Question about True GDM-12 Refrigerator Commercial
How can I adjust the door hang on our True GDM-12?
How can I adjust the door hang on our True GDM-12 cooler? It seems to sag a bit on the left side (opposite the hing side) and does not create a good seal.
  • 400 Answers
SOURCE: I have a true GDM-12FC floral cooler that the
You have not said if the cooler is cooling to the correct temperature or achieving the setpoint. Make sure that the correct thermostat has been supplied. Also that the sensor has been installed in the correct location. If all of the above is correct, then I would have the refrigerant level checked.
Posted on Mar 09, 2009
  • 531 Answers
SOURCE: gdm 69 true cooler wont cool. smels like its
check compressor or fans
Posted on Apr 06, 2009
  • 415 Answers
SOURCE: How to adjust door hinges on fridge
on the door thats sagging on top of the of the door is a cap some have a screw holding it....if not use a screwdriver at the back of the cover and pop it up then you have small bolts some have 2 but most have 3 just loosen up but no need to remove then pull towards the hinge to see it move again move to the to where level you can place something in the gap between the door or have someone hold the door in place then reverse order to complete
Posted on Sep 06, 2009
Testimonial: "Thank you. I just fixed the problem singlehandedly with yor helpful instructions!"
  • 113 Answers
SOURCE: Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Posted on Sep 15, 2009
  • 274 Answers
SOURCE: True GDM-12 - Unit runs, but won't cool below 60 degrees,
Is it very hot out side the unit.recharging may not hurt is it cleaned the lint could be trapping the radiator were the coolan goes through to cool down try cleanning underneath before recharging
Posted on Jul 26, 2010
Can you please tell me what the inside top fan is called on my Mt 12 cooler. also the door is sagging a bit.
Call the manufacture ask for tech support they will tell you the fan and part number sag in door hinges need to be adjusted on door
Apr 20, 2015 | Refrigerators
How do i chage the temperature on a true cooler gdm 49 florial cooler
True GDM-12 Refrigerator... Repair Questions - Fixya
www.fixya.com/support/p22955-true_gdm_12_refrigerator_commercial
Recent True GDM-12 Refrigerator Commercial questions, problems & answers. ...Where is the temp control on the older (14 yrs or so) on GMD-12? True ..
Aug 16, 2014 | True GDM-12 Refrigerator Commercial
Noisy compressor?
My Gdm 12 was doing the very same thing. Remove the from grill plate by taking out the 4 screws below the door. This will expose the compressor mounting plate . While the compressor is running, and is at its loudest, loosen or tighten the two front hold down bolts until the noise goes away. Most likely, when you cooler was moved or transported off the shipping pallet, it was bent slightly allowing contact between the bottom of the compressor, and the mounting plate. Hope this helps.
Feb 03, 2014 | True GDM-12 Refrigerator Commercial
True 3 door refrigerator model#GDM-72 door does not self close
hi, I lost a part of the true cooler model gdm-72 door part that let the door side itself to close
Nov 01, 2012 | True Refrigerators
Replacing temperature control on a True beverage cooler
Remove the doors, then the evaporator cover. Just be careful.
May 20, 2009 | True GDM-7 Beverage Cooler
Help?
turn thermostat all the way to the left to turn it off. restore power and see if it stays on and inside fan is running. Then turn thermostat to rite to turn on compressor. If the power trips when turning thermostat back on, the compressor may be bad. :(
Dec 27, 2007 | True GDM-41 Refrigerator
True GDM-12 Refrigerator Commercial Logo
77 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
