Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
The mower will stall when I lift my foot off the brake.
The mower will start and run but once I take my foot off the brake it will stall. Is it the clutch?
  • 394 Answers
If you have a gear transmission,you have some safety switches. One under the seat. One on the clutch -brake pedal. These switches work together to prevent accidental injury. One may have disconnected or a wire frayed. If one switch has failed it will shut the mower off.
Posted on Apr 23, 2010
Craftsman lawn tractor parking brake won't engage
are you holding the lever while lifting your foot of the pedal?
Jun 27, 2012 | Garden
My huskee riding lawnmower starts but wont run
The riding tractor uses a hydrostatic automatic drive transmission to operate and move, which must be operated correctly in order for the vehicle to move. The automatic drive disconnect is under the driver's seat and must be in the "Drive" position in order for the tractor to move. Once you have set the automatic drive disconnect to "Drive," slowly lift your left foot up off the brake pedal and adjust the throttle control to "Fast." Slowly use your right foot to step on the speed control pedal and move the pedal forward to increase speed
Mustang Parts.
May 28, 2012 | Swisher Garden
I have the Craftsman 20.5 Model 944.609800 42 in mower I can get it to run but when i put it in gear or take my foot off the brake it stalls it also stalls when i engage the mower blades can you help i...
I agree it is the seat switch. This switch will let you start the mower as long as it is in neutral, the brake is set and the mower blades are not engaged. I think it is just two wires, maybe you can jump them together and see if it runs.
Gary
Aug 06, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
MTD MODEL 13AB652F729 came to a complete stop by itself while running. It felt as if I had stepped on the brake. I lifted the rear of the tractor and found that the rear wheels won't turn while the...
If it stalled while mowing long grass the drive system will need resetting. Do this by starting the mower, while in neutral place the speed lever in the highest speed setting then let you foot off the brake/clutch then back on. Place in forward and you should have drive restored. Regards Phil.
Apr 23, 2011 | Mtd Garden
Engine stalls when blade is engaged
the best way to check is to run the engine with you on it then lift off the seat and see if the seat sensor is cutting off then put a bag with some weight in it and turn on the engine it should run ok if the sensor is working and lift the back box to see if the sensor works there.. the other cause could be a build up of grass in teh cutter area stopping the blades fron moving this can caus a stall if you get a hose and blast under the cutter guards and make shure the grass shute is clear for the grass to exit this may help to mine cuts out if there is a blockage here and the grass cant get out after it has been cut it builds up at the exit plates.. Hope this works AB
Sep 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower starts fine but stalls immediately upon
Check the switch connected to the brake curcuit.
As you suspect, that is more than likely the problem.
Good luck.
Jul 15, 2009 | Garden
Craftsman yard tractor runs but take foot off brake it dies.....
Check the under seat switch. The switch sometimes fails and this cuts the ignition except when the foot brake is down. You can use jumpers across the switch wires to test it.
Apr 18, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
521 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
