Question about Harman Kardon HK695 Computer Speakers
The speaker works but its volume is low even if i raise it all the way up. what is wrong with it?
    Brigadier General:
  • 10,406 Answers
Connect the speakers to another computer, and compare the volume. If it still is "quiet", then the problem is in the speakers, or in the AC adapter that connects to the speakers.
Posted on Apr 23, 2010
How do I adjust the volume on ASUS 19
if the volume is too low and your monitor cant be raised more, youll have to use another form of audio. Try headphones or speakers. Monitor speakers are cheap and unreliable so often they dont get loud enough for people's needs.
Oct 18, 2012 | ASUS Vw223t 22" Widescreen LCDFlat Panel...
Rca tv ..how to hook up to home speakers
Unless the set has actual audio outputs it should not be done.
The set will have a very low audio output not intended for external systems--if you hook to wrong impedance speakers volume either will not work, be very low or even damage the audio circuit in the set
Mar 28, 2012 | RCA 27V530T 27" TV
Hitachi mx-w50
This is not a camera, it is an integrated 'hi-fi' system - try posting this query in a forum dealing with music centres
Jun 16, 2017 | Cameras
BlackBerry bold 9700,its speaker phone not working,ringtones and music not heard,but if i put it near ear from back of the phone then music is heard.Please solve as this is my new phone
Your phone is set on handset mode.While playing music,press the blackberry button and select the activate speakerphone option on the list.This would work for you.
Mar 26, 2011 | RIM BlackBerry Bold 9700 Smartphone
I have the Bose Companion 3 Series II speakers. I ordered them through the Bose website. However, I continuously hear static. Mute, low volume, with music, etc. I hear static noise. The only way to...
I have had totally the same problem before, and I have discovered that it is actually because of the electric current running through the speakers when the volume is low or muted.
I am afraid to tell you that the only solution to this problem is to raise the volume, as it is not a malfunction in the speakers but in the electric current running through them.
Good luck.
Dec 16, 2010 | Bose Companion 3 Series II Multimedia...
The volume of my speaker is so low, i cant barely hear it, i cant see anything wrong with it, i checked the AC in, i checked the jack for any short circuit still iget a very low volume out of the speaker...
look on the lower right corner of your screen. there should be a volume icon down there. it looks like a speaker. click that and see if it is set up or down low. if it is low turn it up then it should work. this controls the amount of sound coming out of the sound card on your computer.
Jun 27, 2010 | Creative Labs : Creative Inspire 2900 2.1...
Replaced rear factory speakers now have low volume
Factory speakers usually have low resistance ( 2 ohm) When replacing speakers with aftermarket, most aftermarket speakers will be 4 ohm. If you want the same sound you may have to buy some resistors to put on the speakers (across the + and -). By putting a 4 ohm resistor across the connectors will now make the speaker 2 ohms which in effect will raise the volume. Depending in what vehicle you replaced the speakers the resistance will vary.
May 18, 2009 | Sony CDX-GT500 CD Player
The volume is very low even at the top of bar
Look for a speaker icon in the taskbar (near the clock in the bottom right of the screen). Click it once and raise the slider.
Apr 25, 2009 | Dell Inspiron XPS M140 Notebook
Speakers playing low
open the disc tray and press setup and the speaker volume option will activate and also turn off the night mode for louder sound
Dec 15, 2007 | Philips HTS3440/37 System
Car Audio Cutting Out
stereo is detecting a short , or low load on speaker wire and or speakers .Go behind car stereo , disconnect all speakers and apply a known good speaker to one of four wires and see if volume works normally ..If it works use same speaker on all outputs one by one ..If all are okay then you should figure out what speaker and or wires are causing issue..Also make sure your ground is okay
Dec 01, 2007 | Pyramid 4 X 10 SPEAKERS Car Speaker
Harman Kardon HK695 Computer Speakers Logo
437 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
