Question about Linksys Wireless-G Broadband Router
My Belkin Wireless Network card sees the network but wont connect. Says waiting for Ip Address.
    Problem Solver:
  • 11 Answers
For this issue you need to update the driver software for the wireless Network Card which is available in http://belkin.com/support or you need to do change the wireless mode in your D-Link Router.......
Posted on Apr 24, 2010
Im trying to set this up as an access point. but it will not fine a ip from the router
Most router wont act as a DHCP client (Get an IP address) on their own.
You need to go into the Belkin setup and set it to an IP address in the range of your other router.
For example:
If your PC is getting (connected to the same network) an IP address of 192.168.0.3 IP and a Default Gateway address of 192.168.0.1 you can set the Belkin with any adderss between 192.168.0.10 & 192.168.0.254. Changing the last octet (set of numbers after the 3rd period) to the desired address.
Mar 02, 2011 | Belkin Wireless-N Wireless Router with...
I use the 802.11g enhanced wireless g notebook card and i use the belkin N 150 router but when i try to connect to my network, i will connect to the network but it cant find the network address
For that you need to enable DHCP in router.
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on DHCP and enable then save settings and restart router then enable ip address get automatic in network adapter property.
Let me know if you need further assistance.
Thanks for using FixYa.
Jul 01, 2010 | Dynex 802.11g Wireless-G Laptop Card
I have just bought a belkin network card, installed it correctly and attempted to connect it to my network. It connects, but after 5 minutes, disconnects and forces me to re-boot the router... I can't fix...
1. reset your router on factory reset and after try to connect your router, if you get success then you re configure your router agin with IP address 192.178.1.1
Mar 25, 2010 | Belkin 802.11g Wireless Desktop Network...
Hello sir . I have taken a belkin wireless G PCI card last month.i am using in the institution provided wi-fi net work in the hostel. Card catch the network but detach immediately and also not carry pocket...
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 29, 2009 | Belkin - F5D7000 - 54Mbps 802.11g Wireless...
I am trying to connectmy basement computer to my upstairs office
Your wireless router issues IP address to your computers.
Your wireless card on your downstairs computer needs to be configured to communicate with the router, ie WEP or WAP encryption - if your have enabled it, SSID etc.
To configure the TCP/IP settings on your downstairs computer -
Click on Start - Control Panel - then Network Connections - then right click on your Wireless Network connection - click on Properties.
Then in "This connection uses the following items, scroll down to Internet Protocol (TCP/IP) and click on Properties. Under the General Tab make sure Obtain an IP address automatically and Obtain DNS server address automatically are selected. Click OK.
If you do not see TCP/IP in the Wireless Network Connection then click on the install button and then install the TCP/IP driver.
IF TCP/IP is OK then before you do the following, turn off or disconnect the power to your wireless router, wait for 1 minute before connecting the power again. Wait till the LED lights indicate that it is on line again and the wireless is on then :-
Click on Start - Control Panel - then Network Connections - then right click on your Wireless Network connection - click on View Available Wireless Networks
Do you see your wireless network (ie. your wireless router)?
If so click on your wireless router and then click Connect.
You can also click on Repair to try to reconnect to your wireless router.
Let me know if it works.
Mar 04, 2009 | Dell TrueMobile 2300 Wireless Broadband...
Default ip address
do you know what router you have?
Nov 24, 2008 | Belkin 802.11g Wireless Desktop Network...
Need an IP address?????
yes you can create the ip address of the network to make sure the security and to access the network functionally.
Jun 10, 2008 | Belkin Wireless G Plus MIMO (F5D9010)
Belkin mimo G network card
I think in your Pc Wireless lancard is disable,Pls enable the wireless lancard,
1. just check the lan card is enbled
example:my network place --right click---properties---wireless lan card,
2. check the R u getting ip address,
example: start---run---cmd----ipconfig
May 20, 2008 | Belkin Dual-Band Wireless A+G Desktop...
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
