Question about Kenmore 24032\24036 Top Load Washer
My washing machine won't drain
It starts, but then stops. It shows an error message "Ld". It is a Top loader, Kenmore Elite Model #110.22082.101 Serial #CL4603987 Type 170
  • whitski101 Apr 26, 2010
    Yes!!! Thanks so much, there were some coins stuck in the pump. Once we got those out it works like new!
  • 8,197 Answers
The LD code means long drain. Here is how to fix on link below.
http://www.associatedcontent.com/article/817667/how_to_clean_the_clogged_pump_of_a.html?cat=6
Posted on Apr 24, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
I have an kenmore elite oasis he and the washer has a code - LD. If i try to stop and start it, it just hums.
The LD means Long drain time...that error code coupled with the hum i believe something is stuck in the drain pump preventing it from turning and that is why its humming
GENE
Aug 28, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Machine stops during cycle
"LD" stands for long drain meaning that the pump could be bad or that it just needs to be cleaned out.
Jul 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Top Loader reading LD code.
You may have an obstruction in your pump which causes it to drain slower than usual, or binds the impeller. Flow can still be pretty good even with this problem but the brain will sense a longer than normal drain time and flag the error. Try removing the water pump and look for underwires, paper clips or hairpins.
Mar 07, 2010 | Washing Machines
Ld error
Ld - Long drain - Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Press STOP/CANCEL to clear the display.
Good Luck!!
Thanks
Jun 23, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Ld error message
It most likely means long drain, the drain line could be clogged or kinked. You could also have something jamming the drain pump or a bad drain pump.
Jan 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
64 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
