Question about Bose On-Ear Headphones
Bose on ear headphones - wire problem
I got these Bose on-ear headphones about half a year ago off of craigslist. They worked perfectly fine until about two weeks ago, when the right jugg stopped working. I messed with the headphone for a while and found, that it worked every once and then, depending on the positions, and angle in which it was in. So now, I am relatively sure that it is a wire problem on the inside!! I've tried opening them, but thats were my problem is. I can get past the foam cushion and open the two small screws, but the plastic cover is still attached somehow. I have tried sticking a needle into the small hole (it was my only idea) but nothing happened. Can someone please help me?? Also, I don't want to get them fixed or repaired since the headphones only cost me 60$. On top of that, I am currently in japan and the shipping would be too expensive
5 Suggested Answers
  • 93 Answers
SOURCE: My right earphone won't play
Sound not coming out of one side of the headphone is an indication of connection failure, so that means you have to see where its 'broken' from, either inside the headphone on on the wire somewhere. Usually it happens at the jack, especially if you use an ipod as it tends to get moved alot in pockets, etc..
If this is the case, you could try to cut the wire from where you suspect its broken, and get a 3.5mm (or whatever the original size is) replacement (Do-it-yourself) jack from Radio shack or electronics store.
THen you would have to cut the wire, strip the the rubber coating off, and then if applicable, carefully strip the very thin layer of further insulation thats on the wire it self. Otherwise you would directly connect the cables to the prongs/connections located on the replacement jack. And depending on the jack you would screw it in place or soldier it with soldier and soldiering gun.
If its broken in the headphone or at the headphone, thats much harder to do as you would have to open the head/earphone case and soldier it that way and get it back together in one piece.
Next time don't buy bose headphones and by something cheaper, bose isn't that great, skullcandy is pretty good too. Sennheiser is the best though in my opinion. albieit its expensive too..
Posted on Feb 27, 2009
SOURCE: How can I fix an intermittent sound problem on the
I have the same problem. The first one that I bought last 1 year. I bought another one and the same problem has appeared today. I think this is because they are assembled in China. Cheap and low quality manufacturer that is sold at very high prices.
Posted on Jun 14, 2010
SOURCE: Opening bose on-ear headphone speaker's cup
There are four screws that hold the cup together. Two at the top and two under the foam that goes between the ear pad and the plastic cup. Once I removed the four screws the cup and speaker came apart with no problem. Of course I did not see any issues with the soldering, so I have a bigger problem.
Posted on Mar 09, 2011
  • 5 Answers
SOURCE: boss oethe left side of my headphone is stop working
Try putting the output reciever into your ****.. Then put the earphones on. If you dont hear anything you might want to bring it back to the retailer and explain that your test proved them that it dont work.
Posted on Jan 18, 2012
My bose in ear earphones shows ugly cracks at several places though its still working.It is already outside warranty and bose rep said that they would replace it with a new one less 30% discount which is...
I am really sorry Sanjeev.There is no way of replacing the wires of the BOSE earphones.Go for a new one if you think the present one is weird.Now you are having an offer for 30 % !!....It's the perfect time buddy...Don't forget to rate me if satisfied.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 14, 2011 | Bose in-ear headphones - Black with...
The left side of my bose earphones is working perfectly but the right side just went completely dead is there any way to fix this?
in most cases this is a broken wire issue and it can not be fixed unless you know where the trouble is exactly ..The fix will be to locate the break ..and tide it back ..but if it is a fine wire piece you will not be able to do much ..
Oct 03, 2010 | Bose in-ear headphones - Black with...
I have a short in the right earcup, when tapped it will work, for a little bit, but go off again. It only shuts off the right earpiece, not the left.
well you have a few options the first is how long have you owned the unit? is the unit still under warranty? if the unit is under warranty contact bose for a replacement unit.
the 2nd if its not under warranty is to open the bose headset and re-solder the right ear piece. If you can tap the right ear piece and the sound becomes intermittent that is a indicator that it is inside that headphone.
If you have a soldering iron and flux/solder Open the ear piece and then attempt to find the loose connection. At this point put a little flux on the the loose wire. Then heat up your soldering iron. Now only take a small bit of lead free solder and attempt to repair the loose connection. If you solder it correctly it should be working perfectly fine
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment 4 thumbs up. thanks and have a great day.
Aug 19, 2010 | Bose QC2 Headphones
The wiring in the inside of the headphones is messed up
the wire inside the cable has broken
are these headphones real? orginal bose?
if so i would contact bose because the wire shouldnt break (under normal use)
May 14, 2010 | Bose in-ear headphones - Black with...
I have had the bose in-ear headphones for a year and they were great at first and then all of a sudden the left earpiece stops working. If I move the part that connects the headphones to the ipod then it...
If your headphones are in warranty (under a year old) Bose will repair or more likely replace them with a new pair. I am now on my forth pair or Bose in-ear headphones and experienced the same problem with an ear piece stop working. I have to say Bose customer service has been fantastic and has replaced each pair. Every new pair is then covered by a new full years warranty. Unfortunately my fourth pair has just gone wrong with the same connector problem. Bose again have said they will replace as they are in warranty. I have been told if they are out of warranty they will offer a new pair at a discount price of £50 instead of £80. However i think that if my new pair go wrong out of warranty i will have no option but to look at alternatives.A Pair of headphones that cost £80 should last more than a year!!!
Mar 29, 2010 | Bose in-ear headphones - Black with...
Wire broke right next to headphone jack; any easy way to fix?
if you are not handy, then no.
repair will require disassembly of the ear piece, splicing of the wire, and reassembly.
Sep 19, 2009 | Bose TRIPORTĀ® Headphones
My left earbud no longer produces sound! I was jogging with the earbuds and it started getting static and cutting out. I took them out thinking maybe some sweat got in them or something. I let them sit...
whatever the problem is give a call to Bose customer support(800-999-2673) and u can talk with them to get a replacement. If u r in one year warranty they will replace it(even if havnt bought it at bose store)...otherwise they will charge $50 i believe
Apr 19, 2009 | Bose in-ear headphones - Black with...
Right Bose In-ear cord separated from headphone
i know that these are very exspencive headphones, they were 100 dollars, and they are great. unfortunitally, these cannot be fixed without getting new headphones, sorry!!!
Mar 17, 2009 | Bose in-ear headphones - Black with...
Bose in-ear headphone cord cut
most head phones there two wires. those are the two that you most likly put together. if there is any metel mesh covering the wires. that has to be connected also.
Jun 05, 2008 | Bose in-ear headphones - Black with...
Bose On-Ear Headphones Logo
125 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
