LG Rear Projection TV - Model RT39NZ40RB
I have a 99cm LG Rear Projection T>V Model RT39NZ40RB, it was working perfectly the other day then just went off. Now I go to turn it on and the green on light does not come on, it is just black but when I turn it off the red light comes on. There is no picture at all and no sound. I had it repaired on the 3.05.05 and they replaced the deflection PCB, which cost me $570.00. I'm wondering if it would be the same problem or a different one and I'm certainly thinking twice about getting it fixed depending on the cost, this tele is costing me a fortune. Can you offer any explanation as to what it could be and approx $$$ figure to fix. Thanks
  • gonggirl Mar 23, 2008
    Thanks but I am in Australia, a bit too far to go.
    Problem Solver:
  • 9 Answers
Plz contect me if u r in india or in delhi
Yogesh-- 09811440932
Posted on Jul 29, 2009
I repairs projection plasma and lcd tv's u can call me at 9811440932 (yogesh saini) only for delhi
Posted on Mar 23, 2008
6ya staff
SOURCE:
My Model TV # is 51swx20B. Two days ago the picture started having a lot of green in it and no blue. What is the repair needed.
Do adjustments on focus block. Will have to open front panel access door, focus block blue will be on left, green will be on top. Top screen bottom focus. Turn clockwise to increase, counter clockwise to decrease brightness. Turn the color all the way down on menu where it's pure black and white and make adjustments for perfect black and white picture, then when you adjust color, it will be perfect.
Aug 09, 2011 | Hitachi 51SWX20B 51" Rear Projection...
Blue ghosting on LG rear projection TV- not fixed by using Auto Convergence button. Any other suggestions - Model RT39NZ40RB
Probably a failure in the convergence output circuit. Most circuits are comprised of a 2 IC package and I would recommend replacing both. $100-150 in parts and some experience with a soldering iron is good. Thx
Bill W
integrityhomeworx.com
Mar 09, 2011 | Televison & Video
Green Picture
Sounds like you are not getting a red in your feed. Have you check the feed into your tv or if the cables are having a problem?? check it and let me know........
May 27, 2010 | Samsung HCN4226W 42" Rear Projection...
TV was working perfectly; and now i dont get cable or regular....
most tvs that are digital have already switched over and thats problably what your tv did and i don't know how to change or fix that problem
Jan 31, 2009 | LG RU-52SZ51D 52" Rear Projection...
No picture, no sound
the power supply for the convergence circuit is not working, check for open resistor on the primary
Nov 24, 2008 | RCA P52926 52" Rear Projection Television
Sony 55" rear projection tv
TIGHTEN THE BULB --AFTER YOY CLEAN THE DUST OFF THE BULB VENTS ON THE BULB ITSELF. PROBLEM SOLVED. EASY--CHEAP. Hey it worked for me. My picture was turning off blinking 29 times for picture 37 times for audio. This was the first issue with my KDF-55WF655 since I unwrapped it almost 5 years ago......... ITS STILL ON!!! I hope this helps someone.
Feb 14, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
67" rear projection Mitsubishi....
Sounds like a cold solder joint, turn the main pcb over and see if you find any cracked solder or where the solder looks like it got hot.
Dec 04, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Samsung rear projection tv
WE always need the model #..............................T.
Nov 15, 2007 | Pioneer PRO-99 TV
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
