Question about Sony SLV-R1000 S-VHS VCR
POWERS OFF BY IT'S SELF
IF I UNPLUG IT THEN PLUG BACK IN, THE UNIT WILL COME ON FOR A VERY SHORT PERIOD. THEN JUST TURN OFF. THEN BY PRESSING THE POWER BUTTON I CAN HEAR A SLIGHT CLICK INTERNALLY BUT NO POWER OR LIGHTS. ANY CLUES?
  • 25 Answers
Hello FixYa customer,
There can be different issues in the mechanism or electrical that will cause the unit to shut down. However, since the power is going off completely after the initial plug in I suspect the power supply.
The SMPS, Switch Mode Power Supply has filter components that age due to heat, the voltage output on the filters reduces until the Micro Processor malfunctions and the unit won't stay on. The power supply filters can be changed by an experienced technician for $10-$15.00 in parts plus labor.
Thank you
Posted on May 11, 2010
Getting an E1 error message..wont start
1. Unplug unit. 2. Hold down power button while plugging in unit. It will do a short self-test and then beep. leaving unit off. 3. Release power button and unplug. 4. Plug in again and turn on normally. This should last for about 720 hours, at which point the E1 error will come back and you need to follow the procedure again. (You might as well clean the air filter at this point just in case it really needed it...)
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 03, 2011 | Amana ACD106R Wall/Window Air Conditioner
Unit will not power up. everything is plugged in.
Is this a new unit that has never worked or a new problem on a previously working unit? It's important to know.
Try unplugging all the speakers and see if it turns on.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Mar 18, 2011 | Samsung HT-TZ512T Theater System with...
Forgot my password I cant watch any channels
The easiest way is to reset the TV. There are 3 possible resets for this TV. press and hold Action and Power on the TV until self check appears-- then unplug the TV wait for 30 sec. then plug back in. The reset should take care of any channel lock/ game guard settings
Also Volume down on unit and sleep on remote. Same process wait for self check then unplug for 30 sec. plug back in and turn on.
Last Volume down on the unit and RH-Split on the remote-- same process
hope this will be helpfull. Please rates me . Goodluck...................
Feb 03, 2011 | Panasonic TCL42U25 42 in HD-Ready LCD TV
I have been using my Kenwood KRF-V7030D amplifier up until now without any problems... But now It simply wont turn on... There is power going to the unit as the red led lights up when the power cord is...
http://www.retrevo.com/support/Kenwood-KRF-V7030D-Receivers-manual/id/480ag204/t/2/
If it's microprocessor-related try the procedure at the top of page 26. Of course, this will clear all your custom settings...
"Unplug the power cord from the wall outlet, then plug it back in while holding down the POWER key."
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 21, 2011 | Audio Players & Recorders
Why does your PANASONIC tv ask for a password?
or
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip
Dec 30, 2010 | Panasonic (TH-50PZ700U) Television
6210 Stuck in self test mode
Perform the steps provided below.
  1. Unplug the power cord from the HP All-in-One.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while plugging in the power cord to the HP All-in-One.
  4. Release the buttons after the HP All-in-One starts up.
  5. The HP All-in-One will now be reset to factory defaults.
AFTER PERFORMING THE STEPS IF THE ISSUE PERSIST FOLLOW THE STEPS PROVIDED BELOW.
  1. Press the Power button, and turn off the HP All-in-One.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the HP All-in-One.
  4. Wait for 20 seconds.
  5. Plug the power cord into the wall outlet.
  6. Press and hold # and 6 while plugging the power cord back into the HP All-in-One.
  7. Turn on the All-in-One by pressing the Power button (c01150476.jpg ).
Aug 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Dont have securtiy code to unlock tv
  1. Press and hold Action and Power on the TV until self check appears-- then unplug the TV wait for 30 sec. then plug back in.
  2.  Volume down on unit and sleep on remote. Same process wait for self check then unplug for 30 sec. plug back in and turn on.
  3. Volume down on the unit and RH-Split on the remote-- same process
Try these one at a time until you find the right one.
Let me know if this helps and please rate this solution. Lone99star
Jan 18, 2009 | Panasonic TC-32LE60 32 in. LCD Television
Won't stay on
Good Day;
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. OR your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV. Good Luck, big IRISH.
Sep 02, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Not turn on i do not have 24v. Was watching TV for three hours when I was finished the set would not turn off from either remote or front panel. Unplugged unit and left overnight. When I plugged the unit...
Good Day,
The most common problem with this Model is the Caps on the Main Board, but to make sure pull the codes. Follow this procedure:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Aug 24, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
Sony SLV-R1000 S-VHS VCR Logo
94 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
