Question about Acer Aspire One PC Notebook
Broke screen acer laptop how do I display it on another monitor
I just dropped my acer aspire laptop and most of the screen is not visible and it has lines running through it. I know I broke the LCD screen. If I plug an external monitor into it, how do I get it to display without being able to see the original screen?
    President:
  • 2,600 Answers
Holding down the Fn key and pressing the F5 key will toggle through all the video presets. That includes just the internal monitor, the external monitor and both monitors.
Posted on Apr 23, 2010
Testimonial: "Parrotheadpc gave me a quick and clear response that was just what I needed. I appreciate it very much. Thank you for humoring my ignorance."
I dropped my acer ASPIRE 5336-2524 laptop. Now the screen is distorted. I tried to get into display properties, then re-installed Windows 7. However, I can only identify one-third of the computer screen. I...
If you dropped your laptop and the screen got broken, there is no way to fix it via any software change. But you have two options:
  1. Connect an external monitor via VGA port, more information here
  2. Get fixed it by Acer service
Jul 06, 2011 | Acer Aspire 53362752 Notebook
Broken Acer Aspire 5315 laptop screen
if you hook up a vga cable to your computer you mite need to adjust it in control panel if you can get there ;
May 01, 2010 | Acer Aspire 5315 Notebook
Acer Aspire One notebook model zG5, i hear the hard drive come on, but screen is blank and the keyboard does not respond.
connect the laptop to an external monitor, turn it on see if the monitor will display.
If the monitor displays, then it means your screen inverter or screen bulb is the cause of the laptop screen being blank.
Also if the monitor does not display anything, the maybe the graphic card is the cause of the problem.
This would involve you taking the laptop to a repairer
Take care.
Apr 15, 2010 | Acer Aspire One PC Notebook
My daughter just dropped her acer aspire netbook. Only half of the screen is visible the other half is white and black with a line down the middle
Dropping the netbook will have probably broken the LCD screen.
There is no other way to repair the problem without replacing the screen itself. You can however use a external monitor and use the keyboard to toggle between the two screens.
I know this is probably not what you wanted to hear but unfortunately LCD screens are fragile so a good knock can crack them causing only one half or the part or the screen which is not broken to show. The backlight itself sounds like its working as there is still light showing behind the cracks.
Regards.
Mar 14, 2010 | Acer Aspire One PC Notebook
Aspire Notebook 5735-4774 won't display on external CRT monitor
If the video chip on the Aspire motherboard is OK then the image on the external monitor would be OK. If not then the video/motherboard is faulty.
To gain access to data on the hard disk, remove the hard disk and connect it to an USB hard drive adapter and plug it into a working computer's USB port. The computer will see this as an external hard drive.
Alternately -
You can put the hard drive in an USB hard drive adapter case and use it as an external USB hard drive.
Dec 21, 2009 | Acer Aspire 5735 Notebook
Lcd screen broke external monitor wont work
Sounds like you resolution is too high or vista doesn't recognise your driver.
Try starting in Safe Mode by powering up your PC and tapping the F8 key until you see a menu. Select Safe Mode from the menu. Once in safe mode change the resolution to 800x600 then restart in normal mode.
If that doesn't work then download and install the correct drivers for your display card here;
ftp://ftp.work.acer-euro.com/notebook/aspire_3680/
Once downloaded, you may need to install it in safe made once again.
Thanks
C
Mar 28, 2009 | Acer Aspire 3680 Laptop
Screen problem
this is the problem of the display panel consult acer for this
Sep 29, 2008 | Acer Aspire 1641WLMi Notebook
Acer aspire 5050 laptop color lines on screen
you can try pulling the screen apart and re-seating the ribbon cable, but the lcd might be broken, or one of the controller lcd chips might either be cracked or broken. Trying to reseat the lcd ribbon cable might help, but if there is a visible crack in the screen- you will need a new screen.
Nov 24, 2007 | Acer Aspire 5050-3242 Notebook
Display on the monitor screen
Try an external monitor if all goes well you LCD is broke. Try these people for more info: http://lcdrepair.net
Oct 07, 2007 | Acer Aspire 5630 Notebook
Acer Aspire 1403LC (app 6 years old) Screen resolution problem
You may have a corrupt driver, go to this site and down load vga driver, as i cannot see a grphics driver for your system http://support.acer-euro.com/drivers/notebook/as_1400.html
Mar 08, 2007 | Acer Aspire 1403LC Notebook
Acer Aspire One  PC Notebook Logo
235 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
