Question about Microsoft Xbox Console
X box dashboard
Is there a way to get original xbox dashboard back without connecting to live?
No you need live i think
Posted on Mar 30, 2008
Dont know how to set up xbox live with wireless
Is this a new slim unit or the original system? If it is the original system you cannot set up live wirelessly without purchasing a wireless adapter.
If you have the newer slim model which is black with vents running up the side.
stoshua.jpg Slim Orignal
They both can be configured via the dashboard. You need to go to system settings (last screen on the dashboard all the way to the right) Choose network settings Choose wireless network Choose network settings You will need to know your wireless network's ESSID, encryption type, and key.Provided your router is set up to assign your network devices with an IP address automatically (DHCP) you should be fine at this point else you will also need to manually configure your PI address, subnet mask and as well as your gateway.
Once you enter in the information you can go back to the settings screen and test your connection to xbox live. The xbox will attempt to verify a connection to you LAN (local area network) then the internet and finally to xbox live servers. If you entered everything properly you should have no issues with connecting.
Jun 23, 2011 | Microsoft Xbox 360 Console
How to connect my xbox to xbox live. Damian.
1st need internet
2nd internet cable plugged in to console and internet
3rd turn on go to x box live to connect if u have xbox gold which u can buy at any store, gas stsation (speedway) if u have one go to xbox dashboard and hit redeem code enter digits found on back of card hit enter and ENJOY!!!
Feb 25, 2011 | Microsoft Xbox 360 Console
Want to set xbox on line havnt got a clue
If you have an original Xbox the online capability is obsolete and will no longer be supported by Microsoft if you have an Xbox 360 you need to purchase an xbox live account either at a retail location or online through your xbox dashboard (internet and credit card required). You need to connect a network cable to the back of the xbox the other end to your router or modem to access Xbox live. They also sell a wireless network adaptor for the 360 that you can use instead of a wired connection.
Jan 27, 2010 | NetGear WGR614 Wireless Router
Xbox live dont work please help
the reason for this part to fail differs along with the difference of the type of connection you are using to connect your Xbox 360 console as follows:
a. Direct connection to modem:
1. Make sure first no other devices connected to the modem at the same time as some modems has an Ethernet port along with a USB port so, you might think you can use both at the same time & connect the PC through USB with the console through Ethernet & that's incorrect so, we need to disconnect the PC first.
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live". 3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Edit Settings” then “Additional Settings” tab then select “Advanced settings” & put the Physical Address of your PC without the dashes on the “Alternate MAC Address” part and select "Done", when it asks you to Apply Settings choose “Test Xbox Live”.
b. Wired connection to router:
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
c. Wireless connection to router:
2. Go on the Dashboard of your Xbox 360 console to the "system" area then "Network Settings" then "Edit Settings" then select your wireless settings part down there "Wireless Mode, Network Name,..." the console will automatically then search for your wireless network and when it find it and you select it, it will ask you to enter your wireless key which is called WEP or WPA key - you can find it written on your wireless router or then you need to contact your ISP (Internet Service Provider) to get it from them - when it ask you to apply settings select "Test Xbox Live".
3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you’ll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can put the Xbox 360 console - as a trial - in a closer position to the router to see wither it's going to pick up an IP address or not.
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
d. ICS (Internet Connection Sharing):
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore to Factory Default" when it asks you to Apply Settings choose “Test Xbox Live”.
2. Allow the ICS option on the PC as mentioned before, then test Xbox Live.
3. If it's still not working, set the IP Settings manually to be:
IP Address: 192.168.0.2
Subnet Mask: 255.255.255.0
Gateway: 192.168.0.1
Then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose “Test Xbox Live”.
If you faced any other kind of troubles with this part failing even after you tried these steps please check me
Jan 03, 2009 | Microsoft LIVE ONECARE 2.0 XP/Vista for PC
Cant sign into live
I think your account might have been banned, or have you tried to sign into silver with another account? If that works its ur account,
Dec 24, 2007 | Microsoft Xbox 360 Console
Xbox component output causes "epileptic" flickering
x box 1 on a hdtv r u sure , or do u mean the 360?
Sep 13, 2007 | Microsoft Xbox Console
Xbox dashboard
hello zack0893, you have two options: Couple options: -Does the xbox still boot games? If so, boot up the exploit, and install UXE Complete from "the usual places". Your xbox will be fine. UnleashX has memory card/save management. To get your dash back, you could cold-boot a live-enabled game (SC should work, actually), connect the xbox to a network, and select LIVE, the latest dashboard will install. -get Slayers AutoInstaller disc, and extract the contents with QWIX. The original dash files are in side a c:\ folder somewhere. hope this will fix your problem. AMINE
Aug 18, 2007 | Microsoft Xbox Console
Xbox Dashboard on high definition TV
With the latest update to the Xbox Dashboard available from Xbox LiveĀ®, you can change the default display mode of the Xbox Dashboard from 480i to 480p. Connect your console to the component inputs of a 480p-capable TV using an Xbox High Definition AV Pack toview the Xbox Dashboard in high definition. To get the latest Xbox Dashboard Using a Broadband connection and the Ethernet connector on the back of the console, connect your Xbox to the Xbox Live servers. When you do so, the latest version of Xbox Live, including the Xbox Dashboard, automatically downloads. You do not need to subscribe to Xbox Live for this update to automatically download to your Xbox. But if you don't have an Xbox Live account, get one! To set the Xbox Dashboard to 480p Connect your Xbox console to the component inputs of a TV that supports 480p with an Xbox High Definition AV Pack. Start the Xbox console without a disc in the tray to run the Xbox Dashboard. Note If your Xbox console takes you to the Xbox Livearea rather than the Xbox Dashboard main menu, press the B button on the Xbox controller twiceto return to the Xbox Dashboard main menu. From the main menu of the Xbox Dashboard, select Settings. Fromthe Settings menu, select Video. Fromthe Video menu, select 480p. Select Yes to confirm that your TV supports 480p. Pull and hold both the left and right triggers. While holding the triggers, click (press in) the left and right thumbsticks. After a brief blank screen, the Xbox Dashboard will display in 480p. If you want to return to 480i, repeat the controller combination in step 7, or switch your Xbox High Definition AV Pack with another type of AV pack. Note The opening Xbox animation does not display in 480p, only 480i. To resetthe Xbox Dashboard to 480i Start the Xbox console without a disc in the tray torun the Xbox Dashboard. Note If your Xbox console takes you to the Xbox Live area rather than the Xbox Dashboard main menu, press the B button on the Xbox controller twice to return tothe Xbox Dashboard main menu. From the main menu of the Xbox Dashboard, select Settings. Fromthe Settings menu, select Video. Fromthe Video menu, select 480p. Select No to indicate that your TV does not support 480p to reset your Xbox Dashboard to 480i. If your screen appears blank or scrambled If your Xbox Dashboard does not display correctly while in 480p, it might be difficult to see the menus to reset your display to 480i. Connect your Xbox High Definition AV Pack?s green color-coded video output jack (the one marked with the letter Y) to the composite video input of your TV. Note The composite input on a TV is normally color-coded with yellow. Proceed to reset your display to 480i as described above
Nov 20, 2005 | Microsoft Xbox Console
Nov 20, 2005 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
18 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
