Question about GE DBSR453EBWW Electric Dryer
Kenmore dryer not drying clothers
I have a Kenmore model#417.97042700 and it is not drying no heat . I vacumed the inside and removed build up and I have also removed the duct that connects to the dryer and the wall and cleaned that out. The dryer does sit on a pedelster. what can the problem be? and how can I fix this myself and save $$$.
    President:
  • 949 Answers
If it is running and not heating at all it is one of three things. I will list in order of possibility
- Power is not complete. The dryer needs 240 volts to heat and only 120 volts for the motor to run. Check the circuit breaker for one side being tripped by turning it off then back on again fully.
- Thermal cut off fuse, there is a temperature controlled fuse that usually trips when the air flow is restricted, usually a dirty vent. The cut off can be checked with an ohm meter
- Heat element, this can open up electrically and can be checked with an ohm meter.
Posted on Apr 24, 2010
The dryer heats up,it also goes through the entire cycle but the clothes are never thourly dryed.What could be the cause?
Typically it is because lent has built up in the vent tube. Here is a good site that shows you how you can do it yourself: http://www.wikihow.com/Clean-a-Clothes-Dryer-Vent
Sep 04, 2014 | Kenmore Dryers
1995 Kenmore Dryer heating issues
Sounds like a Heating element. Most towns have a do it you self appliance repair store. Contact them to price the part. Have you tryed vacuming th ling from the inside of the unit. Sometimes they get loaded with lint and does not heat efficiently. Hope this Helps.
Jun 21, 2013 | Dryers
I have a Kenmore Dryer (Model 970-C87022-00), there is heat, however it does not dry the clothes. They actually feel wetter.
The most typical reason a dryer will heat yet not dry the clothes is going a blocked.restricted or crushed vent. Check the venting from the back of the dryer all the way outside and make sure its blowing good air pressure all the way through it,Also check inside of the dryer at the housing where the blower wheel is for lint build up.
GENE
Sep 18, 2011 | Dryers
It takes 2 or 3 cycles to dry one load of clothers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 23, 2010 | Kenmore 60172 Electric Commercial Dryer
My Kenmore Elite dryer works except there is no heat to dry.I am looking for suggestions to repair. Thanks
There is a moister sensor in your dryer that detects any lint build up inside the exhaust vents. If any obstruction is inside the exhaust tubes this sensor will put the heat in the check mode. Inspect and clean thoroughly and see if it will heat up again
Aug 03, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
We have to hold the start button down when for
if you have to hold down the start button to keep it running then the motor is shot-mike
Jan 29, 2010 | Kenmore 63952 Electric Dryer
Sears Kenmore elite quietheat front loading dryer not drying. Moisture builds up on the window inside.
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
May 28, 2009 | Kenmore 64902 Electric Dryer
Kenmore Dryer Model 110.888029 Serial MH1102412 Type 180.00
MOST LIKELY PROBLEM IS A RESTRICTION IN THE EXHAUST. DISCONNECT THE VENT FROM THE BACK OF THE DRYER AND TRY DRYING ONE LOAD. IF IT DRIES O.K.,
THERE IS A RESTRICTION IN THE EXHAUST. CLEAN THE LINT OUT FROM THE ENTIRE LENGTH OF DUCT WORK.
Apr 08, 2008 | Kenmore 63942 Dryer
Dryer won't dry
There are three possible parts that can cause this.
1. Thermal fuse
2. Thermostat
3. Flame sensor
https://www.repairclinic.com/Shop-For-Parts/a8b6d600503/Model-11072212100-Kenmore-Dryer-Parts
You can check the first two with a meter to see if they are ok. If they are then you should replace the flame sensor.
Mar 25, 2017 | Dryers
GE DBSR453EBWW Electric Dryer Logo
109 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
