Question about Sharp CD-MPX850 Shelf System
THE SYSTEM SHOWS ME ER-CD01 AND ALSO THE PLAYER WONT PLAY THE CD, IT DOESN'T EVEN READ THE CD
  • Anonymous Mar 15, 2014
    cd will not play
  • Virgil Schmidt
    Virgil Schmidt Nov 22, 2014
    I'm going to try and explain this. I have an Onkyo 6 change cd player and it started to show "Er"; just out of the blue...It seems. The whole tray slider wouldn't even slide open (to take cds in/out). I took it apart and saw nothing unusual. I blue on things and nothing. After a week of it sitting on the floor, and thinking it needed to be taken in. I took another look at it. I removed the moved middle screw on the tray and tried to take out the cd holder (the part that spins for the player to find/play the "next" cd. As I was lifting and spinning the tray around, it slipped and popped back down, AND the whole slider opened. Short end to the story, The cd holder tray seemed to be stuck. I pushed the open/close button and watched the display to see if "Er" would show up. It didn't. I put the screw back in... plugged it all together and the cd player is fine.
  • 666 Answers
This is a standard reset so if its a problem with the programming this should do the trick if it does not either your cd or laser lens is no longer doing its job properly
turn on the set-press the on stanby button,allow the set to enter demo mode. now press the power button while pressing the stop and eject button,clear all will display
hope this helps
Robb
Posted on Apr 23, 2010
CD player rotates but wont play or read disc.
Cd spins but player can not play - ecoustics.com
www.ecoustics.com > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) - eCoustics.com
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc - ecoustics.com
May 30, 2004
More results from www.ecoustics.com
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | Audio Players & Recorders
Jensen Personal CD Player Model CD-60 won't play cds. It starts and then shows "ER " message. I've put in fresh batteries - no change. Appreciate your help, thanks so much!
Have you try a Cleaning Disk. Maybe you can use a compress air can (usually sell in pc/electronics stores) and clening up the laser lens. Check for dirty on discs, water drops or scratches. Try another CD
Hope this help.
Regards,
Mar 13, 2011 | Jensen CD-60 Personal CD Player
Put a CD in and get message that says ER (Error?)...every CD that goes in spins, but does not play.
could be one of 2 things
use a cd lens cleaner to clean the laser lens .
or could be warped or damaged cds and player wont play them
also if they are burnt cd the player may be to old to read them.
Apr 26, 2009 | Audio Players & Recorders
ER message for CD, Sharp GX-CH150
The optics assembly is having a problem. Either it can not read the disc at all or the disc is not spinning. In any case, the unit will require service. If you can reach the lens, try cleaning it using a cotton swab and alcohol. That may resolve the problem. If not, update this. Please try to see whether or not the disc spins and report that as well.
Thanks,
Dan
Apr 07, 2008 | Sharp GX-CH150 Shelf System
Wont play cds
Wiring is not hooked up right, you are going to burn your amp/cd player up...
Jun 25, 2007 | Panasonic CQ-C7301U CD Player
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Jan 01, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
CD Player will not play all CD-R discs only ones it chooses. But if the CD is bought from a store it will play it.....if it is burned it usually will not.....even if the cd was just brned and plays on...
It might be an older system that can't read computer-made discs, or it could be a disc incapability. Most old players can't read CD-R discs, even if they can play normal/original CDs. You can try another media but i wont think it will help. Sorry.
Jan 04, 2006 | RCA RS2044 Shelf System
Sharp CD-MPX850 Shelf System Logo
977 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
