 2007 | Canon ZR85 Mini DV Digital Camcorder
Canon ZR85 Mini DV Digital Camcorder Logo
192 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
