Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
7 terminal ignition switch wiring diagram
Where can i find a diagram for the 7 terminal switch
Anyone have a wiring diagram or know how to hook this up ?
Black and red are pretty standard for negative & positive battery terminals.
There is likely a model number (pic isn't good enough to see the finer print) on the label but the larger numerals are probably serial numbers and without the model number, you may have a problem finding the exact installation info you want.
The link below has illustrations for a different model but manufacturers will generally stick with a wiring code to make installation and even production simpler:
http://www.mygen.com/users/dbruce/myz31/Jacobs%20Ultra%20Team%20Installation%20Instructions.pdf
That company does not have the web 'presence' they should have by now.
Apr 20, 2015 | Cars & Trucks
Wire 253 holden boat motor starter alternator coil basic diagram
batter positive to one big terminal of the starter solenoid--large wire as in a car ( the other big terminal will have a wire from it going into the starter)
a wire from the start point of the ignition switch to the small terminal of the start solenoid .( This to energize the starter solenoid to start the engine.) a large wire ( 30 amp capacity ) from the positive terminal of the battery going to the BAT terminal of the alternator the plug in the back of the alternator will go to the battery light or ammeter.. wires from the start and run positions of the ignition switch to the coil. One to provide power when the starter is engaged and the other from the run position to provide power to keep the engine running
basic but it will work
Jan 25, 2015 | Holden Cars & Trucks
This question is for Strech.Hey bro you have give me a whole lot of information I know you are a very smart guy especially when it comes to bikes.So I don't know if you caught my question about the...
As far as the terminal board (terminal block, terminal plate) , I assume you mean something like this:
http://img.jpcycles.com/zoom/382-054_A.jpg
You may or may not be using all of the connections (they come in different standard lengths, and might have more connections than you need).
Now, I can't remember which wiring diagram I sent, so I'm starting over with this:
http://shovelhead.us/specs/wire/1976_FL_FLH.gif
The lower diagram is actually an continuation (to the right) of the upper diagram.
On the upper diagram, item #1 (to the right of the headlight, with little spots inside of it numbered 1 - 11) is the FRONT TERMINAL BOARD.
On the lower diagram, items # 17 - 20 comprise the REAR TERMINAL BOARD.
These show how many wires go to each terminal connection (example, terminal #3 in FRONT TERMINAL BOARD shows 5 wires connecting to that one terminal, #s 9 & 11 are not used).
Now your wire colors MIGHT not be stock.
In which case a multimeter would help you chase the wiring:
http://www.harborfreight.com/7-function-multimeter-98025.html
Also, do you have a Fat Bob tank center dash ignition switch?
http://i.ebayimg.com/00/s/MTA5MVgxMjI2/$(KGrHqZHJDME63ZMWiUbBO3tGwQzH!~~60_35.JPG
Or a key switch mounted somewhere else?
http://demonscy.ipower.com/i_pics/ignition_17-124_1.jpg
If the dash switch, this might help:
http://img231.imageshack.us/img231/931/dashswitchwiringdiagram.png
If a key switch, three wires would be:
1 - hot lead coming INTO switch
2 - lead going to ignition, brake light, instrumentation (for running without lights)
3 - lead going to lights (headlight, taillight) for ignition AND lights.
Hopefully, this will start you off.
Fire back with any questions
Feb 08, 2014 | Motorcycles
Can i get a wiring diagram for model 7007-00 i dont know what all these terminals do thanks jason
Wiring diagrams
http://waterheatertimer.org/images/4PST.jpg
http://waterheatertimer.org/images/4PST-example.jpg
Paragon 7007-00 timer has 120Volt clock motor, and 4 switching relays.
All 4 switching relays are NO and turn on-off at same time.
Connect 120V Hot and Neutral to terminals A and B.
Terminals 1 thru 8 are dry, and receive no power when 120V is applied to A and B.
There are two terminals for each relay.
Terminal 1 is for Hot wire and terminal 2 goes to load.
Terminal 3 is for Hot wire and terminal 4 goes to load.
Terminal 5 is for Hot wire and terminal 6 goes to load.
Terminal 7 is for Hot wire and terminal 8 goes to load.
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
http://waterheatertimer.org/Paragon-timers-and-manuals.html#7000
Aug 15, 2011 | Paragon 7007-00 Electromechanical Indoor 7...
Need a wiring diagram for a 1969 Ford F250.
there should be a slot for each wire on back of ignition play with them till you get it right cant hurt anything
Jan 14, 2010 | Ford F-250 Cars & Trucks
Ignition switch 1992 Lebaron
Hello! Disconnect +battery cable...Remove tilt lever...Remove 3 Torx column cover attaching screws...Then the upper and lower column column covers...Using a Torx with a security tip (also called tamper proof tip) #440-tx20H... Remove 3 ignition switch mounting screws...Carefully pull switch away from column...Release 2 connector locks on 7 terminal wiring connector...Then disconnect from ignition switch...Release connection lock on 4 terminal connector...Then disconnect from ignition switch.
Guru..................saailer
Jan 12, 2010 | 1992 Chrysler Lebaron
I need the wiring diagram for a 7 terminal
GO TO PARTSTREE.COM. PUT IN YOUR MAKE AND MODEL# THIS WILL PROBABLY BE WHAT YOUR LOOKING FOR HOPE THIS HELPED
Jun 06, 2009 | Garden
I have a toro 8-25 rear engine rider model 56172 serial # 8008773, I need a wiring diagram for my mower. It is messed up,and some *@#$%+&* mess it up before I got it. I received a diagram for a 7-25 and it...
None of the numbers you supplied match any info on the toro.com web site. Check the numbers and then see if toro has any info for you.
That said, it sounds like you connected to the wrong relay terminal. Here is how you want it connected:
The battery (and alternator) connect to one of the large terminals on the relay. The starter connects to the other large terminal. The start switch connects to the small terminal on the relay. The idea being that the small current connected to the small terminal turns on the relay which connects the large battery current to the starter.
Obviously there is more to the wiring than just that, but you didn't ask about the rest...
May 05, 2009 | Garden
Diagnostic codes
Please rate me solved...thanks!
DTC P1259: VTEC SYSTEM MALFUNCTION
1. Perform PCM reset procedure. See SELF-DIAGNOSTICS - INTRODUCTION article. Start engine
and run at 3000 RPM with no loads and transmission in Park or Neutral until radiator fan comes on. Road
test vehicle. Accelerate in 1st gear to an engine speed over 4000 RPM and hold that engine speed for at
least 2 seconds. If DTC P1259 is not indicated during first road test, repeat road test 2 more times. If DTC
P1259 is indicated, go to next step. If DTC P1259 is not indicated, problem is intermittent. System is
okay at this time. Check for poor connections or loose wires at VTEC solenoid valve connector and PCM.
See ENGINE PERFORMANCE WIRING DIAGRAMS article. Repair as necessary.
2. Turn ignition off. Disconnect VTEC pressure switch 2-pin connector. Check for continuity between
VTEC pressure switch terminals. If continuity exists, go to next step. If continuity does not exist, replace
VTEC pressure switch.
3. Turn ignition on. Measure voltage between ground and VTEC pressure switch harness connector terminal
No. 2 (Blue/Black wire). If about 12 volts exist, go to next step. If about 12 volts do not exist, check for
an open or short in Blue/Black wire between VTEC pressure switch and PCM 31-pin connector "C"
terminal No. 10. Repair as necessary. If wire is okay, substitute a known-good PCM and recheck. See
SUBSTITUTING PCM in SELF-DIAGNOSTICS - INTRODUCTION article. If symptom or problem
goes away, replace original PCM.
4. Measure voltage between VTEC pressure switch harness connector terminals. If battery voltage exists, go
to next step. If battery voltage does not exist, repair open in Brown/Black wire between VTEC pressure
switch and ground connector located on left side of engine, under throttle plate, between end of radiator
hose and cooling fan switch. See ENGINE PERFORMANCE WIRING DIAGRAMS article. If wire is
okay , substitute a known-good PCM and recheck. See SUBSTITUTING PCM in SELFDIAGNOSTICS
- INTRODUCTION article. If symptom or problem goes away, replace original PCM.
5. Turn ignition off. Disconnect VTEC solenoid valve connector. Measure resistance between ground and
VTEC solenoid valve connector. See ENGINE PERFORMANCE WIRING DIAGRAMS article. If
resistance is 14-30 ohms, go to next step. If resistance is not 14-30 ohms, replace VTEC solenoid valve.
6. Remove VTEC pressure switch and install Pressure Gauge Adaptor (07NAJ-P07010A) and A/T Low
Pressure Gauge (07406-0070300). Reinstall VTEC pressure switch into adaptor. Connect tachometer.
Start engine and with no loads and transmission in Park or Neutral until radiator fan comes on. Because
engine is running with no load, oil pressure must be checked within one minute. Check oil pressure at
engine speeds of 1000, 2000 and 3000 RPM. If oil pressure is less than 7 psi (48 kPa), go to next step. If
oil pressure is 7 psi (48 kPa) or more, check VTEC solenoid valve. See SYSTEM & COMPONENT
TESTING article.
7. Turn ignition off. Disconnect VTEC solenoid valve connector. Connect a fused jumper wire between
battery voltage and VTEC solenoid valve connector. Start engine and check oil pressure at 3000 RPM. If
oil pressure is more than 57 psi (393 kPa), go to next step. If oil pressure is 57 psi (393 kPa) or less,
check VTEC solenoid valve. See SYSTEM & COMPONENT TESTING article.
8. Ensure jumper wire is still connected to VTEC solenoid valve connector. Start engine and allow it to idle.
Set engine speed to more than 4000 RPM and measure voltage between ground and PCM 31-pin
connector "C" terminal No. 10 (Blue/Black wire). See ENGINE PERFORMANCE WIRING
DIAGRAMS article. If battery voltage exists, go to next step. If battery voltage does not exist, replace
9. Turn ignition off and disconnect jumper wire. Check for continuity between VTEC solenoid valve
harness connector and PCM 25-pin connector "B" terminal No. 12 (Green/Yellow wire). See Fig. 2 . See
ENGINE PERFORMANCE WIRING DIAGRAMS article. If continuity exists, go to next step. If
continuity does not exist, repair open in Green/Yellow wire between VTEC solenoid valve connector and
PCM 25-pin connector "B" terminal No. 12.
10. Check for continuity between ground and VTEC solenoid valve connector. See ENGINE
PERFORMANCE WIRING DIAGRAMS article. If continuity exists, repair short in Green/Yellow
wire between VTEC solenoid valve connector and PCM 25-pin connector "B" terminal No. 12. If
continuity does not exist, substitute a known-good PCM and recheck. See SUBSTITUTING PCM in
SELF-DIAGNOSTICS - INTRODUCTION article. If symptom or problem goes away, replace original
PCM
Jun 21, 2008 | 1999 Honda Accord
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,089 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
