I have restore cd's but how do i erase evrything so i can start from scratch
    Brigadier General:
  • 10,406 Answers
Put the first System Restore CD into the drive.
Restart your computer.
Tell your computer to "change the boot order", to select the CD device as the _first_ device.
As part of the "System Restore", your disk-drive will be completely erased.
Posted on Apr 23, 2010
My intsul disc is sractched so bad that it will not install on to my new computer what do i do now??
Clean off the CD. Run some warm water over it and then rub it with a microfiber cloth.
Rub from the inside edge, straight out to the outside edge.
Do not rub in circles.
Continue this process until the CD is dry.
Pour rubbing alcohol over the CD. Shake the excess off and let it air dry.
When CD is dry, try playing it to make sure that it wasn't simply dirty and not scratched.
Hold the CD in the light and try to determine precisely where the scratch is located.
Scratches will usually be visible.
If you can see the scratch, place a small amount of plain toothpaste
(the type with baking soda works best) and fill in the scratch with it.
Take the microfiber cloth and get it only slightly damp.
Rub the excess toothpaste off by working from the inside edge of the CD to the outside edge.
Repeat this until it is clear.
If you are having a hard time locating the scratch, but rather see several scratches, using your cloth rub a thin layer of Vaseline over the CD.
Gently wipe it off by once again moving from the inside edge to the outside edge of the CD, in straight motion, not in circular motion.
The Vaseline will fill the cracks, allowing the tracks to be read by the laser beam.
Use an original Mr. Clean Magic Eraser.
Lightly dampen it and run it along the CD in straight lines from the inside edge to the outside edge only.
Continue this process until the CD has been completely wiped with the eraser.
The magic erasers contain small microbead particles that can fill the crack
Things You'll Need
Rubbing alcohol
Toothpaste with baking soda
Microfiber cloth
Vaseline
Mr. Clean Magic Eraser can be purchased on Ebay
AU $2.78 +postage
AU $4.67
http://www.ebay.com.au/itm/MR-CLEAN-MAGIC-ERASER-/390187665113?pt=LH_DefaultDomain_0&hash=item5ad8ff46d9
try it once you have your cd cleaned any ready copy and paste it to a folder ready to burn it or do a cd copy
hope this helps
Oct 05, 2012 | Audio Players & Recorders
I just want to "Erase" everything and start over
You should have received recovery cds when yoou bought your desktop. One is for the XP installation and the second one is for the applications and drivers.
Just put the installation cd in and restart the desktop. You may have to hit a key when you see the message: boot from cd" on the screen.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Jan 06, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
I have an i pod touch but none of the apps will open. i have tried reseting it and rebooting it but they still dont work
Well since uve tried rebooting it and stuff i guess theres only one solution.
Connect ur ipod to the computer and, open itunes and go to the ipod summary page. from there click "restore" this will wipe off evrything on ur ipod and u will hav to start downloadin from scratch! this happened to me once but after i did this, they all opened up :)
hope this helps :D
Nov 01, 2009 | Apple iPod touch
Trying to restrore Hp zx5040us
Place the operating system cd in the drive and reboot the computer. Watch for the message "press any key to boot from cd" then press a key (I usually use the space bar). If you don't get the message about boot from cd you will need to change the boot order in the bios settings to make sure it looks to the cd/dvd drive first. Please be aware that this method will erase all personal files/folders and programs so make sure you have backed up first.
Jun 10, 2009 | Computers & Internet
ERASE AND REINSTALL ALL SOFTWARE
First if it have a restore disk or it is design to restore to factory setting this is the most desirable method.
Second is installing the software from a scratch. But copy all drivers of it. Or do you have in hand the full driver cd of your unit. Your operating system and other installed software that are important to you. Backup files that is important to you.
You gonna need some bootable cd or disk.
Apr 29, 2009 | Toshiba Satellite 5005-S504 Notebook
Emachine t2042
*.GHO files are Norton Ghost images that are used by some OEM's to create a factory defuault image. When you restore this it should set the pc back to the same condition it was in when u purchased it however this will erase all your personal data on the drive.
If you are getting this error it means that the ghost image you are using to restore the PC is corrupted and cannot be used. eaither the CD is trying to read this data from a corrupted restore partition or the restore disk you have is bad (sometimes the disk may look fine- no scratches or anything and still be bad)
Try checking the disk for scratches or smudges but if you dont find any you can clean off the disk you will have to contact e-machines for a replacement disk.
Jan 09, 2009 | E-Machines eMachines Desktop PC
Need to reinstall operating system without restore cd
i want to restore my hp compaq dx2200 microtower to factory setting but i lost the cd what can i do to restore it for free
Oct 27, 2008 | HP Compaq Business Desktop dx2200 - P4 524...
NEC ND-3540A DVD RW - problem with erasing RW DVD
try downloading this cdrw soft ware it works graet you can write rewrite and play software dvd 's evrything www.slysoft.com lala linda
Mar 17, 2008 | NEC ND-3540A DVD RW Dual Layer Burner
Need Help with Restore CD's
I suggest that you replace that optical drive and down load the restore disk from the manufacturers' website.
May 21, 2007 | E-Machines W4682 PC Desktop
Computers & Internet Logo
David Payne
David Payne
