I have a HP LaserJet 3050. For years it has worked fine. this morning it is giving me a "no printer cartridge" error message. I have changed the printer cartridge and I still get the error message. One time since it showed the greed "Ready" light, but when I turned it off and back on, it returned to the "no printer cartridge" error message and will not print.
  • blhillier210 Apr 23, 2010
    Thank You. There was a sheet of paper that had slipped into the paper feed area when I had added more paper on top of the stack. That fixed the problem.
  • 666 Answers
This is a very common problem after a printers parts have been changed you have to let the printer know by going into the error count menu and resetting it to zero much like mechanics do with you check engine light
"Often this issue is caused by a sensor. â Therefore the first thing we should do is try to trigger the sensor.
1 Turn off the HP LaserJet 3050
2 Remove the toner cartridge from the HP LaserJet 3050
3 Remove all of the paper in the paper tray
4 Check the entire paper path for any obstructions
5 Reseat the toner cartridge and paper
6 Power on the HP LaserJet 3050
If the issue is still not resolved we will need to try some resets on the HP LaserJet 3050.
1. The first reset we can try is a soft reset, it is done by pressing the MENU key then holding *# together. â This will bring you into a Developers Menu. â Scroll through the options until you find reinit FFS and then press the ENTER key.
2. If this reset doesn't clear the issue we can try a harder reset. â We can do this by pressing MENU, scrolling over to SERVICE, pressing ENTER, scrolling over to RESTORE DEFAULTS and pressing ENTER to restore the defaults and ENTER to confirm.
WARNING: Restoring the defaults will clear your fax settings, phonebook numbers and headers so you may want to print a phonebook report and Config Report first. â We can do this by accessing the Reports menu.
3. If these two resets do not help there is a third reset we can try.This reset will completely put the HP LaserJet 3050 back to factory defaults.WARNING: Before doing this reset we will need to disconnect the power cord, the phone cable, and the USB cable from the back of the HP LaserJet 3050.We can do this reset by unplugging the power cord from the back of the HP LaserJet 3050 then holding down the MENU/ENTER key and * symbol at the same time,then powering the HP LaserJet 3050 back on with the keys compressed.We will release the keys as soon as PERMANENT STORAGE INIT appears on the display screen."
hope this helps
Robb
Posted on Apr 23, 2010
I bought an HP 3050 J610 printer less than a year ago, and need to replace the ink cartridges. Elsewhere on this site Upvarish advised someone else to use 61 cartridges, when the person asking for he
The HP 3050 Deskjet All-in-One takes the HP 61 cartridges: http://www.shopping.hp.com/product/CH376A%2523B1H . There are 2 cartridge boxes (black and tricolor: cyan, magenta and yellow). Both regular or extended use cartridges are available.
I hope this helps. If you actually have a Laserjet printer, please give the model of the printer to get the toner cartridge you need.
Feb 18, 2012 | HP LaserJet 3050 All-In-One Printer
Tricolor cartridge problem error message on HP 3050 J610
These types of severe cartridge errors (i.e. Incompatible cartridges, Black/Color cartridge(s) problem / Cartridge not intended for this printer, etc.) typically indicate the internal micro-electronics of the HP 61 cartridge are electrically damaged. The cartridges electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you run a Tap 41 diagnostic test to check cartridges electrical health (this is a forced service test so the printer will attempt to send whether cartridges are good or not); Refer to Inkjet411 youtube videos below:
HP 60, 60XL, 61, 61XL Ink Cartridge Refills - Solving Errors & Warnings:http://www.youtube.com/watch?v=BskAfa6NJSg
HP Deskjet 1000-3056 Printer Models -- HP 61 Ink Cartridges Tap 41 Diagnostics Testhttp://www.youtube.com/watch?v=tMZkqE36ifk
Jan 25, 2012 | HP LaserJet 3050 All-In-One Printer
No print cartridge message - with brand-new printer
Did this "brand new" printer ever work?
What kind of warranty did it come with?
HP gives their products a year warranty. Your "brand new" printer was probably manufactured in 2005, possibly 2006, so it isn't "brand new".
Does it have a cartridge in it?
May 14, 2011 | HP LaserJet 3050 All-In-One Printer
Missing Toner Cartridge
Try first removing all paper from paper trays and then reinserting cartridge, etc.
Sep 23, 2008 | HP LaserJet 3050 All-In-One Printer
HP Laserjet 3050 blank print
Have you tried a new toner cartridge? Usually blank pages are due to a missing bias voltage to, or in the cartridge.
Aug 11, 2008 | HP LaserJet 3050 All-In-One Printer
Replacing Print Cartridge
Turns out there was an easy solution. I filed a support case and had an answer in half a day:
I tried all the steps in sequence; it took #3 to fix it. Fortunately I didn't have a big fax address book or custom settings, so a factory defaults reset didn't cause any extra problems. It retained the time and date, and now it works fine.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
HP 3050
Try cleaning of the connectors inside of the printer. Also, try turning off the printer for a few minutes and restart it being sure all doors are fully closed.
Jan 16, 2008 | HP LaserJet 3050 All-In-One Printer
65 people viewed this question
jasbo
jasbo
