Question about Amana ARB1917CSR Bottom Freezer Refrigerator
Amana ARB1917CB bottom freezer refrigerator, not freezing at all has done this before but have always manage to get it working again top & bottom up as high as it can go, but the top doesnt feel that cold at all freezer hasn't started working again yet. Cleaned coils, just waiting...
    Scholar:
  • 126 Answers
YOUR COMPRESSOR MAY HAVE FAILED. USUALLY ABOUT 800 TO REPAIR. THERE MAYBE A FIVE YEAR FULL WARRANTY ON THAT. OR EVEN A 10 PART ONLY WARRANTY. CHECK MODEL AND SERIAL NUMBER HERE TO SEE. http://servicematters.com/warranty/warranty_main.htm
Posted on Apr 24, 2010
Testimonial: "Thank you, you were right on,the repairman told me that the bottom freezer models work harder & don't last as long as a top model. Thanks again. "
Do all refrigerators have the problem of food freezing in certain spots?
its most likley the refrigerator you have now (kenmore) is a Amana. They were one of the few that made bottom freezers. Sears makes nothing they contract and have the kenmore name put on it. From what I see there are certain issues with all freezer bottom refrigerators. The most common is the top is not cold enough at times. some units like the LG have a frost problem in the freezer and thats due to air getting in there some way. With refrigerators they all have some kind of small issue that may hapen to them. and thats not saying there bad. Most is due to them being made more efficent and having more and more electromics and features that customers want. so its not what brand is better then the next its what you want in a fridge and how much your willing to pay. I feel the thing that makes one better over the other is how the manufacturer backs there product. Hope it helped you out
Aug 06, 2007 | Amana ABB1921DE Bottom Freezer...
I have an amana bottom freezer/refrigerator model ABB2522FEQ. the bottom freezer works great, but the coils have frozen two times. I thawed coils out again and it only lasted 2 weeks, eventhough the fan...
HI,IF THE FREEZER IS BUILDING ICE ON EVAP COVER THAT IS NOT DEFROSTING PROPERLY,REPLACED THE CONTROL BOARD AND DEFROST B-METAL TO REPAIRD THE PROBLEM..
Jul 04, 2011 | Amana ABB2524DE Bottom Freezer...
Fridge & freezer work fine but there is water running out from under it. no ice maker on this model.
the freezer has a defrost timer on the evaporator coil to keep it from freezing up and restricting the air flow to the box. It may simply be going into defrost mode to often and filling up the condensate pan. The adjustment on the timer is internal near the rear and should be done by a servvice tech
Nov 26, 2009 | Amana ABB1927DE Bottom Freezer...
I have a amana bottom freezer refrigerator that is cooling the top section
i think you mean its not freezing at the top? if this is so, sounds like you have a gas leak, you cannot fix this yourself unfortunately you may require a technician to fix the leak and top up your gas.. make sure they fix the leak or this will happen again. hope i have helped
Nov 11, 2009 | Amana ARB2257CSL Bottom Freezer...
The freezer on my Amana ARB1917CB keeps frosting over; the fridge no longer cools. The advice given on most forums for this siutation is to "test the defrost timer by turning the screw with a screwdriver,"...
Exploded parts diagram for your fridge:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5167592
I understand your frustration. Below are some diagrams and troublshooting aids. If you look at the exploded parts diagram link and select the Wiring Information page, you'll see the defrost timer is on the FF harness, which is the "Fresh Food" compartment.
Next, click in the "Controls" page. Item #12 is the defrost timer. It looks like it is in light assembly / cover in the fresh food compartment as it has 2 light bulbs shown - and the freezer has only 1.
Generic service manual for Amana bottom mount freezer / fridges:
http://www.servicematters.com/maytag_library/docs/S120_0R0.pdf
http://www.servicematters.com/maytag_library/docs/T120_0R0.pdf
I hope this helps!
Jun 24, 2009 | Amana ARB1917CSR Bottom Freezer...
Amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
May 25, 2009 | Amana ABB1927DE Bottom Freezer...
Amana BX20RW Refrigerator slightly warm freezer not freezing
Check the thermostat, to make sure that it is working properly. The theremostat is a long wire in the top of the freezer up near the fan. If that is bad it will not let your freezer cool correctly
Feb 08, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana Refrigerator
Is fan in freezer running? If not it is bad and needs replacing. Please leave feedback.
Nov 27, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana ARB1917CSR Bottom Freezer Refrigerator Logo
414 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
