Question about Tecnik TKL9260 Front Load Washer
Washer cycle worked. When reached spin cycle it stopped. When I manually put the washer dial on spin cycle, I heard a clicking noise coming from the area of the dial. Water would not spin out.
IFIXALL
  • 868 Answers
SOURCE: whirlpool washer intermintent drain problem
Replace the main control board
Posted on May 25, 2008
JULIANFIX
  • 975 Answers
SOURCE: My washer wouldn't drain or spin. It just humms
OK ! TRY this , located the DRAIN MOTOR PUMP , usually where the drain hose is connected , remove it , check for any debri or lint clogging the PUMP , replace and try again, hope it helps , AJ
Posted on Sep 23, 2009
  • 115 Answers
SOURCE: my washer wouldn't drain the water
pump bad replace
Posted on Nov 04, 2009
SOURCE: washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Posted on Nov 24, 2009
  • 353 Answers
SOURCE: Think I have a clog somewhere. Washing machine
Clean the filter
Posted on Jun 11, 2010
Washer making whining noise rinse cycle
Possibly a worn drive belt, or it needs tensioning.
Jan 06, 2018 | Whirlpool Ultimate Care II LSQ9549L Top...
11 year old Kenmore washer fills then stops.
in the machine under the front control panel will be a module that controls the wash agitation. Have it checked out as they fail . There is no connection between the timer and this unit as it comes in to play when the water reaches a set level. The timer just keeps working through the cycles believing the washer is agitating.
Jun 26, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
What does E27 on display mean
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Mar 10, 2011 | Bosch Washing Machines
My Maytag Neptune FAV6800AW top load washer only runs for the first few minutes of the cycle, it will not spin..it just stops..we've tried two cycles, the quick wash...it starts at 33 mins and then stops...
I'm and owner and will try to help. Are you handy and do you want to try a DIY fix?
From the wash times is sounds like the washer is agitating the wash load (tumblers are rotating the wash basket load) is that correct?
If so see if the machine will complete a Spin Only cycle with no clothes in the wash basket. Set the Spin setting to Spin/Hang dry seting and start the cycle. It should take about 10 min complete. Does the Spin Only cycle complete with no clothes in the wash basket?
Some handy links if you are going to DIY.........Service Manual for reference.
Sep 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Power surge - washing machine Not turning on.
Instructions Things You'll Need:
  • GE/ lg washer
    Primary Method---Newer models
  1. Step 1 Unplug the washer.
  2. Step 2 Twist the control dial around the cycle settings.
  3. Step 3 Place the dial on any setting other than the final spin.
  4. Step 4 Ensure that the water line is securely attached to the washer.
  5. Step 5 Plug the washer back into the wall (making sure it has gone at least 30 seconds without power).
  6. Alternate Method---Older Machines
  7. Step 1 Turn the dial around the cycle settings, but do not lift it to start the cycle.
  8. Step 2 Unplug the washer.
  9. Step 3 Plug the washer into the wall after 30 seconds without power.
  10. Step 4 Lift the washer lid five times, making sure it reaches a height of at least 6 inches or more. There should be no more than a 15-second interval between lifts.
  11. Step 5 Listen for a clicking noise. If a click is not heard, repeat steps 1 to 5 until you hear it.
  12. Step 6 Place a small load of laundry into the washer and start the cycle.
  13. Step 7 Watch the load throughout the wash to ensure the washer is working properly.
Dec 26, 2009 | LG Washing Machines
Wash doesn't go through full cycle
I have a Maytag model A490 clothes washer. It works fine up to the rinse cycle and then shuts down. When it reaches this point it has become necessary to manually advance the dial a short ways whereupon it will fill with water and complete the rinse and spin cycles. This happens on both the regular and the permanent press cycles. What needs to be done to fix this problem?
Jul 14, 2009 | Maytag Washing Machines
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Water does not drain, clicking noise heard no spin cycle
REMOVE DEBRIS FROM PUMP LOCATED INSIDE WASHER ,, REMOVE 2 SCREWS HOLDING BOTTOM PANEL,, PUMP IS PLASTIC TURN COUNTER CLOCK WISE AND REMOVE DEBRIS,, BE CAREFULL HAVE ALOT OF TOWLES STILL HOLD 3 GALLONS OF WATER
Nov 22, 2008 | Kenmore 43142 Front Load Washer
Tecnik TKL9260 Front Load Washer Logo
124 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
