Question about Philips 42PF7220A 42 in. Plasma Television
How ro replace y upper buffer board on a phillips 42pf7220a
jdbouncer
  • 72 Answers
SOURCE: Y Upper Board
Yes these board have plug in connectors If its your Y-main Y-upper, and lower buffers are bad u can order them yourself and replace them its very easy to do.
Posted on May 06, 2008
inst
  • 12 Answers
SOURCE: Phillips 42PF7220A fix
I googled the part numbers and ended up on a website that allowed me to purchase the buffer cards for around $120.00 each. The Y sustain card was purchased of of e-bay for $80.00 including shipping. I think that I got lucky with the Y sustain card.
It took a lot of searching to find the cards.
Each card had multiple part numbers on them.
LJ41-02759A = LJ92-01200A = Y Sustain
LJ41-02760A = LJ92-01202A = Y Buffer Upper
LJ41-02761A = LJ92-01203A = Y Buffer Lower
I searched today for the same part numbers and they were priced much higher.
The site was a Vance Baldwin parts store which is where philips must be distributing their replacement parts.
Posted on Nov 20, 2008
SOURCE: Y - BUFFER BOARD - PCB: LJ41-02760A : Parts FOUND!!!!
You can also find it here: http://www.itritek.com/ysusbufferforsale.html It's a lot cheaper than partstore and they offer repair too.
Posted on Sep 22, 2009
abilenetech
  • 65 Answers
SOURCE: I have a 42 inch phillips plasma, went to turn on
my advice would be to find a supply store online who sells parts for tvs, if it were me i would google the model of my tv and put in buffer board and upper y board, you should be able to find suppliers, hope this helps
Posted on Nov 18, 2009
SOURCE: I have a phillips 42pf7220a/37 and 7 blink led
vcc problems did u get it fix i have the same problem so if u did email me and help me out thanks you so much
Posted on Nov 28, 2010
Red lines on plasma screen.
you may want to check out your buffers.
for cheap buffers check out hssparts.com
thank you
Dec 11, 2009 | Philips 42PF7220A 42 in. Plasma Television
I have a 42 inch phillips plasma, went to turn on would not turn on, repair guy said $510 to fix, buffer board / upper y board bad, where can I find and fix myself.
Nov 18, 2009 | Philips 42PF9630A 42 in. Plasma Television
The Ymain Board is out if you have the back of the tv exposed disconnect the ymain board and then plug in the tv set and turn it on. the light should remain green and no longer flash. If this happens the Y main and upper and lower buffer boards should be replaced
Jun 15, 2009 | Philips Televison & Video
Nov 13, 2008 | Televison & Video
Philips 42PF7220A/37 April 2006. Chassis Number BP2.3U
Most likely the YSCAN UPPER board and/or YSCAN LOWER Board also gone. Your new YSUS board may damage again if you don't replace the bad YSCAN boards. Try to replace the three boards together and then to verify which boards are bad one by one. Good luck.
Aug 03, 2008 | Philips 42PF7220A 42 in. Plasma Television
Top of picture of Phillips 42PF7320 has red-ish lines
have a tech replace the Y buffer boards upper and lower. there are different model numbers of the panel used in this set and corrispond to different buffers so have a philips tech replace them.
Jun 06, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Phillips 427220a
After you remove the back cover inspect the power supply board for swollen or bulging capacitors. Pull and check any capacitors that you suspect to be swollen. Next, look for a sticker in the upper right hand side of the TV set. Use the values you find on the sticker to calibrate the voltages on the power supply board.
Mar 08, 2008 | Philips 42PF7220A 42 in. Plasma Television
Help required for to repair plama tv
just resolder the high voltage section and the chroma.
Mar 07, 2008 | Televison & Video
Phillips TV- Plasma Model #42PF7220A/37
A tech will need to come out. When the tech do come out have him unplug the Y main and see if the led goes solid greem if it does have them replace the Ymain and the Y upper/lower boards. Most likely that will be the problem.
Feb 29, 2008 | Philips 42PF9630A 42 in. Plasma Television
We have samsung 50 inch plasma tv, we have only half a screen
I have a Phillips 50 inch Plasma. About two months out of warranty the top half of the screen would go black. Sometimes when we tapped on the back behind the upper right hand corner the picture would return. I did some research online and found that there is a Main Y sustain board (much like a mother board in a computer) and connected to that board is a upper Y Buffer board and a Lower Y buffer board. According to my research these boards seem to be the source of the problem. I am assuming that the upper buffer controls the top half of my screen and the lower controls the bottom. I removed the back of my TV (about 50 small screws) and searched for these parts by part number. Surprisingly all of the parts in my Phillips are made by Samsung. I found the parts on ebay at shopjimmy.com. I decided to try replacing the upper Y buffer first. I ordered it from shopjimmy for about 100.00. When I received the part I started to remove my upper Y buffer and realized that the new part was slightly different. The part number was the same but the REV. number was slightly different. The new part was missing a small white connector that connects the upper buffer to the lower buffer. I sent it back for an exchange for the right part with no problem. Ok so here is the interesting piece of this little adventure. When I started to remove my upper Y buffer I removed the screws and started to pull on it to loosen it. When I noticed that I had the wrong part I pushed it back into place and put the screws back . My TV has worked perfectly since I did that, with my original part. It has only been about two months, but if you are in the same situation it might be worth a try.
Nov 19, 2007 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Open Questions:
See all Philips 42PF7220A 42 in. Plasma Television Questions
Philips 42PF7220A 42 in. Plasma Television Logo
337 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
