Question about Jandy 131K BTU LAARS AIR ENERGY HEAT PUMP W/TITAN. HX & CHILLER
Spa will not heat. Service AGS light is on. What does AGS mean
What does the AGS light mean, service?
    Top Expert:
  • Jandy Master
  • 8,163 Answers
Check safety circuit and gas pressure
Posted on Apr 29, 2016
  • 9 Answers
SOURCE: the AGS
AGS is automatic gas shutdown,
can be caused by problems with pump pressure, or low gas supply pressure .
Posted on Jun 18, 2009
  • 9 Answers
SOURCE: Jandy lx250 heater is giving me service code ags
AGS automatic gas shut down
which means you have ignition failure, which can be from low gas pressure, or volume. if the heater fires then goes out the signal is not going back to the control module check all wiring.
  • 8404 Answers
SOURCE: Service AGS message is on the heater
Look here:
http://www.jandy.com/html/productsupport/
I hope this leads you to your answer.
Alternataively, you could contact your local distributor.
Posted on Oct 04, 2009
  • 10 Answers
SOURCE: I have a Jandy Laars LX Pool/Spa Heater...when I
If the unit is lighting then shutting off then repeating it isn't rectifying, means not sensing the flame. May have a bad flame sensor or ignition control. I'm guessing your AGS is indicated on the GUI also.
Posted on Mar 07, 2010
  • 11 Answers
SOURCE: try to start heater and i get a code that says
Automatic gas Shut Off . The system Locks out if it does not ignite. Shut the power off to the unit at the breaker then try to start it again.
Posted on Jun 30, 2010
What does service ags mean on a LAARS LX pool heater?
AGS stands for Automatic Gas Shutoff. This means the heater failed to sense a flame or flame rectification. When this occurs, the the gas valve will close as a safety precaution. The heater will have to be reset to get another call for heat.
May 18, 2010 | Jandy 131K BTU LAARS AIR ENERGY HEAT PUMP...
I have a Jandy Laars LX Pool/Spa Heater...when I try to heat it cycles three times then tells me to call for service...I feel heat coming out of the vent. The pool/spa is connected to a AquaLinks system...
Mar 05, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Service light and ags light comes on after a minute or two
I had this problem. Jandy ended up replacing the burner from day 1 with the heater (LT400 propane). It was a manufacturing defect. Of course it took 5 trips from the "warranty" company to not fix it before they finally punted to Jandy. Then, there's only one Jandy service rep from VA to ME (I'm in PA).
Jan 27, 2010 | Jandy Laars Lt 400,000 Btu Heater
I have to reset the heater several times before it lights. I get the "service" and "AGS" lightgs flashing after it tried to light. Once it lights it runs fine
AGS MEANS TH EHEATER IS NOT FIRING CHECK YOUR GAS VALVE IF OPEN THAN CLEAN THE ORIFICES WHERE THE GAS COMES OUT AT THE GAS MANIFOLD
Oct 30, 2009 | Jandy Laars Lt 400,000 Btu Heater
Jandy LT Pool/Spa Heater Will Not Heat
YOU SHOULD DIAL 1800 jandy LT help me out! the device the number or contact should be there .
Oct 03, 2009 | Jandy Lite2 LG400 Ceramic Compact Heater
Jun 16, 2009 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
Jandy 131K BTU LAARS AIR ENERGY HEAT PUMP W/TITAN. HX & CHILLER Logo
133 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
