Question about iLO IWT3206 TV
Converting from tv to monitor
How do i convert my tv into computer monitor
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 164 Answers
As you have a SDTV. Which means you don't have any VGA input port. You will need to install a graphics card that has S-Video option, with that you'll require a S-Video cable. Thats it that your TV can be used as a Monitor.
Here's a Graphic Card with S-Video: converting from tv to monitor - a32d0cc.jpg
Hope this helps, Please feel free to ask me any further.
Posted on Apr 23, 2010
HOW DO I USE MY TV AS A MONITOR
If it is a CRT you need a scan converter. Some can cost you as little as $29.00 on ebay. Look for VGA to RCA. The low dollar devices are not great quality but do work.
If it is a tv with HDMI you can get a DVI to HDMI converter for $12 to $25 from best buy. If it is a computer with VGA out you can get a vga to hdmi out converter for $27 to $50.
If it is a tv with VGA in you can connect direct from the vga out on your computer directly to the tv. If your computer has DVI out you can get a converter for $12 or less to convert to VGA.
There are so many options that I can go on and on. You really didn't give me much information but I hope I helped you a little..
Nov 03, 2014 | Computers & Internet
Moniter convert to t v
your monitor not convert to tv, your computer must convert to receiver. you should install a TV card.
TV card is a hardware and can receive TV Signals like antenna
Feb 15, 2014 | Computers & Internet
How i use my samsung CRT TV as a computer monitor? my TV has A/V and RGB input connectors. and My PC has only VGA out put.
You'll need a VGA to Video composite / S-Video converter (commonly called PC to TV converter), this device will allow you to connect the VGA output to composite video input of your TV.
Feb 24, 2011 | Computers & Internet
How do I connect my laptop to tv to use as monitor
It depends on the laptop and the TV. If both have a VGA port, then use a VGA cable between them. Make sure the VGA port is enabled on the computer (possibly in the BIOS) and then set the monitor properties. You may need to reboot the computer to get the TV on.
If the TV has HDMI input and the laptop also has an HDMI port then you need to check the TV specs. Some HDMI ports can accept a signal from a computer (often labeled HDMI/DVI) and others don't. If the HDMI port is compatible with a computer source, then use an HDMI cable between the two. Again make sure the port is active. If TV's HDMI port is not compatible with the computer, you will need a converter.
If the TV doesn't have a VGA port (and the laptop doesn't have any video port other than VGA), then you will need a VGA to component video converter (or VGA to composite video) depending on the inputs of the TV. See http://www.svideo.com/pctocomponent.html for some converters.
Note: the converters are needed since computers output in a different format than the TV input understands. For analog, the computer is RGB and the component video is YPbPr.
A few media PCs might have a TV out port. This would eliminate the need for a converter. Check the specs for the cable you need.
I hope this helps.
Dec 10, 2010 | Televison & Video
Can this be used as a monitor for a computer?
Hello
Sorry. The answer is you can't. Computers output comes as VGA [Video Graphic Arrey],or AGP [Advanced Graphic Protocol]; and it is not directly compactable with TV inputs. The computer outputs, Red_Green_blue and Horizontal and Vertical synchronisation signals seperatly through one VGA cable which goes into the monitor and there they gets processed and you see the image on computer monitor. Monitors are equipped with such circuits to process the same, whereas in the TVs there are not. Your TV is equiped with S-video connection and not have a VGA input connection.
You must buy a VGA to RGB converter for this purpose. It can be bought from the electronic market, and will have instructions and remote control of its own to control it. You must give the computers signal [VGA], to the input of that converter,with a [VGA to VGA] cable and from which the converter outputs R_G_B [Red_Green_Blue] along with an other output contains synchronisation signal, as described earlier, and will have directions in its manual where should it to be connected. Different converters have different confugurations for this connection, and it will be described in its manual. Ok.
Oct 29, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
I just bought my 46'toshiba lcd tv and the sound is distored for some channels. Is this my cable converter or my TV or....?
I would think it is your cable converter. Try hooking the cable directly to the TV without the converter. Pick some channels in the lower range and see if they have the same distortion as the cable converter. Thanks. Let me know what you find.
Nov 11, 2009 | Computers & Internet
How to convert a computer monitor to video television
You need a converter box, there might be some input lag but it should be ok if you are just watching tv.
it's a RCA to VGA converter, it's a thing you buy.
Oct 11, 2008 | AcerView 54EL 15" CRT Monitor
Connecting to a computer
If you don't have a VGA input on your TV, you need to convert the signal using a device like this:
PC to TV Converter
Jun 05, 2008 | Polaroid FLM-2011 Television
Ilo 27inch hdmi hd tv monitor
You would need to connect a VGA + Audio to HDMI Converter. The downsize it the converter goes for about $150 us
Jul 31, 2007 | iLO V27DMBX Television
iLO IWT3206 TV Logo
85 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
