Question about Duracell AA/AAA NiMH Battery Charger with 4 Rechargeable AA Batteries
The light won't come on to charge the batteries. Last year we put non rechargable batteries in and the batteries melted and the acid seeped into the unit. Can I fix the unit?
  • 1,606 Answers
If you had that much of a problem then you may be dealing with damaged parts from the overload and even damaged ciruitboards from the acid. Yes you could possibly fix it but you are talking about a few hours of playing around and you need the proper equipment ie meters, a scope, and a soldering station. Some of these are simple inside but the better ones can be quite complicated if they monitor things during the charge cycle.
These are not that expensive. Find a sale and replace it. Think of it this way if you paid yourself minimum wage for a couple of hours is that close to what a new one costs?
Posted on Apr 23, 2010
CVO 1800cc will not turn over
Hi, Paula I have been turning wrenches on motorcycles, mostly Harleys, for the past 50 years and in those years I have run across all kinds of battery issues. In the beginning, I too believed in the myth that keeping a battery on a trickle charger 24/7 was the best way to keep it fully charged and prolong battery life. In 1982 I was working for Harley Davidson of Washington D.C. when a customer came in for a tire change after basic chit-chat I discovered that he had been building lead-acid batteries for the Excide Battery Company for the past 17 years and the battery he had in his Bagger was 11 years old, I was shocked, to put it mildly. For the next 45 minutes while I was changing his rear tire I got re-educated on the proper maintenance and care for lead-acid batteries. The following is what I gleaned from our conversation:
1. Choose a quality battery that has the most "CCA" Cold Cranking Amps for your application.
2. Always charge the battery to 100% capacity before installing in your motorcycle. The battery may be new but may have been sitting on the shelf for months or longer and has lost 20% or 30% of its maximum capacity charge if installed under these conditions, the first time you hit the starter button the amperage draw from the starter motor will "SET" the lead-acid plates to whatever percentage of charge the battery had at that exact moment and will never charge any higher. This situation will have a negative impact battery life.
3. Service and inspect your battery as per the owners or service manual schedule and only add "Distilled" water if necessary.
4. Always check your charging system after battery service and make sure the charging voltage back to the battery is 13.8 - 14.8 volts DC. any numbers higher replace the voltage regulator any numbers lower check the alternator/generator for proper output
5. During winter storage or months of non-use, the optimum operating/storage temperature for the lead-acid battery is 25*C (77*F). Elevated temperature reduces longevity. As a guideline, every 8°C (15°F) rise in temperature cuts the battery life in half. A maintenance-free sealed battery, which would last for 10 years at 25°C (77°F), would only be good for 5 years if operated at 33°C (92°F).
6. A long period of a low amp trickle charger for 24 hours is highly preferred over a short period high amp charger.
7. For battery life longevity during a non-use period use a trickle charger of .5 to 1 amp for 24 hours once monthly then remove the charger. Batteries like to be slowly charged and slowly discharged on their own. 24/7 charging causes the battery to heat up and it's acid to evaporate.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Help Engine won turn over Harley Davidson Forums
http://proudfewmc.net/SiteAssets/99483-11.pdf free service man.
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/2010-harley-davidson-owners-manuals
Instant Tech Relief To speak to me personally $6 very cheap
Feb 07, 2018 | 2010 Harley Davidson FLSTSE CVO Softail...
Can u put rechargeable batteries into the Lanson smoke alarm
I am not familiar with the brand, but a quick search of the internet makes it look as though this is a 240VAC device. Since I'm not familiar, I thought I might offer some general advice re: rechargeable batteries. Most units will probably accept rechargeable batteries, but they will not provide a charging current to the battery, so you would probably find yourself changing the batteries more often, not less, because typical rechargeables are not charge to as high a voltage as non-rechargeables. I would suggest using lithium batteries because they are more likely to last the life of the unit (10 years by code in the US) when only being used as a backup; certainly you could expect 5 year battery life unless you go without power on a regular basis for extended periods...hope that answers your question. When in doubt, always check with the manufacturer.
Sep 23, 2015 | Home
How long do Kodak KLIC-7001 batteries usually last? I just bought a new charger (K7700) for my battery and when I put it in the green light flashes and then the red and then goes right off. Why is this...
the battery might be bad. One thing I learned with drills, is to never charge a battery directly after use (if it feels warm), and do not use when warm from the charger. I'm not sure on specialized batteries, but normal batteries like AA, AAA etc. only last about one year or so.
Mar 24, 2013 | Cameras
My battery for my mp3 won't last long
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 16, 2012 | Coby Audio Players & Recorders
Batteries run out fast
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 25, 2012 | Canon PowerShot A80 Digital Camera
HTC battery wont charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 04, 2011 | HTC Desire Cell Phone
I have a Craftsman mulcher model 315.370270. The green recharge light goes on but the battery charge level stays in the red. Do I need a new battery and if so where do I buy it?
I guess you've solved this by now, sounds like you need new batteries if the mower lacks power after trying to recharge. There are two sealed lead acid 12-volt batteries connected together on this mower to provide the 24 volts of power. These are the same batteries that are commonly used on rechargeable power wheelchairs and scooters. So you could find them at a Durable Medical Equipment company. The last two times I bought them, I got them from a DME company where I used to work. I also looked into buying them over the internet. Just make sure the replacement batteries are the same size and specs. You could burn out your on-board charger by continuing to charge batteries that are shot. I did this a few years ago with my 315.370270. Since then I have been charging the batteries with my portable Craftsman charger. The 12-volt batteries last about 3-5 years. I have had my mulcher since 1995 and have replaced the batteries about four times. This is the best mower I've ever owned. I'm going to retire it this year, if you're interested in it for spare parts.
Aug 27, 2011 | Craftsman Garden
Got a replacement battery not long after I bought this weedeater. The replacement battery would not hold a full charge [unless it is supposed to last only 10 minutes]...however, I lived with it. Well now,...
The replacement battery should have come with a WARRANTY, e.g., 30 days or 90 days or 1 year.
Exercise that warranty to get it inspected/repaired/replaced.
How old is the weed-eater? Has its warranty expired? It could be a problem with the battery-recharger.
Jun 06, 2011 | Computers & Internet
Unit charges shows full and by mid day in a nursing home battery lights show only 2 red lights. do i need to replace batteries. the chair is a jet3 it was bought in 2003 and not used for about 2...
You definitely need new batteries. There are 2 size U-1 batteries in the chair that will last between 1.5 and 2 years. Get the deep cycle sealed gel lead acid batteries, preferably AGM. Hope this helps.
Feb 15, 2011 | Jet 3 Ultra Power Chair
Help me!
The most likely problem is the batteries. You don't mention which ones you have - if they're rechargeable, charge for 10 - 15 hours even if the charger indicates a full charge. If those rechargeables are a couple of years old - replace them. If using non-rechargeable, be sure they're NOT "heavy duty" or "super heavy duty" - those are useless, for toys. Get fresh alkaline batteries.
Dec 12, 2008 | Kodak EasyShare CX7330 Digital Camera
Open Questions:
See all Duracell AA/AAA NiMH Battery Charger with 4 Questions
Duracell AA/AAA NiMH Battery Charger with 4 Rechargeable AA Batteries Logo
229 people viewed this question
Top Duracell Electronics - Others Experts
Craig Butler
Craig Butler
Joseph Mueller
Joseph Mueller
Are you a Duracell Electronics - Other Expert? Answer questions, earn points and help others
