Question about Panasonic PT-51HX41 51" Rear Projection Television
Can the front cover be removed for cleaning?
Can the front cover of the Panasonic DLP TV be removed for cleaning? There are cobwebs behind the cover. Thanks.
  • 666 Answers
Yes normally its just small clips that are resealable used to hold it on as for maintenance it requires exposing the light bulbs
hope this helps
Robb
Posted on Apr 23, 2010
I have a Panasonic hdtv. How do I clean cobwebs from inside?
Remove the back lower cover first.........you should see a slide out board covering the light box.........slide that out and care fully reach up and around with your plastic long vacuum extention.......you can remove the top back cover,but be careful,because there is usually a mirror attatched to it,this will allow you to clean more thoroughly........be careful!
Jun 15, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Removal of the lamp unit from the tv
sometimes lamp is replaced in the front of tv.If so the panel under picture pulls out revealing lamp housing which is held in with a couple screws.replace lamp housing assembly
Feb 22, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Mitsubishi VS50609 has cobwebs behind the ribbed screen and I need to know how to remove the ribbed screen, I already removed the clear cover smooth cover. Sandy
set should have the clear screen cover (protective) and two more screens behind that. Easy way is to unplug set and remove back cover--cobwebs are usually behind on inner screen.
With the back off I use a swiffer like duster and reach up and get them all out--gently on the inside of the inner screen so you do not scratch or mar it.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 09, 2009 | Mitsubishi VS-50609 50" Rear Projection...
My RCA DLP HDTV shows ''Cobwebs''
It is in the top half of the set. You will have to remove the top back cover to clean it.
Jul 09, 2009 | Televison & Video
Cobweb in projection tv
take the back cover off as the mirror is attached to it then you can clean the mirror and the inside screen and colour gun lens's (3off) there should be 8 to 10 screws around the outer edge of frame and about 6 to 8 holding the screen portion to the chassis
Jul 23, 2008 | Televison & Video
Cleaning JVC rear projection screen (behind cover)
You will have to do some dissassembling of the cabinet to remove the screen and bezel assembly. If you are will to do this I can give you the directions.
Mar 22, 2008 | JVC AV-48WP30 48" Rear Projection...
Clean behind the screen.
hey,
to packerfan. yesterday i did some thinking. i had the same problem w/ my toshiba 57". cobwebs in the viewing screen. i found the solution to be simple. take the front panel off. it's just held on by some clips. remove the black cardboard cover that protects the wiring. it's simple just w/ a screwdriver. attach a feather duster w/ duct tape to a 2 ft. dowel or longer if your arms are short.there are several places you can go up to dust. i found that if you clean 1/2 of the screen then the other 1/2 you should be done all tolled in about 10 mins. presto! my screen has never looked so good.too bad it's taken me 3 yrs. to figure it out. hope this solution works for you as great as it worked for me!!!
Nov 24, 2007 | Toshiba 57HDX82 57" Rear Projection HDTV
Exploded view diagram
1) Remove rear cover. Slide out pressed-board light shield.
2) Remove any cobwebs behind screens-(soft cloth on pole)
3) wipe lens caps with soft cloth
4) re-assemble
Oct 24, 2007 | Sony KP-57WS500 57" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
133 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
