Question about Polaroid FLM-3232 Television
All the black colors are bright fuzzy green-polaroid flat screen
All the black colors on the polaroid flat screen are bright green fuzzy colored.... no amount of color adjusting fixes this....why?
  • hjoseph1968 Apr 23, 2010
    is it worth repairing this problem? what causes this problem? how much will it cost to repair?
  • hjoseph1968 May 02, 2010
    What causes this? Is it from having an xbox hooked to the tv?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you might have a backlight and/or an inverter board issue with this TV set. It could also be due to the inverter circuits for the backlights. The inverter is the power supply source for the backlights. There could also be a screen driver problem; if it is then you have to change the entire inverter board. All this is only recommended if you have some kind of expertise for checking the internal circuitry of the TV as these units have high voltages running even when the set is switched off. The cost to change the inverter board including labor would be around $250, if you get this done by a professional. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Apr 24, 2010
    President:
  • 1,768 Answers
You have a ma inboard that needs service.
the LCD controller IC is malfunctioning along with some other components surrounding it . check the power supplying this portion of the board also also. Your TV will need service.
Posted on Apr 23, 2010
Green screen upon shutting down or green color replacing black .. Fuzzy green on some dark scenes.. Sharp Aquos LCD TV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 29, 2015 | Sharp Televison & Video
My sceptre lcd tv is displaying really bright pink and green colors
I had a similar problem with blacks showing up as green. Turning up the brightness a bit fixed it for me. Not a permanent fix, but something to try if you want to make it last a bit longer until you can get a new one or fix it.
Mar 24, 2012 | Sceptre X32BV-Naga 32 in. LCD TV
Color and picture is distorted. Colors are predominately bright green, yellow and pink. Sometimes color will clear but picture is still fuzzy.
Hi
Please post a comment with the manufacturers name and model no# of the unit so that I can assist you further.
Thanks
Rylee
Sep 21, 2010 | Insignia Televison & Video
42" Polaroid LCD loses most colors
Try replacing your lcd controller. It's the board that actually makes the screen display the picture. Usually you will see the colors getting a little screwy and then the longer you have the tv on the hotter it gets and the worse it gets. I had one that started to look silvery then got worse as it got warmer. For lack of better ways to describe it, it was like you were watching tv on a crazy acid trip. Once you change the controller it should be ok. If that doesn't work 99% chance it's a bad lcd panel. I've seen about 6 of those all with similar issues as you have, they were all brand new tv's and all Sharp Aquos.
Aug 06, 2009 | Polaroid FLM-2632 Television
LCD screen has black and red colrs + a green vertical line
Reset the video card, and if that doesn't work it sounds like the card is dying. How old is the card?
Apr 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Green tint and psychedelic color swirls in picture
I have a good but with green tint on a polaroid tv model number 64SX505Y-DC02
Dec 28, 2008 | Polaroid FLM-3232 Television
Vertical lines, colors not sharp, graphics fuzzy
could be the vga car4d problem, try to hook up with another pc if the problem remains then unfortunately the monitor is dying.
Jan 06, 2008 | Envision EN-7100e 17" Flat Panel LCD...
The color is all off, no red, the green is too much it does not look right
Which inputs are you using? If your using the composite inputs the cables may be switched.
Aug 18, 2007 | Polaroid FLM-4234BH 42 in. LCD HDTV
Polaroid FLM-3232 Television Logo
125 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
