Question about Sanyo PDP-42H2W 42 in. HD-Ready Plasma Television
Tv wont turn on
I was playing my radio which is plug into the same strip as the tv and the radio just turded off, when i tured it back on , i also checked the power for the tv, and the tv would not turn on. both things were not playing at the same time
  • 1 more comment
  • slaughterbri Apr 23, 2010
    I pluged it into other outlrts in the house, using an extention cord and the problem still remains the same, it wont turn on
    still didnt work
  • slaughterbri Apr 24, 2010
    i plug it up in a differant outlet, but it wont come on. please help
  • 2,335 Answers
Have you tried running power to the TV through a different extension cord from a different power socket?
With any luck, the power strip you are using is just defective or had been damaged by a power surge, but that the TV has not been damaged in any way.
Plugging the TV in somewhere else will help you determine this.
Posted on Apr 23, 2010
HI NEED HELP? TV WONT TURN ON?
Unplug the power cord from your TV. Wait 30 seconds, then plug it back in. Plug the power cord into a different power outlet or power strip. If possible, try a different TV power cord.
Apr 13, 2017 | Televison & Video
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Oct 21, 2014 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
60' Sharp Aquos tv power bar flashing but TV wont turn on. Any help??
Good day!!!
please try to count the exact number of blinking lights to diagnose where the fault came from..
Also try to open the cover and look for any bulged capacitors on power supply board..
Dec 04, 2011 | Sharp LC60LE810UN 60 in. LCD TV
Can't turn my tv on. Have been away for ten days and now tv wont turn on with either remote or using on/off buttton on the side of tv.
The only suggestion I would have is to double check your power to the TV meaning if its plugged in completely in the back of tv to the wall, and if to a power strip that the power strip is turned on. If all the above are done but not recieving power to the power strip make sure the surge or safety wasnt tripped. If its not tripped and no power check your main fuses and the fuse in the power strip.
Feb 10, 2011 | LG Televison & Video
Tv turns on but has no picture
there might be a high voltage leak from the plyback.Open the back cover of your tv .turn it on and observe which part of the plyback has a leak..use a silicon adhesives to cure the leak..cover it heavy and complete..
tnx please rate my help.
Jun 04, 2010 | Samsung TXN3071WHF 30" TV
Tv shut off, and wont turn on. It flashes when you press the power button. NO clue at what is wrong.
is the tv on a power strip? unplug the tv from the power strip or wall outlet wait one minute then plug back into the wall outlet and not a power strip. TV should power back on.
Oct 12, 2009 | Sabre LCT371BKA LCD TV
Loud Music causes no picture
A solder must have fried out on the board. A red blinking power light indicates a fault somewhere. It wont let it turn back on to reduce further damage. If your good with a solder iron, take a looksie and search for a broken solder somewhere on the boards....dang! what were you jammin`? lol...
Mar 31, 2009 | Philips 55PW9363 55" Rear Projection...
Play tapes through TV
Sure - on the left side of the camera just below the tiny speaker, is a plug marked "audio/video" it's well hidden under the rubber strip and all you must do is just lift it up and there it is. A popular plug fits the hole and gives you audio and video out. Connect this to the audio and video plugs on your TV and set TV to "aux" and you in.
Radio shack and you dealers have a RF converter that you could plug into and has an output on chan 3/4 on your TV. Enjoy. I do.
Dan P
Jul 01, 2008 | Sharp Viewcam VL-AH151U Camcorder
Lcd tv
dos the porew light stay red or turn blue or not at all?
May 31, 2008 | Polaroid FLM-323B Television
Plug came out when on and now it wont go back on
HI there
Open up the unit and replace the fuse , should do the trick
Mar 28, 2008 | Radio Shack Cinego D-1000 Multimedia...
Sanyo PDP-42H2W 42 in. HD-Ready Plasma Television Logo
42 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
