Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
HE error My LG LD-14aw1 is showing HE error code - Heater Circuit is troubled???. (Not as much as owner!!!). I have repaired several dry solder joints in the control module, which have been causing various operating failures, but the HE problem has got me stumped. Can anyone provide me with a wiring diagram of the machine and or the control module? I'd like to trace the heater circuit to see if I can find the fault. Many thanks
  • annelevonis Jun 23, 2008
    i have model ld14aw2 jast had new motor installed perished seal motor completely rusted now shows he code fed up out of warranty is it worth fixing
  • john418 Feb 22, 2009
    I have the same error message on a LD 14AW1.
    I am assuming it is something to do with the heating element as I have no hot water
    Problem Solver:
  • 9 Answers
From the manual: Errors: HE: Heater circuit failure.
Please call your Authorized Service Center or LGE
Customer Service at
1-800-243-0000(US), 1-888-542-2623(Canada).
Posted on Jan 09, 2010
Dishwasher has an HE error code?
"HE" is a "HEATER ERROR"
These are the possible causes for "HE" error:
1. The Circuit of Heater is troubled.
2. The Thermistor is troubled.
3. The Heater is shorted.
4. The Relay Circuit is troubled.
The Possible solutions are:
1. Repair the Circuit of Heater.
2.Replace the Thermistor.
3. Replace the Heater.
4. Repair the Relay Circuit..
Thank you !!
Aug 04, 2010 | LG Dishwashers
LG DWLD4080T dishwasher shows HE error message after 10 mins What is the problem?
Apr 01, 2010 | LG 24 in. LD-12BW5 Free-standing...
HE error on LG dishwasher
HE is a HEATER ERROR
Possible causes
¥ The Circuit of Heater is troubled.
¥ The Thermistor is troubled.
¥ The Heater is shorted.
¥ The Relay Circuit is troubled.
Possible solutions
¥ Repair the Circuit of Heater.
¥ Replace the Thermistor.
¥ Replace the Heater.
¥ Repair the Relay Circuit..
Jul 12, 2009 | LG 24 in. LD-12BW5 Free-standing...
I have a lg dishwasher ld-14aw1over flow
On an LG LD-14AW1, three is a float sensor on the left hand side of the dishwasher, behing the water outlet port.
It is the sensor that tells the dishwasher to stop filling just before the wash or rinse cycle begins.
A service call is needed or post back here is you want help replacing it.
Apr 09, 2009 | LG 24 in. LD-12BW5 Free-standing...
I have LG dishwasher model LD 14AW1 I get error the message HE about 15 minutes into the wash cycle then the dishwasher turns its self off
HE refers to HEATER ERROR
The water is not heated
or the temperature in
the Tub is overheated
to over 95¡
Possible causes
Possible solutions
Feb 22, 2009 | LG 24 in. LD-12BW5 Free-standing...
LG Dishwasher LD-2050WH with HE error code
This is a heater error. The cause is either a bad heating element or bad thermistor (the thermistor is part of the heater assembly). The heater assembly will need to be replaced.
Jan 14, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwasher not drying - Bosch Integra SHU9952
Bosch generally drys through evaporation from hot water rinse. There is a common circuit board issue where a cold solder joint on the heater relay pops.The water does not heat sufficient to evaporate any longer. Consult your manual for self diagnosing trouble shooting codes or go to appliance aid.com.
If the board connection is the issue I have repaired several, however Bosch recommends replacement only and sometimes supplies the parts free.
Aug 14, 2008 | Bosch SHU5315UC Dishwasher
Dishlex DX302SB Dishwasher water not heating, have changed the heating element without any success.
Who posted this comment I am really appreciative. I have had the same problem with my dishlex. I disassembled the plumbing and removed a chunk of plastic wrapping from inside the pump. Then I checked the heater with a multimeter. It measured fine.
The next day I read this post and have since removed the controller. I found the burnt solder joint mentioned. I have since cleaned up the mess, repaired the circuit board, re-soldered the effected component and the dishwasher is now working better than ever.
I have read elsewhere that this problem arises when the door is opened while the heater is on and the program hasn't been paused. I don't know if that is the exact cause but in my house we will be more careful about that from now on.
The damage to the circuit board was on the Normally Open terminal of the relay used to control the heater. The heater is marked as being about 2100 watts. The relay is marked as being able to switch 125Vac. Which is interesting because power here in Australia is 240Vac. At 240Vac the heater will draw a little under 10 amps when operating.
Anyway the circuit board trace is possibly a little narrow at the point where the burnt connection was and I can see why it would have burnt out. The other terminals on the relay were showing signs of becoming dry joints too. The repair was effected by completely removing the relay, cleaning all the joints, re-soldering the relay and laying a loop of tinned solid wire around the burnt terminal to replace the missing piece of circuit trace.
Anyone who has a little skill with a soldering iron could perform this repair. The worst that could happen is you could lift what is left of the circuit trace from the board. Since the controller is already broken you can have a go and probably save yourself the cost of a new controller.
Jul 23, 2008 | Dishwashers
Error
The ?OE? indicates drainage trouble. It could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Sep 16, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
LD-14AW1 keeps coming up with OE error code
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Oct 28, 2006 | LG 24 in. LD-12BS6 Stainless Steel...
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
501 people viewed this question
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
