Question about Mag Innovision LT782S 17" Flat Panel LCD Monitor
LT982s - 2 monitors 2 problems
1 has green light no picture
2nd no lights - no picture
    Brigadier General:
  • 10,406 Answers
With the SECOND (usually the RIGHT) mouse-button, click anywhere on your computer's "wallpaper".
Click Properties.
Click Desktop.
Click Identify and watch both screens.
One should display a large '1' and the other a large '2'.
Click 'Extend my Windows Desktop onto this screen".
Again, click Identify.
Posted on Apr 23, 2010
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Screen stays on for 1/2 sec, power light stays green. when connected to the pc it will display for only a 1/2 sec, and the light stays solid green. when not connected to the pc it does the same but the...
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Aug 07, 2009 | Sony SDM-HS73 17" Flat Panel LCD Monitor
Monitor only power's on NO sound and No Picture
check your cable to speaker of your monitor and to the audio output of your pc.
May 20, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
Lcd monitor power light flashing with no img. seems 2 be frozen
The display is in safe mode and you will need to reset the display to get the display out of the safe mode. There are 2 different model revisions. Please choose the method that will match your revision. Depending on the revision of the monitor, one of the following 2 methods should reset it to a normal state. This reset generally requires both hands and it is sometimes easier with another person.
If the serial number begins with an A and/or your power button on the far right (5th button from left):
Method #1
1. Unplug the VGA cable.
2. Remove the power cable from the back of the monitor.
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 3 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
5. If the procedure worked, the green light will go to amber and you should see a "No Signal" message on the screen for a few seconds.
Method #2
4. Keep holding the buttons until the 4th green LED blink; then, let go. The green light should be steady when you release the buttons.
If the serial number begins with a B and/or your power button is in the middle (3rd button from left):
Method #1
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see attached picture) and while continuing to hold the buttons, plug the power cable back in.4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
Method #2
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
If you have tried the reset a few times and it does not solve your issue, please Ask a Question to submit a request through the system or call 1-866-752-6271 Option 1 to contact technical support.
Mar 02, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
Mag lt982s no green light no power at all
try testing it in another outlet a known good outlet if it powers on then your outlets bad if it doesnt means a bad cord or bad monitor
Feb 10, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
Black screen on monitor when plugged in., no picture at all
When you plug in the monitor no lights come on at all green, orange nothing ?
Try
1. Using a new power cord ( maybe something is wrong with it)
2. Plugging it into a new socket on the wall.
If you can't get power to the monitor at all you may be in for buying a new one.
Jan 04, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Monitor does not work!!
I had identical problem with my. I fix it by purchasing new chips from China (minimum 250pcs)
I have plenty on stock. If you like, I can fix it for you, or send you parts and you can fix it
Sep 02, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Monitor goes blank less than a second after turning on.
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
May 11, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Mag Innovision LT982s screen problem
Based on your post/description, I will initially suspect the inverter and/or the CCF Lamps since as you posted "dim screen picture" indicating that there is ** backlight(s) and/or it is **t receiving power from the inverter.
If the unit is relatively new and under warranty, it may be to your advantage to have it replaced or seek the services of their Service Center. Should you want to do a DIY, it would be required that you be familiar with electronic circuitry and components, use of a DVM and a soldering iron and access to a service manual or at least a schematic diagram.
Incidentally, there are k**wn cases where similar issues could be resolved if you try lowering your display properties (resolution and refresh rates) but that would also include the powerlight changing colors.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 09, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Mag Innovision LT782S 17" Flat Panel LCD Monitor Logo
80 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
