Question about GE Washing Machines
Water level control problem / washer overfills
wagdom
  • 64 Answers
SOURCE: Unable to control water level
Some water may have got into the pressure switch. Remove the pressure switch and see if you can shake any water out. Make sure the cables go back on the correct terminals. make sure the tub is empty when you refit the pressure switch, so no water is allowed to enter the pressure tube
Posted on Oct 29, 2007
SOURCE: Maytag washer model # LAT8714A over fills
An overfill caused by a failed valve will occur even if the machine is unplugged. Trace amounts of debris from your plumbing etc or even a deterioration of valve parts themselves can cause it to pass water while off. This can be as slow as a drip but given time it will overflow. Water level switches are by necessity highly reliable parts and when they do fail they usually "fail safe" in other words not allow any current to the water valve. Overfills that are not due to a bad water inlet valve are usually traceable to a pinched, plugged or disconnected air hose. The location of the switch varies. Sometimes it's right behind the water level knob. On others like front loaders it's inside the machine, usually above the tub and at the end of a length of clear plastic tubing.
Posted on Jan 29, 2008
AlmostBob
  • 550 Answers
SOURCE: Removing the top
the pressure sensor is inside the control panel, the panel is screwed closed from the rear
you initially check that the plastic air line is attached at top and bottom
top is easy
to reach the bottom
the top of the washer must be removed, unlock the two metal clips at the front ~3 inches from the edges by sliding a putty knife or other blunt blade between the front panel and the top
tilt up the top
visully inspect the air line running from the top left to the bottom of the drum/tank
usually the top comes off
test that first,
because if the bottom is off, there would be water running all over the floor as the pressure sensor attaches below water line
if both hose ends are attached remove the top end and blowe down it, any water in the line messes up pressure readings
the water level sensor is adjustable
remove the water level sensor body from the control panel, there is a lock clip on the right side of the control body
there is a 1/8th nut next to the shaft the knob sits on
clockwise to raise water level
counterclockwise to lower water level
if turning the adjuster has no effect, the spring inside has broken, not weakened, and the control body should be replaced.
water level control bodies are common to many models and makes, the local parts store will have a suitable one, even if labelled ge or kenmore instead of maytag
Posted on Sep 11, 2008
TheMobilian
  • 8220 Answers
SOURCE: maytag washer overfilling
Easy fix. Do this: Remove the rubber tube coming from the bottom of the tub up to the water level switch right there at the switch itself. Blow through it to remove the sediment in the bottom of the tub so that air pressure from tub to switch will be kosher. Put the hose back on the water level switch tight and pump out any water in the machine.
Retry
Posted on Dec 19, 2008
skrbin
  • 121 Answers
SOURCE: Water level does not work.
check water level device,or hose on device is dirty.
If is level device must change it.
Posted on Feb 16, 2009
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
Washer overfilling
check for the water level controller is switching of the water control solenoids
check that the solenoid solenoids are working and not just humming
if they are humming , replace the control unit
Jun 23, 2016 | GE Office Equipment & Supplies
Washing machine overfilling with water.
Possible that the inlet valve is not controlled or faulty . check the voltage and see if the voltage is cut after the level is achieved. If not the water level sensor is defective.
If the inlet is not controlled then the program controller is a suspect.
Jun 28, 2012 | Ariston Technologies Ariston AWD12 Front...
WATER LEAKING FROM TOP WHEN START SPINNING,MY WASHER IS MAV 7600AWW,I CHANGED THE SEAL AND STIL LEAKING
Does this happen on any water level setting, or just on full load? If the machine is overfilling, the centrifugal force at the start of the spin cycle will throw the water up the sides high enough to overflow the top of the tub.
If the machine is overfilling just a little as I suggest, then the water level switch may be out of calibration or the water level hose may be partially clogged at the tub end. A quick fix in the latter case would be to disconnect the hose from the level switch and blow compressed air through it - it's a lot easier to get into the control panel than the side of the tub. A leaky hose would have a similar effect.
Feb 04, 2011 | Maytag MAV7600 Top Load Washer
Washer overfills
This is caused by either a washer fill level sensor tube being blocked or the pressure switch it acts on being defective, the water level switch is next to the timer control on the top of the washer panel.
Dec 23, 2010 | GE WDSR2080D Top Load Washer
My maytag washer model lav3600aww continues to overfill and overflows
Hi There
I have found some stuff for you to read and hope this helps you. Let me know how it goes.
It's overfilling If your washer is overfilling, check these: Water-inlet valve Water-level switch Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Maytag PAV2300 Top Load Washer
Water doesn't shut off causing overfilling of the
the pressure hose may have come off the water level switch. you need to acess the control panel, check the water level switch, there is a small pressure hose that slides on the small stem toward the lower rear of the wl switch. if the hose is disconnected, put it back on & it should work fine. if the hose did not come off, you either have a bad wl switch, or the pressure hose is plugged and needs cleared. hope this solves your problem. shane
Jun 29, 2009 | Washing Machines
Occasionally it will overfill
The water level switch is your problem.
Open the control panel and remove the plastic hose from the level switch and blow through it.
Soap and dirt clog the bottom end and prevents the switch from stopping. The water continues to flow because of this blockage.
After you reattach the plastic hose , set the washer to spin and turn it on to reset the switch.
Mar 15, 2009 | GE WBSR3140DW Top Load Washer
Machine over filling even when set on min. simpson enduro 701
When the machine is overfilling , it means that there is a problem with the inlet valve (valve not closing) or with the water level switch, that should turn off the valve when water reaches level.
See the suggestion from It's overfilling at repairclinic:
Water-inlet valve
Water-level switch
Oct 06, 2008 | Washing Machines
Overfilling Whirlpool cabrio washer
Great! It may be the water level control switch. So, where is it and how do you check it or fix it or replace it?
Jan 13, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
100 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
