Question about RCA HD52W58 52" TV
Tv out of foucs
Can't find reset button on tv
    Problem Solver:
  • 17 Answers
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Posted on Jun 18, 2010
Where is the reset button
Sanyo Service Menu - Factory-Reset.com
factory-reset.com/wiki/Sanyo_Service_Menu
Jump to Sanyo TV Service Menu Method 2 - Unplug the power cable. Press and hold the {VOL -} button on the TV while plugging the power cable back ...
Sanyo TV reset button location? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 27, 2007 - Does anyone know where to find the reset button on a 32" Sanyo TV? The thing is just totally dead and I am thinking maybe if I push the reset it ... I have a Sanyo TV, I accidentally hit the reset button twice. I ...
Aug 6, 2012
36 inch sanyo tv won't change off video 2?
Apr 17, 2010
I accidentally hit the 'reset' button the remote of my sanyo tv ...
Jan 6, 2010
Sanyo DS32224 TV Problem!!?
May 21, 2009
More results from answers.yahoo.com
Nov 29, 2015 | Sanyo DS31520 31" TV
Changed foucs speedometre but car not start
Have the speedometer panel tested for errors, and check the fuse box for correct operation's.
Feb 14, 2012 | 2007 Ford Focus (3 Door) Hatchback
The hitachi 46f510 has went out of foucs how to fix it loos as if u watch through wax paper
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 27, 2010 | Hitachi 46F510 46" Projection HDTV
Where is the motherboard reset button located on sony tv kp-46wt510
No button on the main board. But, you can reset the TV by holding down the 'Reset' button on the TV remote and then pressing the 'Power' button on the TV control panel. This will cause the TV to Factory Reset. I hope this was helpful, best wishes.
Apr 12, 2010 | Televison & Video
Picture out of foucs
HIGH VOLTAGE WARNING - open the tv and on the flyback Xformer, there should be a knob that is labeled FOCUS try adjusting it. the flyback has the red wire on top that goes directly to the the top of the picture tube.
Jan 11, 2010 | Televison & Video
My Philips model 50p8341a 50" rear projection tv turns on, has sound but has no picture. Any ideas? Heard something about a convergence chip? Please advise.
you need ssb board is bad and you can,t git that part you can send to pts to have it rebuld. yes the stk 392-120 can drag the pix down but if you open it up you see a fouc blook go to the screen red or green or blue
turn it up just a litte the pix will come back. this is a know fact about this with this set i see a lot in my days of sevice ,at quaker tv
Dec 07, 2009 | Philips 50P8341 50" Rear Projection...
Toshiba that is very out foces
I can't find audio drivers for a toshiba P15-s20
can you help me
Jul 26, 2009 | Toshiba 50H82 50" Rear Projection...
Hitachi 57F500 blurry picture
How can I fix it? The magic foucs goes to two or three lines and goes back to the picture. The sides are blurry, like red and green.
Mar 18, 2009 | Hitachi 57F500 57" Rear Projection...
Loose mount and foucs ring will not turn
The short answer is "you don't"! Take it to a professional camera repair man. If you try to fix it yourself, you will quickly end up with a table full of parts and no way to put them back together. Typically, lenses are made like complex jigsaw puzzles. If you try to fix it yourself, you will fail and it will cost substantially more to have it repaired then it would if you had not tried to repair it yourself.
Dec 30, 2008 | Cameras
Camera wont take a picture
well u have the flash system with a problem that can just be solved replacing the mainboard. therefore you can´t do much.
Feb 12, 2007 | Olympus Stylus 400 Digital Camera
RCA HD52W58 52" TV Logo
250 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
