Question about RCA HD61LPW165 61" Projection HDTV
I have a 2005 rca dlp hd61lpw42 tv that has started to make an awefull whinning sound could it be the fan or color wheel, some days it doesnt do it at all some days its mind numbing jim
  • 1 more comment
  • draglinetras Apr 23, 2010
    how exactly is the easiest way to get to the color wheel? jim
    this helped a bunch knowing what to look for
    thanks a bunch ill get on line and find a manuel JIM
  • RCA Master
  • 3,866 Answers
That would be the color wheel as if it was the fan it would have stopped by now. So yes check the color wheel by all means, let me know what you find, please do click the accept button for my efforts, thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 23, 2010
  • Grand Canyon Tech
    Grand Canyon Tech Apr 23, 2010
    first of all not easy and not really to exact I would council you if your going to do this job yourself is to get a service manual. they run around $20-30 bucks this will help you exactly take out the color wheel for replacement. Step by step over email is to complex.
Screen fade in and out, then picture scrambles when the fan turns off, the fan makes a really loud noise when starting.
sounds more like a color wheel issue rather than a fan. Can you verify where the sound is coming from?
Jul 20, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
My HD61LPW42 makes a high pitched wirring noise after it is on a few seconds sounds like the fan is rubbing against something but doesn't appear to be. The picture quality is still good and the tv...
this might be a noisy color wheel . this is a motorized wheel that produces the color in the set. it could be something else because of your statement of picture is ok. if it the color wheel the set will eventally shut down. this part used to be avalible and fairly easy to replace. it has got harder to locate. The other possibilites includes a small leaky capacitor in the powers supply but that is more like a whine. a tech would have to take the back off and locate the noise.. i believe this unit might have 2 fans and a color wheel. three moving motors.. anything that moves eventally dosnt
Mar 22, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
My rca hd61lpw42 is having trouble. there is the loud whirring noise, and the whites on the show i was watching distorted and then the screen turned off. is the issue with the color wheel or the lamp?
it sounds like the lamp or fan. do you feel airflow? Unplug the set and wait. When you plug it up is the whinning imedate. the color wheel generally is the first thing to come on. If it dosent reach speed it will shut down
Oct 31, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
I have an RCA Scenium DLP 50 TV. The TV started making a loud noise (like a computer fan) going out. The noise would go away when we powered off the unit and the bulb shut off. Eventually there was no...
yes ... you could have a color wheel problem.. this set get color from a spinning wheel called a color wheel.. when you unplug this and plug this back in you should hear a whining motor sound. During the "bootup" sequence this motor spins this wheel to test to see if it reaches speed. This is a motor that moves and anything that moves eventally dos not. i see this problem often in the shop and if it is the problem there not all that difficult repair. the hardest part is finding the color wheel
Oct 18, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
Cant find convergence on menu screen
The HD61LPW42 is a RCA DLP which doesnt have convergence. If the convergence is out of alignment you have a three CRT TV such as the D52W19, HD52W59 RCA Check the model number from the rear tag and let me know what the model number is.
Nov 21, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Loud whinning, high pitch noise coming from TV when turned on.
The color wheel is likely bad and needs to be replaced.
Check this link it is for a samsung TV but the same principals apply
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Oct 17, 2009 | RCA R52WM24 52" HDTV Projection Television
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
RCA DLP TV needs color wheel replaced
I used the internet and found others who had the same problem. Two individuals had a brief description on how to replace the color wheel in a DLP TV. Three small torque screws and a ribbon connector was all that was need for removal; once the access panel on the back was opened. I would guess that this process is the same for all DLP TV's, with some small variations!
Nov 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA model #HD50LPW62AYX2 hdtv/dlp rear-projection set. The picture went out, and we thought it might be the bulb, so replaced it. The picture still will not come on, and there is a loud...
The color wheel can make a whinning sound for sure, However it should not continue to whine after shutting it off. That sounds more like the fan used to cool the lamp, as that will continue to run after the set is shut off. How soon does the whinning start when you push power? Let me know I should be able to help you out. DLPs are my specialty
Mar 26, 2008 | Televison & Video
Rca scenium 61 inch dlp
the unit has a bad color wheel,a big pain in the ass to change.the part runs about 175.00 labor is about 200.Try first to get the manufacture to fix unit,be persistant
Mar 20, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW165 61" Projection HDTV Logo
75 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
