Question about Canon PowerShot SD550 / IXUS 750 Digital Camera
My camera has stopped taking photos.
My camera turns on and the lens comes out, but when I push the button to take the photo it will not take the photo. Can you help? Seems like everything is working.
Thanks! Renea
  • ron dijcks May 11, 2010
    What model is it? Is your camera auto-focussing? If in an "auto" setting, the camera will usually not snap the pic, if the camera cannot "focus" your shot. Depending on which camera you have, it may be in a "mode" that will not allow the shot under certain circumstances.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 141 Answers
Please check your batteries. If they are rechargable it's possible they are losing their abilility to store electricity and if you use Alkaline then I'd advise switching to NIMH rechargeables or place a brand new set of High Output Alkalines in the camera.
Quite often low batteries can have enough power to switch on and light up but just don't have enough to fire or even charge the flash if it's switched on. Or to focus and take the picture. Batteries are the digital cameras biggest problem maker. It's the first thing I always go for because of this and also it's the cheapest repair if they are faulty. Even if you do use rechargables it's possible for one cell to suddenly die and that stops the other cells from doing their job. Obviously, in your case some power is getting through but check them anyway with a known good set.
If your fresh batteries don't do the trick then it looks like you will have to call into your local service agent. Obviously if your camera is under warranty it will be covered by the manufacturer and you can take it back to the place of purchase. Just remember to take you purchase receipt with you.
Good luck.
Posted on Apr 24, 2010
Stuck flash
There is a button on the left side of the camera with lighting bolt symbol push it at the same time helping the flash up. Keep the lens cap on when pushing the button.
May 07, 2013 | Nikon D3100 Digital Camera with 1855mm...
When I push the power button, "access" appears on
Hi, this is what we call a lens malfunction. Usually caused by debris getting into the lens such as
sand, etc... or the lens has suffered some kind of Jolt. The only lasting resolution is to
have the lens repaired or replaced.
Feb 01, 2011 | Sony Cyber-shot DSC-N2 Digital Camera
I turn the d100 on and push the button to take a photo and get a little "f" and two capital "EE" s and it wont depress. help have to take some photos at a rehersal in an hour.
What lens?
Remove the lens, clean the contacts, reattach the lens, and jiggle the lens to seat the contacts. See if that helps.
Aug 22, 2009 | Nikon Cameras
Camera does not go on
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 11, 2009 | Canon PowerShot A520 Digital Camera
Need to push out the lens a bit everytime i take a photo.
What you have is called Impact damage, there may not be physical visible damage, but you have internal damage to the camera. The alignment of the lens is now out of alignment. When you press on the lens, you are physically moving the gears inside of the lens. You need to stop doing this, you are causing more damage to it. You camera needs to be sent in for repairs at a repair center.
www.cameradr.com
He can fix it for you for a reasonable price.
Hope this can help you.
Nov 20, 2008 | Nikon D70s Digital Camera
Screen is black for photo taking
Not really a solution, but I think you have the same problem I do. I believe that the shutter is sticking. Mine will work for one shot every 3 or 5 power cycles (turn it off and on again)
Oct 16, 2008 | Olympus FE-210 Digital Camera
Taking photos
jeep111
be sure batteries are good. pull up on the rewind knob to open film door. load film ,push down rewind knob. pull enough film to connect to take-up spool. close film door. advance film to counter # 1. look through finder and set meter ( push shutter button to turn on meter ) focus subject and fire shutter repeat to end of film. push rewind button ( bottom of camera ) rewind film.
remove lens by pushing button and turn lens left to remove.
Apr 28, 2008 | Vivitar V3800N 35mm SLR Camera
Cybershot 3.2 seems to work fine until you push button to take photo
when i turn the camera on it says turn the power of and on again and the lens cover will not open
Nov 25, 2007 | Sony Cyber-Shot DSC-P52 Digital Camera
Olympus Stylus Powers itself off
the power on button is located under de lens slyding thing, therefore probably is broken or just need to be glued to do that u will need to open the camera. the other u will need to replace a small battery on the mainboard. good luck
Dec 04, 2006 | Olympus Stylus 410 / ? 410 Digital Camera
Canon PowerShot SD550 / IXUS 750 Digital Camera Logo
89 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
