Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Light will not turn off, have pulled switches from both sides and still stays on
    Scholar:
  • 126 Answers
SOUNDS LIKE THE RELAY ON THE MAIN BOARD STUCK ON. YOU NEED A NEW MAIN BOARD. IT CAN BE ORDERED ON THE SEARS SITEhttp://www.searspartsdirect.com/partsdirect/index.action.
Posted on Apr 24, 2010
2000 chevy 2500 (new style) parking lights wont shut off
The parking lights staying on and the left turn signal not working may not be related, the turn signal is probably a burned out bulb, turn on the left signal and see if all the bulbs light up if not replace the burnt one, if they all light, the turn signal flasher may be at fault ( it can work with one side and not the other), as far as the parking lights staying on, check the door "pin" switch that controls the interior lights (are the interior lights staying on too?), since the chimes are staying on even with the keys on , I would suspect the door pin switch, probably the drivers side. I believe there may be a timer on the parking lights that turn them off after several seconds after the door is closed, this may be at fault if not the pin switch. newer cars and trucks also leave the reverse lights on for a while after the door is closed.
Dec 20, 2013 | Chevrolet Silverado Cars & Trucks
One light stays on 2lights one switch
check wiring to switch the light that stays on must be wired to the wrong side of switch. disconect both wires from both lights and double them up and reconect them where the light that turns off was wired
Jun 27, 2013 | Cars & Trucks
Brake lights stay on
Ok, the brake light is turned on when the brake lever is pulled. The switch is actually located in the right switch housing along with the right turn signal switch, starter switch, and throttle. It's simple button switch. When the lever is pulled, it pivots on the pivot pin and small tang on the bottom side to the lever swings FORWARD releasing the swith turning on the light. When you let go the tang swing backwards depressing the button turning off the light.
Loosen the bolts that hold your front brake master cylinder to the handlebar and slide the master cylinder back towards the switch houslng as far as you can. They should be touching. If the light still won't turn off, you'll have to take the right hand switch housing apart and replace the small switch.
Good Luck
Steve
May 28, 2010 | 2000 Harley Davidson FLHR-FLHRI Road king
Right side will not work light glow only
If you have a service vehicle soon light (not service engine soon) this usually indicates a problem with the foreward lamp system.Your problem seems confusing, but check your high beam lamp operation. These cars are NOTORIOUS for corroded harnesses to the headlights. The problem is usually buried behind the washer bottle or across the radiator area. If you are lucky, it may be a burned out high beam bulb. If the blue symbol for brights stays on and there is no click when pulling on high beam lever, you will need a new turn signal switch.
Jun 21, 2009 | 2004 Chevrolet Cavalier
Head lights wont turn off after turnning off car
See if you have fuse under dash or under hood if more fuses in there that is marked DRL , or DRL module. (daytime running light module) may be at fault. Pulling that fuse may isolate problem, otherwise you may have to pull connector off back of light switch to test it.
Jun 06, 2009 | 1995 Dodge Spirit
Tail Lights stay on all the time.
under the dashboard on the drivers side. look at the brake pedal lever. there should be a switch attached. push switch in and twist to remove. then pull the button as far out as it will go. while holding brake pedal down reinstall switch. then pull pedal up to top. this will reset the brake light switch. if they stay on still, then just replace the brake light switch.
Jan 19, 2009 | 2001 Dodge Ram 1500 Truck 2WD
My headlights wont turn off on my 2003 dodge intrepid
I own the same year make and model. The headlights are supposed to stay on for a few minutes if you shut them off after shutting off the engine. This is a safety feature. These are the headlights only. If the lights, side markers and taillights stay on, then the issue is most likely the switch. You will have to pull the switch and disconnect the wiring harness to confirm this. If the lights go out, then the switch is bad.
However, if the lights don't go out, or the headlights never shut off until they drain the battery, you may want to take the car in to get diagnosed. There could be an issue with the body control module or wiring. Most likely, it is the switch as Chrysler uses the cheapest parts for their switches, but I would check it first and not swap parts. All you have to do to check the switch is pull the bezel it sit in out of the dash. The switch is held in with two screws.
Dec 22, 2008 | 2003 Dodge Intrepid
Tail lights and marker lights stay on
On my 2004 Impreza ther is a switch on top of steering column that turns those lights on all the time. Look for that switch.
Dec 10, 2008 | 2005 Subaru Impreza
Tail lights
There is a switch on top of the steering column that switches the parking light facility on and off. Check that this switch is not in the on position . If it is on then your side lights will stay on even if you turn the lights off.
Aug 30, 2008 | 1993 Subaru Impreza
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
338 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
