Question about Dryers
YOU GUYS ARE THE BEST SERIOUSLY
I HAVE BEEN TOLD TWICE BY YOU GUYS TO REPLACE COILS SOLENOIDS WELL THEY ARE IN FRONT LEFT OF DRYER I SEE TWO CLAMPS ON TOP AND TWO SPRINGS ON BOTTOM CORNERS HOW DO I REMOVE FRONT OF DRYER? WHIRLPOOL DRYER LGR8648LWO TY
    Sergeant:
  • 211 Answers
UNPLUG DRYER B4 YOU START ANYTHING !you need a puttknife locate two clip on both side of the dry botton access panel push the blade in over the top of clip while pull on the left side dryer some time the clip are hard to let go,an if you got a old model you have to take the lint screen out of top of dryer take two screw out on front top of the front panel there two clip you use your flat head screwdrive are puttknife locate the two clip on left an right side of dry pop the top lift up an look down on the left an right inside dry there two 5/16 srew you got to remove an lift panel up an off. the gas coil should be locate on the left are right side of dryer depend on model
Posted on Apr 25, 2010
Dryer ignites and flame stays on for 1-2 minutes then shuts off and comes on again a few minutes later
This is most likely caused by faulty gas valve coils. The electrical coils are right above the gas valves and when energized, these solenoids open the gas valves to permit gas flow. A symptom of bad solenoids is a "cycling" condition such as you have described. It is recommended that if any solenoids are suspected of being faulty that they both (all) be replaced at the same time. They will most likely come as a set. Hope this helped and best wishes.
Oct 07, 2009 | Kenmore 63942 Dryer
Maytag gas dryer MDG6400AWW heats up for 2 minutes and that's it everything else runs. and twice I smelled gas when I opened the dryer door. the timer was replaced 2 years ago. Is there another problem?
turn gas off to dryer. For safety it is best not to wait get your gas company to find leak(i don't think they charge for that)if it is at the control valve you should take the screws that hold the coils down out.Remove coils and rubber O rings and replace all with new ones it comes as a kit
Aug 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool 110.76722690 gas clothes dryer spins but no heat
First, check that the ignitor is working properly. If it is working properly, it should glow an orange color when activated. If the ignitor is defective, it will need replaced. If the ignitor is working properly, the problem is most likely the gas valve coils. These small black coils are situated directly above the gas valves. These solenoids, when energized, open the gas valves and permit the burner to light. If any are defective, the valves cannot open and the burner cannot light. Due to the difficulty in testing these solenoids, it is best to replace both (all) of them at once if they are suspected of being faulty. Hope this helped and best wishes.
Aug 06, 2009 | Kenmore 659 Electric Dryer
My dryer doesnt get hot
With gas bills so outrageously high these days, you deserve a medal for being able to keep current! lol Let's see what we can do about the dryer. First, check that the ignitor is working. It should glow an orange color if it is working. If the ignitor seems to be working properly, then I would suspect faulty gas valve coils. These are solenoids located directly above the gas valves, that when energized, open the valves and permit gas to flow to the burner. If the solenoids are faulty, the gas valves won't open and the burner cannot light. Due to the difficulty in testing these solenoids, it is best to replace both (all) of them at once if any are suspected of being faulty. Hope this helped and best wishes.
Aug 06, 2009 | LG DLE0332 Gas Dryer
Dryer will not ignite
If the ignitor is working properly, I would suspect faulty gas valve coils. These solenoids are located right above the gas valves and when energized, they open the gas valves. If they are faulty, the valves won't open and the burner won't light. Due to the difficulty in testing the coils, it is best to replace both (all) of them at once. Hope this helped and best wishes.
Aug 05, 2009 | Kenmore 800 7983 Dryer
Whilpool dryer m#ggw9868k02 ignitor glows but no flame
If the ignitor is working properly, the problem most likely lies with the gas valve coils. They are located just above the gas valves. These solenoids, when energized, open the gas valves and allow the burner to light. Since these solenoids are hard to test, if any are suspected of being faulty, it is best to replace both (all) of them at the same time. Hope this helped and best wishes.
Aug 05, 2009 | Dryers
My gas dryer won't heat but will run it's a duet and i changed the glow plug or igniter
Since you replaced the ignitor and if it is operating normally, it should glow visibly. If the ignitor is operating properly and the burner is not lighting, then I would look at faulty gas valve coils as being the problem. The coils are located right above the gas valves. These solenoids, when energized, open the gas valves. If they are faulty, the gas valves won't open and the burner won't light. Due to the difficulty in testing these coils, it is best when replacing them to replace both (all) of them at once. Hope this helped and best wishes.
Aug 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer motor works but will not heat. Dryer is gas
First, check to see that the ignitor is operating properly. It should glow orange if it is heating up. If the ignitor is ok, then look at the gas valve coils. These coils are right above the gas valves and when these solenoids are energized, they open the gas valves. If the coils are faulty, it cannot open the valves and so the gas cannot ignite. If they are faulty, and due to the difficulty in testing them, it is best to replace both (all) of them at the same time. Sure hope this helped and best wishes.
Aug 02, 2009 | Maytag MGDZ400TQ Gas Dryer
Dryer not heating, replaced igniter, told by repairmen to check inline fuse but we cannot find it, model LGR7620LW0, also curious if flame sensor could be defective
The first thing to look at would be the thermal fuse. It is usually mounted on the exhaust duct at rear of dryer. It's about one inch long. You can test it for continuity with a multimeter. If it has no continuity, it is bad and needs replaced. If the ignitor is glowing, but the gas isn't igniting, I would look next at the gas valve coils. They are right above the gas valves. They are solenoids that, when energized, open the gas valves. If the thermal fuse is not the problem, then I would look at the coils. It is hard to test them, so it is best to replace both (all) of them at the same time. Hope this helped and best wishes.
Jul 29, 2009 | Dryers
Dryer worked well until recently. Igniter glows
I would take a look at the gas coil solenoids. The gas coils are right above the gas valves. They are black electrical coils. When energized, the coils open the gas valves. If one or more of the coils is defective (bad solenoids), then the gas valves won't open and the gas cannot ignite. Because it's difficult to test the coils, it is best to replace both (all) of them at the same time. Sure hope this helped and best wishes.
Jul 28, 2009 | Dryers
Dryers Logo
65 people viewed this question
Top Dryers Experts
