First I hate the fact that I wasn't paying attention to my own common sense. You can't wash without water. My main problem is the worrysom vibration this machine puts out. I have lowered the spin cycle to medium and it is still shaking so bad I'm afraid it might be doing structural damage to my brand new home. I have it on the second floor of my house and can't use grandfather clock because it has been knocked completely off balance to where it won't chime
I have a problem with the spin cycle, the vibration is horrible, my washer is on the 2nd floor, how can I resolve this?
Posted on Feb 03, 2009
  • 43 Answers
Have you removed the packing transit bolts
Posted on Mar 23, 2008
Aquarius vs Virgo? In terms of intelligence.?
They are both very smart. Aquarius may be more intelligent, but I hate them. Virgos are only smart because they pay attention to everything
Both are equally smart in different ways. Virgos have good common sense and mathematical ability, while Aquarius are very scientific and inventive.
To get more info go through url.. Aquarius vs Virgo In terms of intelligence
Jan 04, 2017 | Horoscopes
Oil leak
Check your oil pan, did you run over something? That many quarts of oil has to be leaking from somewhere. Headgasket blown would likely show as water mixing with engine oil(no loss of water would likely remove likelihood of blown headgasket).
Jun 13, 2013 | 1998 Chevrolet Lumina
Whirlpool Quiet Partner II clean light blinks 7 times
The clean light flashing 7 times is an error code indicating an issue with the wash temperature. If the control does not detect a 4*F temperature rise in the main wash cycle, it will display the fault as the clean light flashing 7 times. There are several things that could cause the water not to heat, including the water being too hot coming in, an open door switch, or a faulty component in the heater circuit. The most common cause is the door switch not closing properly. This can be due to a loading issue or a latch issue. If upon visual inspection of the heating element no obvious defects are found, I would recommend resetting the control and running another cycle, paying close attention to door closure. If the light begins flashing again, you likely have a component failure. The heat circuit consists of several components including the element, control, door switch and tub thermostat(s). Reset the control by pressing teh following buttons within 5 seconds.
Hit Temp Wash Heated Dry Hi Temp Wash Heated Dry
Mar 02, 2012 | Whirlpool Dishwashers
Frigidaire dehumidifier is not collecting water; model may be older but there wasn't much ice collects. started under same conditions as before
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog unit
set the humidity extraction knob on Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humid-i-stat has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 23, 2011 | Frigidaire FDF50S Dehumidifier
DEHUMIDIFIER IS RUNNING BUT NOT COLLECTING WATER
level
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Jul 28, 2011 | Whirlpool AD25BBR 25 Pint Per Day...
I have a Danby dehumidifier. It has not been used for 1 year... I tried to use it, it seems to work (noise, blue light on the little panel) but in fact there is no water in the tank after several hours and...
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2..
level
in basement applications . Raising the unit up off the floor,
problem.
Hope this helps you.
Jul 09, 2011 | Danby Heating & Cooling
I am getting fe error after the water fills in.it doesnt start washing. What to do?
The FE error isn't common to all washers. In fact, I could only find information on it in relation to LG washers. I actually found this link here which explains it pretty well:
http://www.managemylife.com/mmh/questions/208013-lg-wm2032hw-error-fe
Jun 23, 2010 | Washing Machines
Hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Aug 26, 2009 | Hotpoint Washing Machines
I spilled little coke on my lapi sony lf v30, but some of keys are not workg might be 4 keys... how can i skolve this
You'll have to remove the keyboard from the laptop, pull off some keys, and clean the board with a q-tip with a tiny tiny bit of warm distilled water or 99% alcohol or you can purchase some electronics cleaner solution from Radioshack.
DO NOT USE plain old water or soap or anything else.
Pay close attention to how the keys are attached to the white plastic clips, it's not rocket science and there are no special tricks to getting them back on except to use common sense.
If the above doesn't work you can always just purchase a replacement keyboard from ebay for relatively cheap.
Hope this helps.
Best of luck!
RescueTechLA
Mar 10, 2009 | HP Pavilion dv6000z Notebook
LG WM2455HW washer problem
Some machines monitor the power required to operate the drive motor and excessive power requirements can lead to this type of error. Try using a light load so the motor isn't strained.
Mar 01, 2017 | LG Washing Machines
Washing Machines Logo
261 people viewed this question
Top Washing Machines Experts
