Question about Canon PIXMA MP620 All-In-One InkJet Printer
Color pictures have streaks--think it has to do with magenta cart
Brand new magenta cartridge, but does not seem to want to print. Everything else prints great. Black prints perfectly, black with one other color ie: green or blue is fine. Red comes out orange. A pict or illustration that uses many colors is badly streaked, seems to be the magenta. I love my Canon, worried that the print head might be damaged. A new print head costs as much as the printer! Cleaned it numerous times, tried realigned it as well, nothing works. Can anybody help?
myob247
  • 1342 Answers
SOURCE: Canon Multipass F50 printing streaks
Clean the glass in the scanner bed.
Posted on May 03, 2008
SOURCE: Printer will not use the magenta color
I had the same problem. It is most likely that your print head nozzles are clogged. Your choices are to attempt to manually clean them, or order a new print head from Canon.
Attempt the manual cleaning at your own risk, this doesn't always work. When it does not work, it means your print head is damaged.
To maually clean the print head. Printer cover up (so you can get to the cartridges and print head). Turn the Printer Off. Remove all the cartridges (I put each cartridge in a separate zip lock bag). Then flip up the lever and remove the print head.
Now heat (don't boil) distilled water (Iused a good sized cook pan and a plastic measuring cup to pour the water). Find a container you can soak the print head in (I used a deep alluminum baking pan). Pour the hot (not boiling) distilled water over the print head molding where the cartridges seat down (hold the printhead over your diposable alluminum pan). Then dunk the molded print head part into the pan numerous times. When the water gets dark change it (be carefuill not to stain the sink). Then slowly pour the hot distilled over the print head (opposite side from where the cartidges seat in). Eventually no ink will be in the water. Set the print head on a dry paper towel, and let it dry for 24 hours or longer. Reinstall the print head, then the catridges. If it worked, your true colors will return. It make take up to 15-20 photos to get all the ink catridges flowing-be patient. You can also just wait 24 hours after re-installing the cartridges, and hopefully it will take less photos to see the correct color match.
Never keep printing when a cartridge is low or out.
Print a few prints every week. Not printing for weeks causes the printheead and the ink flow to clog!
Good luck. I just recovered my S820 and my i900D using the above cleaning method. Like everything else, your mileage may vary! It cost me $1.29 for distilled water and about an hours worth of time!
Posted on Oct 20, 2008
exil0r
  • 118 Answers
SOURCE: black text has white streaks
You have to clean the nozzle with cartridge cleaner liquid
Posted on Mar 26, 2009
  • 240 Answers
SOURCE: Nozzle Still Clogged After Following Maintenance Procedures
just wipe the nozzles or the printhead .on a wet cloth...using DI(deionize water) to remove the clogs that cover nozzles...and then deep clean the printhead using the printer panel features...
good luck..
Posted on May 26, 2009
yboyandrei
  • 828 Answers
SOURCE: Magenta Ink Streaking
that printer color cartridge is a problem... buy a new one.... color ink
Posted on Jun 16, 2009
Replaced T0603 magenta ink with brand new cartridge. Ink levels show its FULL. But when do nozzle print check, no magenta line will print. Trying to pring something with red clip art and can't get the...
Depending on when you last used your printer it may take a few head cleans before the ink prints. Print a nozzle check after each clean (uses minimal ink).
Also be aware each clean depletes your other carts as well.
Jan 09, 2011 | Epson Stylus C88 InkJet Photo Printer
My printer is won't print either of the magenta colors, so all my pictures are coming out in this greenish yellow hue. I have done everything I can think of including cleaning the print heads, checking...
Unfortunately, printers seem to have a short life to them.
We had to replace ours and buy new ink cartridges because
they make it to where you have to buy a different cartridge number for the same brand of printer.
How old is the printer? Base your decision on whether to replace it or not. If it is old, the best thing would be to replace it.
May 12, 2017 | HP Photosmart 3210 Printer
The lt magenta and magenta just quit printing between pages
1. Check if the cartriges are correctly installed:
Installing the Ink Cartridges
2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
Color Mix or Missing Colors on the Diagnostic Page
Repeat if needed.
3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
LED Head Missing, Color:Magenta
Take out the magenta cartridge to the right upper indside wall of the printer you should be able to see a small rectangular window, give it a blow of wipe with a cloth, do the same to the corresponding part of the m toner, put the drum and toner back, shut the lid and everything should be ok. If not contact oki for a replacement drum/cart.
Mar 23, 2009 | Office Equipment & Supplies
Epson C66 problem
Without the benefit of a response from any of rickyostrom, liusgarciaca, or hotdog233311, I think we can say the problem lies with the fact that your magenta cartridge isn't printing. You can confirm this by carrying out a nozzle check print.
If any of you would like further assistance in restoring your magenta to working condition, please do a new post to this effect.
Oct 29, 2008 | Epson Stylus C66 InkJet Photo Printer
Every page covered in magenta and black won't print across the page
This is caused by toner contamination in the laser scanner unit, it is quite a complex job removing and cleaning the laser scanner. I would suggest you contact HP regarding the repair.
Sep 04, 2008 | HP Color LaserJet 2600n Printer
Just changed both magenta and yellow toner cartridge on my color lazer. When I print the page comes out covered in blue, magenta and yellow streaks. i have re-installed everything and cleaned everything...
is that a new toner? or a refilled one?
its hard for you to ressolved the issue because you need to open all the cover in order to clean all the necessary mess.
try to send your printer to a repair center.
Aug 28, 2008 | Office Equipment & Supplies
Streaks when printing colored copies. I have replaced the cartridges twice.
if its only copies then glean the scanner glass. otherwise disregard this post.
Jul 21, 2008 | Lexmark X83 All-In-One InkJet Printer
First, wouldn't print black, now won't print magenta- all new cartridges!
Unplug machinepowercord. Open printer and take all carts out. Plug in power. Machine demands carts. Put new one in: Replace with original ink carts!. When asked push 1 (yes New cart). If you have used thirdparty carts, there could be a prob due to construticon or ink quality. In case there is no bk after 3x cleaning cycles anymore, the head is clogged: This happens because the filter in front of the nozzels is clogged by pigmented ink. DO USE ONLY DYE INK for all types of brother inkjet machines!!!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
My Canon i960 printer is printing red streaks on the pages
It's possible that the heads need to be replaced. That's one disadvantage to the printers that don't have the heads contained within the cartridge.
Feb 26, 2007 | Canon I960 InkJet Photo Printer
Canon PIXMA MP620 All-In-One InkJet Printer Logo
51 people viewed this question
old marine
old marine
