Question about Samsung Televison & Video
Samsung TV (Model number TXT2793HX/XAA) blinking remote
My Samsung TV (Model number TXT2793HX/XAA) has started acting odd over the past week... often times the "TV" button on the remote flashes rapidly, like a blinking orange light. The red LED on the front of the TV blinks rapidly, too. When this happens (which is often), I nothing I push on the remote does anything. I thought maybe it meant the batteries were low, but I replaced them (in the remote) and it's still doing it.
Benimur
  • 6966 Answers
SOURCE: Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
Hi, If all else fails, try do a hard reset. You can verify from your manual, but in some units, this is merely unplugging the unit from mains for a couple of hours. Try again, if it still shows error codes (blinking lights) you probably have to seek the services of a qualified professional. Hope this be of some help/idea. Good luck and kind regards.
Posted on Aug 26, 2007
SOURCE: Power indicator light blinks orange times
sounds like the lamp faceplate is not screwed back in properly
Posted on Aug 06, 2008
SOURCE: Kenmore front load washer won't start. Lights just blink
I had same problem........push options and select button at same time, hold for 5 sec.......choose option.....machine stuck inbetween cycles.
at least it worked for me!
Posted on Aug 13, 2008
SOURCE: Samsung ltm1555B - lcd tv blinking on button
I am having the same problem with the blinking orange light
Posted on Aug 31, 2008
djchillsnyc
  • 152 Answers
SOURCE: The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Posted on Dec 14, 2008
MY TV STARTS EMITTING A BUZZING SOUND AFTER IT'S BEEN ON AN HOUR OR SO. It is a Samsung DLP model HLP5063WX/XAA.
Its likely to be the color wheel which when fails can do several things: A high pitched whine or what is often described as a fan like sound.
Since the set monitors the speed of the wheel if it slows down even a little image may look odd or dark.
you can at worst hear a grinding sound and it means segments in the wheel are shattered or missing
Good news is it is readily available and many average people can replace it---you tube even has video instructions for most of the Samsung models for this.
Only two models were made and Google the model number with Color wheel to locate the one your set uses.
Dec 22, 2012 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung dlp
If you have have 40 vertical lines 16 pixels wide: DDP1011 or BCA, DMD panel interference: Replace the DMD board.
Jul 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Missing manual
Here is a link to the users manual for your television.
Samsung TXT2793HX XAA Manual
Good luck.
Semper Fi,
Z
Feb 20, 2018 | Samsung Televison & Video
Have a 50 inch samsung projection tv model hlt5075sx/xaa lamp code bp9601653ap132w turn tv on lamp stays on for approx 20 seconds then 3 blinking lights on right bottom side start blinking if it is the...
The blinking lights will be flashing a code.....
Can you please indicate the sequence of the flashing lights, as this will determine what needs to be done to fix your fault.
Cheers,
Jun 16, 2011 | Samsung - Projection TV replacement lamp...
Model Number HLT5676SX/XAA 56" Samsung
your question does not help us or you as we do not know your problem .
Jun 09, 2017 | Samsung DLP HL-P5663W 56" TV
I have a samsung model hlr4667wx/xaa picture freezes
analog board can cause that symptom especially if the pic is freezing .
Jun 26, 2010 | Televison & Video
I have a samsung HLS4266WX/XAA about 3 years old with white dots.
This is a known issue with Samsung DLP sets. Here's a link to the solution:
http://forums.cnet.com/5208-13973_102-0.html?messageID=3162774&tag=emfrnd#3162774
Jan 01, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung HLS4266WX/XAA warnings w/ new lamp also
You may be in need a new ballast, the assembly that excites the bulb into producing output.
Sep 20, 2017 | Samsung Televison & Video
SAMSUNG 15inch LCD TV
Debra,
Don't bother... You've got a busted backlight inverter. Need to replaced a new one or repaired it.
Sep 28, 2008 | Samsung SyncMaster 910MP 19" LCD Monitor
Televison & Video Logo
349 people viewed this question
Jerry Greenberg
Jerry Greenberg
