Question about Fisher and Paykel Washing Machines
Our gwl11 is beeping and the left most red light and right most green light on the wash cycle are on. Is this a trouble code? the machine does not fill properly. do you have a list of error messages?
  • djvski126 Apr 24, 2010
    after unloadig and puttig the machine on it's front to check things underneath, I tries again and this time I get 100000010 error code. It seems that wahtever cycle it is in, it is intermittant. i.e. the water fills on and off or the pump will start and stop. I looked up the error code on the sheets you referred me to ( thank you btw) and now I get the above erroe message. Can you help me?
    i looked at thr waher and the error lights are different after I looked underneath. the code is now 100000010. It refers to the rotor posistion sensor but I would like to find a diagarm that points out what parts I am looking at. Can you recommend a site or do you have a diagram that would help me out? Or do you know what the fix is to this error message? Thanks.
  • 10,515 Answers
There would be a Diagnostic Sheet inside the Machine as well. As far as you want Diagnostic Code List for this Model, you would get it from ;-
http://www.docstoc.com/docs/25379715/Fisher-_-Paykel-Washer-Diagnostic-Fault-Codes
If you want Schematics for this Model, refer to ;-
http://www.docstoc.com/docs/25379677/Fisher-and-Paykel-Circuit-Diagram-GWL11/
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 23, 2010
  • taran_2005
    taran_2005 Apr 24, 2010
    Thanks for your response!!
    Regarding Schematic, Check my first Comment that i sent. Initially i sent you the Schematics.Rotor sensor is attached 2 motor windings and detects position of motor
    and speed of motor.
    Complete Explanation of Error
    (10000010) Phase 1 to 6 Single Rotor
    Position Sensor Error
    The Motor Controller has found an error in
    the pattern received from the Rotor Position Sensor.
    Likely causes
    of this fault are a bad connection on the harness between the Rotor
    Position Sensor
    and the Motor Controller, or a faulty Rotor
    Position Sensor.
    Primary Source: Wiring.
    Action:
    1)
    Check for corrosion on the edge connector of the Rotor Position Sensor
    and the Motor Controller module connector.
    2) Check the
    contacts on the rotor positional sensor end of the hall harness to see
    if any have been damaged. (Each set of contacts in the socket has two
    wipers. If the distance between these wipers varies between different
    contacts, replace the rotor positional sensor harness).
    Secondary
    Source: Rotor Position Sensor.
    Action:
    Check the Rotor
    Position Sensor with an R.P.S. tester.
    Replace if faulty.
    Tertiary
    Source: Motor Controller module.
    Action:
    Replace Motor
    Controller module.
    Hope i helped you.
My Fisher and Paykel washing machine beeps every second and shows the following code 1&2 off, 3,4&5 on, 6,7&8 off. Have removed agitator and checked pump for blockages. Sometimes will do a full...
Each light has a specific number, so to work out the error code we need to know which side you are counting from i.e. left to right or right to left. Makes a huge difference.
Oct 08, 2017 | Fisher and Paykel GWL11 Top Load Washer
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,...
GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,Hepi
Jul 24, 2011 | Fisher and Paykel GWL11 Top Load Washer
Last cycle completed, maching beeped and washing taken out. Machine light is on rinse cycle and beeps will not reset to start new load.
Hi just read your posting.From the information in your posting you mentioned that the rinse light is on when the machine is beeping.Starting from the left to right on the wash progress lights which lights are lit when the machine is beeping,Is it the 1st and 6th or the 3rd and 7th etc?Please reply with this additional information and i am sure i can help you rectify your machine.Looking forward to your reply.
May 17, 2011 | Fisher and Paykel GWL11 Top Load Washer
Keeps stopping during wash cycle
Hi Kathy,just read your posting.When the machine stops during the cycle does the machine beep and show an error code?Could you confirm the model number of your machine.Now if you have an LCD screen on your machine the fault code will appear in it but if you have no screen then the error code will appear as lights .These lights will be a row of 8 lights.Starting from the left to right which lights are on when the machine is beeping.Is it the 2nd and 4th or the 1st and 7th ---etc---?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Sep 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer will not go through spin cycle just puts water in tub then will constantly beep
Hi just read your posting.When the machine stops and beeps an error code will appear.In the models with an LCD screen it will tell you what the code is.On machines without an LCD screen a series of lights will light up. The lit lights will be in a row of 8 lights.Starting from the left to right which lights are lit when the machine beeps?Is it the 2nd and 4th or the 3rd and 6th ----etc----?Please reply with additional information on the error code and I can help you rectify this fault.
Jul 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
After washing heavy load mashine spin cycle not working
Hi just read your posting.Does your machine drain the water .When your machine stopped doing the spin cycle did it start to beep and show a series of lights as an error code?Or have you got the model with the LCD display and it showed an error code in letters?If you have the model with lights and your machine beeped the lights that did come on will be in a row of 8.Starting from left to right is it the 2nd and 5th lights on or the 4th and 8th lights---etc---- that are lit? Please reply and I can help you rectify this fault for you.
Jun 26, 2010 | Fisher and Paykel GWL11 Top Load Washer
Start up Fault
there should be a trouble shooter in the console the blinking lights will tell you what the problem is and the common issues are listed on that paper.
Nov 08, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
99 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
