Question about LG Art Cool LA121CNP wall/window Air Conditioner
After 4-5 hrs of running it ice particals drop out of AC and fall out.
  • 59 Answers
MAKE SURE THE FILTER IS CLEAN AND COLD COIL IS CLEAN . JUST REMEMBER 70 OUT SIDE AND 70 OR LOWER INSIDE AND YOU HAVE A ICE CONDITION. 75 INSIDE AND 75 OR HIGHER OUTSIDE KEEPS UNIT FROM ICING UP. IF ITS LOW ON FREON IT WILL ALSO ICE UP. MOST OF THE TIME THEY DONT LEAK FREON BECAUSE THEY ARE SEALED SYSTEMS
Posted on Apr 24, 2010
Have a scottsmanicemachine doesnt drop ice compressor on water on water runs on coils goes to harvest but makes no ice coil usualy have a ice buildup before it harves
The water runs over the evaporator coil(plate) until the ice gets thick enough, than when the ices touches a switch for the thickness you have it set for, it to go into harvest and the hot gas from the liquid line goes through the evaporator making the ice fall. If you are not making ice, it is the refrigeration system not working, so check the refrigerant, compressor etc like you would on any refrigerator or freezer
Dec 09, 2014 | Coffee Makers & Espresso Machines
2006 Subaru Forester. AC always runs properly cool except once or twice a day when air turns warm for about 1-2 minutes. Then back to normal.
IT may be that there is ice forming on the evaporator in the car. This prevents the ac from working as the thermostat setting is affected and the ac shuts down until the ice clears and the thermostat gets a new reading. Check that the ac evaporator core fins are clean and free of gunk build up. Some times you may be a clink sound as the ice breaks away and falls into the ac box
Feb 14, 2014 | 2006 Subaru Forester
Have General Electric standup freezer; model # FUF2DMARWH. Left door open a tad, over night. Unplugged it in morning for 10 min., then plugged it in and it seemed to be working as the temp. dropped...
turn off freezer and remove freezer panel at bottom in back. if evap.coil full of ice then defrost all ice. if no ice build-up then compressor may need new relay.
Aug 29, 2013 | General Electric Refrigerators
Franklin chef ice maker fim70 finished running cleaning cycle. have cleaned plugs, lines, on rear and sprayer inside bin. water continues to run, ice forms on top (w/ frost). Ice never drops.
Hello
Ice may jam up in an ice dam and close off the chute. Shove the ice scoop up into the chute with a fair amount of force to break up the ice dam. Chunks of ice should fall into the bin, followed by a shower of ice cubes.
Jun 21, 2011 | Franklin Freezer Chef FIM70 Commercial Ice...
Little door that lets ice fall into glass won't
need to check door chute hinge it could be broken
Nov 05, 2009 | Kenmore Refrigerators
OUR ADMIRAL ICE MAKER HASNT DROPPED ICE IN ABOUT 2-4 HRS. WE ALWAYS ADJUST THE ARM MANUALLY WHEN NEEDED AS THERE SOMETIMES IS SOME ICE CUBE BUILD UP. THAT DOSENT SEEM TO BE THE PROBLEM NOW. THE TRAY IS...
They sometimes get frosted up and don't want to work the motor properly...if you can get the face of it off, take a hair dryer and heat it up until the frost melts off...don't spin the fan motor if you have one on that unit. Then put it bad on and see if that will help if it doesn't you may have to replace the whole unit. They run around $190 if you do it yourself...not too hard of a job.
Oct 29, 2009 | Admiral AAV7000A
Still not getting clean ice ED5VHGXM Side by Side Refrigerator
If particals are dark then most likely the icemaker is causing this. The non stick surface does break down over time and will leave particals in ice. Unfortunately there is no repair I am aware of for this,< in past had to replace icemakers due to this>.If this is not wh at you find then disregard this.
Apr 28, 2009 | Whirlpool ED5VHGXM Side by Side...
Formation of ice on evaporator element
hi! there,
eventually ice freezing evaporator occured two factor you have
dirty fin evaporator and undercharge system.
1. undercharge can easily detected using clamp
ammeter clamp on one line of evaporator while running
read the amper the compare this to yuor service
manual the rated current of the compressor.
2.if the reading current is below the rared current on
manual or there is tag on the body of unit specified
rated current.your unit need to recharge.
if has the same current no change at all freon is still
good, this only need cleaning of eveporator fin.
clean this by pressurise water to purge out all debris
particle on fin tube of evaporator.
cracking sound usally made by blwer or fan
misalignement or distorted bearing blower .
regards have anice day dont forget to rate me.
Apr 10, 2009 | LG Heating & Cooling
Freezer temp increased slowly;ice cream/ice will not freeze
If the repairman is experienced the problem will be resolved. I have recharged refrigerators myself and it is difficult, time consuming ad tedious. Sorry the work needs to be done in your home. If he does not know what he is doing he will cause problems and make excuses for why the refrigerator does not work correctly. Hope you have the best service available for your area. Sea Breeze
Mar 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
LG Art Cool LA121CNP wall/window Air Conditioner Logo
288 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
