Question about Kenmore 53532 / 53534 Side by Side Refrigerator
Not cooling, the fan works, but not cooling! - Kenmore 53532 / 53534 Side by Side Refrigerator
    Scholar:
  • 126 Answers
THE START DEVICE ON THE BACK OF THE REFRIGERATOR COMPRESSOR MAY HAVE FAILED. ESPECILLY IF THE BIG ROUND BLACK THING IS HOT. THE PART IS ON THE LEFT SIDE OF THAT. PART NUMBER 12002782. CAN BE ORDERED HERE. http://www.searspartsdirect.com/partsdirect/index.action
Posted on Apr 24, 2010
Testimonial: "thanks!"
2009 chevy hhr speakers don't work and a/c radiator fan won't come on
What engine does it have ?
Cooling Fan Control 2.0L
The engine cooling fan is a variable speed fan. The engine control module (ECM) controls the fan speed by sending a pulse width modulated (PWM) signal to the cooling fan control module. The cooling fan control module varies the voltage drop across the engine cooling fan motor in relation to the PWM signal. The cooling fan speed can be adjusted from 10 percent to 94 percent duty cycle. 94 percent is considered high speed fan.
Cooling Fan Control 2.2L or 2.4L
The engine cooling fan system consists of one cooling fan and one relay. Voltage is supplied to the relay through a fuse. The engine control module (ECM) controls the fan operation by grounding the cool fan relay control circuit. When the cool fan relay is energized, voltage is delivered to the cooling fan motor. The cooling fan motor is grounded through its own ground circuit.
When the request for fan activation is withdrawn, the fan may not turn OFF until the ignition switch is moved to the OFF position or the vehicle speed exceeds approximately 10 mph. This is to prevent the fan from cycling ON and OFF excessively at idle.
Just one speaker doesn't work ? Do you know how to do automotive electrical testing ? That's how to find both your problems . Speakes work by electrical inpluse's . The A/C radiator ( condenser ) fan also works by B+ voltage through a fuse an a relay , controlled by the engine electronic control module or PCM - powertrain control module . When you push the A/C turn on button , it sends a signal to the PCM . The PCM will then energize the radiator fan relay turning on the fan . Check fuse in the under hood fuse box , If the fuse is blown you have a electrical short , too much current flow . Plus if the PCM sees too much pressure in the A/C system it will not let the A/C work .
Mar 31, 2017 | Cars & Trucks
Where can I get pictures of the fans in the engine compartment?
Radiator Cooling Fans - Professional Mechanics Online
www.2carpros.com/articles/how-an-electric-cooling-fan-works
Aug 1, 2015 - Step 1 - There are primarily two types of engine radiator cooling fan, electric and manual. A manual fan is connected to the engine drive pulleys ...
article How a fan clutch works
https://www.2carpros.com/articles/how-a-clutch-fan-works
Sep 3, 2015 - Step 1 - A fan clutch function is to engage the fan blade to the shaft when heated which is mounted to the front of the engine attached to the ...
Improving an Engine Cooling Fan Using Design for Six Sigma
www.mathworks.com/.../improving-an-engine-cooling-fan-u...
MathWorksA key component of an engine's cooling system is the cooling fan, which ... a shroud to direct airflow through the radiator (image courtesy of Novak Conversions).
Dec 21, 2015 | 1996 Chevrolet Cavalier
C550 cooling fan not functioning, what can i do to make work?
Konica Minolta bizhub cooling fan not working Questions ...
www.fixya.com/tags/cooling_fan_not_working/printers/konica.../bizhub
Konica Minolta bizhub printers & copiers cooling fan not working related questions and answers. Ask your Konica ... Question about Bizhub C550. 1 Answer ...
Konica Minolta Bizhub C550 Cooling fan power - Questions ...
www.fixya.com > ... > bizhub > Konica Minolta Bizhub C550
konica minolta bizhub c252 error c-5351 C - 5351 Is power cooling fan problem.Verify the cooling fan connectors and clean.For reset open/close the front door.
cooling fan not operating properly - HP Support Forum
Nov 29, 2015 | Cars & Trucks
My ac is not working I have a Chevy Tahoe 2005 the fans won't turn on either .
Hi Maria , The A/C system wouldn't keep the fans from running but none working cooling fans will keep the A/C from working ! This is a fairly complex system if your not familiar with this sort of thing ! I will add the description from the factory service manual.
Cooling Fan Control - Two Fan System
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the powertrain control module (PCM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block.
During low speed operation, the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan s/p relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM supplies a ground path for the high speed fan relay and the cooling fan s/p relay through the high speed cooling fan relay control circuit. This energizes the cooling fan s/p relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the high speed fan relay coil is energized closing the relay contacts and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Do you have a check engine light lit ? The thing to do would have it check at the dealer or a ASE certified repair facility ! They could hook up a advanced scan tool an diagnose fairly quick ! Or you could find a wiring diagram an try testing with a volt meter yourself ! But watch yourself so you don't short out the PCM - engine computer !
May 01, 2015 | AC Cars & Trucks
Dodge Stratus R/T fan doesn't come on while car is running and car is getting hot.
FAN NOT WORKING
It can be issue with faulty motor or its faulty fan control relay.
Bother are to be inspected.
Test volt at fan relay and fan motor.
For more help, I suggest you to go through the troubleshooting links mentioned below:-----
Click the link below: ------
How to replace Cooling Fan on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-cooling-fan-on-acura-car.html
OBD Code P1490 low speed fan relay ckt open-short
http://schematicsdiagram.blogspot.com/2012/11/obd-code-p1490-low-speed-fan-relay-ckt.html
Engine cooling components working?
http://repairhelpcenter.blogspot.com/2011/11/engine-cooling-components-working.html
How does Vehicles Engine cooling system works?
http://repairhelpcenter.blogspot.com/2011/11/how-does-vehicles-engine-cooling-system.html
Hyundai Sonata cooling fan not working
http://schematicsdiagram.blogspot.in/2012/02/hyundai-sonata-cooling-fan-not-working.html
Fuel pump relay and cooling fan relay troubleshooting on 1997 ford thunderbird?
http://repairhelpcenter.blogspot.com/2011/10/fuel-pump-relay-and-cooling-fan-relay.html
Fan belt routing diagram for 2004 Volkswagen Jetta?
http://carbeltrouting.blogspot.com/2011/12/fan-belt-routing-diagram-for-2004.html
Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
A/C, heater, defroster fan, not working?
http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Blower fan not running on Isuzu trooper?
http://technoanswers.blogspot.in/2012/02/blower-fan-not-running-on-isuzu-trooper.html
How to replace blower motor fan assembly on 2000 GMC Yukon?
http://repairhelpcenter.blogspot.com/2012/01/how-to-replace-blower-motor-fan.html
Heater AC or defroster fan not working on KIA?
http://technoanswers.blogspot.in/2012/02/heater-ac-or-defroster-fan-not-working.html
These will help.
Thanks.
Nov 27, 2012 | Cars & Trucks
Fan won't work
Bother are to be inspected.Test volt at fan relay and fan motor.-------------
For more help,i suggest you to go through the troubleshooting links mentioned below:-----Click the link below:------
------------These will help.Thanks.
Engine cooling fan only works when ac or defrost is on
if engine at long stand still,the engine temperature will rise about 190 degrees the cooling fan suppose to automaticaly turn on when coolant temperature sensor get hot it cause its resistance decrease causing pcm to send power to coolant fan relays and cooling fans, when you turn on AC the cooling fans suppose to turn on to cool down AC CONDENSOR, IF NOT AC WONT WORK COOLING FAN COOLS DOWN REFRIGERANT SO IT CAN RECYCLE THROUGH THE SYSTEM AGAIN.your cooling is suppose to turn on when engine at a sit still if vechicle not moving as coolant temperature rises at a set point the cooling fans will turn on cool down engine.cooling fans dont turn on when you first cold stsrt vechicle unless you have AC SWITCH ON.if cooling fans dont turn on when vechicle at a long stand still or moving along slow traffic.if coolant temperature sensor been replaced and fuses and relays okay have dealership check see if pcm driver circuit working faulty pcm will cause cooling fans not to turn on.
Sep 27, 2012 | 1996 Buick Century
Fan comes on when switch ignition on instead of when hot Tazz
If the fan not turning on when car engine getting hot,then car will notice overheating.Click this link below for troubleshooting:---http://technoanswers.blogspot.in/2012/02/car-running-hot.html--------To know how engine cooling system works ,click the link below :----Engine cooling components working?
How does Vehicles Engine cooling system works? http://repairhelpcenter.blogspot.com/2011/11/how-does-vehicles-engine-cooling-system.html
------------How to Replace Engine cooling Fan:-- http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-engine-cooling-fan-on.html
-----------Replace Fan Relay but still Radiator cooling fans not working? http://schematicsdiagram.blogspot.com/2011/12/replace-fan-relay-but-still-radiator.html
----------DIC says "COOLING FAN FAULT"? http://schematicsdiagram.blogspot.com/2011/12/dic-says-cooling-fan-fault.html
---------Where Is Radiator Fan relay and Fuse Located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radiator-fan-relay-and-fuse.html
This will help.
Thanks.
Feb 09, 2012 | Cars & Trucks
My radiator fan is not working
For radiator replacement procedure and radiator problem troubleshooting. I suggest you to click the link below and follow the detailed procedure :-----
How to Replace Engine cooling Fan on car? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-engine-cooling-fan-on.html
Engine makes noise and Cooling Fan belt Breaks? http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Cooling fan relays location? http://technoanswers.blogspot.in/2012/02/cooling-fan-relays-location-on-1998.html----------DIC says "COOLING FAN FAULT"? http://schematicsdiagram.blogspot.com/2011/12/dic-says-cooling-fan-fault.html
How to replace radiator Cooling Fan?
cooling fan not working http://schematicsdiagram.blogspot.in/2012/02/hyundai-sonata-cooling-fan-not-working.html----------- Fuel pump relay and cooling fan relay troubleshooting? http://repairhelpcenter.blogspot.com/2011/10/fuel-pump-relay-and-cooling-fan-relay.html
Why Transmission fluid leaks near radiator?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
How to replace Radiator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-radiator-on-audi-and-vw.html
HOW TO REPLACE AN UPPER RADIATOR HOSE
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-upper-radiator-hose.html
HOW TO REPLACE A LOWER RADIATOR HOSE
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-lower-radiator-hose.html
How to replace Radiator on Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-radiator-on-acura-car.html
How to flush cars radiator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-flush-cars-radiator.html
HOW TO PRESSURE TEST A RADIATOR AND CAP
http://schematicsdiagram.blogspot.com/2011/07/how-to-pressure-test-radiator-and-cap.html
HOW TO REPLACE A RADIATOR
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-radiator.html
HOW TO REPLACE A RADIATOR SUPPORT
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-radiator-support.html
This details will help.
Thanks.
Feb 01, 2012 | 1997 Mercury Cougar XR7
The fan speed controller box is not working,that mean the radiator cooling fan is not working to .
does the fan work when connected directly to power? is there power present at the fan connector, what about at the fan speed controller?
Oct 31, 2009 | Gigabyte 3D Galaxy II CPU Water Cooling...
Kenmore 53532 / 53534 Side by Side Refrigerator Logo
835 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
