Question about Poulan Garden
I have a Poulan weedeater 14.5 h 42 inch cut rider. What kind of oil and how much to change it ?model # 733-864 MFG Id. HD1 45h42h se # 032698a005854 .
5 Suggested Answers
  • 218 Answers
SOURCE: Looking for Manual fro Poulan WEEDEATER model
They may have one on www.2instructions.com ..it wouldnt hurt to check..i hope this has helped...Keith
Posted on Jul 01, 2009
SOURCE: I have a 12 year old Poulan/Weedeater riding lawn
American Yard Products (AYP) is the manufacturer and the part number is: 142829 the part the part description shows sub= 145775.
Posted on Oct 14, 2010
  • 3074 Answers
SOURCE: Have and older style Poulan rider mower with a
disconnect the starter and turn the ignition to see if the fuse blows, if it does not then the starter is grounded, but more then likely there is a stripped/bare wire grounding out somewhere. Hope this helped Tim
Posted on Jun 05, 2011
SOURCE: Poulan Lawn Tractor 42" 14.5 hp Model 733-864 How ...
I need the diagram for a drive belt for a 42'' lawn tractor - 14.5 hp Can ANY ONE help me?
Posted on Jul 14, 2011
Tip
Easy way to install fuel line and primer bulb return line into gas tank
Chainsaw fuel lines enter the gas tank from holes in top of tank. They are sized for a tight fit to prevent leakage. Make it easy on yourself when pushing the line through the tank by cutting a long lengthwise taper cut with razor knife 3 inches or longer to easily feed through that tight hole. Once started you will then have to grab it through the gas cap hole with needle nose pliers, then cut the tapered end flush and add fuel filter. Readjust inside length by pulling from above, then cut to length to upper carb fitting. If connecting to primer bulb a filter is not required and make sure the line goes to fitting on primer bulb marked tank.
on Nov 17, 2015 | Fuel Line & Primer Bulb Repair Kits 2...
What kind of oil should be used with this chainsaw?
Pick up some bar and chain oil. Usually comes in a little container, but I have found it in one quart bottles also. Poulan puts there name on a bottle of the stuff and the bottle is that funny poulan green color. I guess that makes it easier to spot.
Aug 11, 2011 | Remington 16-Inch Bar, 2.5-AMP Motor,...
Have and older style Poulan rider mower with a 14.5 hp and 42 inch cut. Replaced Battery, starter selenoid, and ignition switch. Now the 30 amp fuse keeps blowing, how come?
Jun 05, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Identifying the engine used in a Poulan PO16542 mower
I suggest removing the carb and taking it to an authorized B&S repair shop, they will be able to I.D. it.
Apr 26, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have poulan/weedeater leaf blower
ignition coil,or blown head gasket...
Nov 08, 2009 | Poulan Garden
I need an owners manual for model #bc3100
Go to... http://www.weedeater.com/poulanpro/indexAction.do?id=default Scroll down to Download Manuals on the right, then enter your model number. There you have the owners manual and parts manual.
Jun 25, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
175 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
