Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
Leaking door- right side
I had standing water. I removed the kick plate and fixed the clog in the hose. I hooked everything back up and now the dishwasher is leaking on the bottom right side of the dishwasher. Can you advise?
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote about leaking dishwashers...
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Posted on Apr 27, 2010
Some water is leaking under the dishwasher and on the kitchen floor during the end of the wash cycle.
Does it leak during pump-out only?
If so , must be drain hose .To see everything,remove kick plate to isolate leak. Check hose connections. Fill and drain and observe.Or run a whole cycle with kick plate off to find leak.
Good luck
Aug 15, 2011 | Kenmore 24 in. 15689 Built-in Dishwasher
Condensation is forming on the glass door and dripping onto floor boards. How do we stop the condensation. It does say to empty drain tray but we cannot find it and instruction manual does not tell you...
The drain tray is under the fridge often times set back a little bit. Remove the kick plate by pulling from one side then the other side, strait forward till it pops off. The kick plate is a plate as close to the floor as you can get on the front side of the fridge going the entire width of the bottom of the fridge. Now get eye level with the underneath of the fridge. Center your view on the underneath of the fridge. The drain tray is right there. Pull it out, carefully as it is probably full of water, and dump the water out of it. Replace the drain tray and then replace the kick plate. Check the drain pan once a week or so and you should have no more water leaking on your floor. Hope this helps.
Mar 22, 2011 | Refrigerators
I have a side by side Kenmore refrigerator model #363-9562510. Water leaks from the bottom right corner of the freezer door from a small round cut out hole. This is the door that has the ice and water...
couple of things to check if you have a dispenser on this model there is a hose that goes up into the bottom of the freezer door you need to remove bottom kick plate and take a look at this...also if no water from that hose and its actually coming from the door you could have a ruptured line in the door itself.... next make sure the water is not actually coming from the freezer compartment as the drain in the freezer could be clooged and leaking over on defrost mode and out door...
hope this helps good luck...
Jan 05, 2011 | Kenmore Refrigerators
Samsung rs255sl refrigerator leaks water at water filter. Replaced water filter and it still leaks. Leak occurs even when not dispensing water.
The problem is at the water lines behind the kick plate. Remove the 3 screws on the kick plate. You should see too water lines a red and a blue coupling. Push the water lines in rather forcefully towards each other. When looking at the couplings on your left hand side you should see a small gray lip. You need to slide those outwards and insert the red clips (that should have been left in the plastic bag with the allen key used to adjust the door height) in between the lip and the coupling as they are compression fittings. This should fix your problem right up!
Oct 08, 2010 | Samsung RS265LBBP Side by Side...
Trunk water leak 1993 buick park avenue
Mother nature is too slow in finding leaks. Have someone small get in the trunk with a flashligh and watch as you run a hose over everything. LET THE PERSON OUT!
Jun 11, 2009 | 1993 Buick Park Avenue
GE dishwaher leaks with standing water in bottom
Check to make sure regular dish soap did not end up getting inside the dishwasher. This will create a lot of suds that will overflow onto the kitchen floor. Standing water from not draining can mean the drain hose is clogged somewhere or the check valve has something caught in it. If you remove the front kick plate, you will be able to check those.
http://tclaundryrepair.com/
Feb 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
Water is infrequently dispensing from our water line on our refrigerator
the ice maker and dispenser are on different water valves check your water filter first slowly push in your dispenser paddle and listen for a click then hum look at the bottom of the freezer door after removing the kick plate check to make sure the line there is free and not kinked if all that's ok replace the water valves
Feb 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Samsungrs21dcns water dispenser problem
just below the doors of the frig is a kick plate. remove the kick plate. on the left youll see a water line that goes into the freezer door. there is a connection for that hose just under the freezer. disconect the hose the press the water dispenser. if water comes out of the hose then the water line is frozen inside the door. you can use a hair dryer to warm up the dispener area both from the front and from the back, inside the freezer, it will take about 30 min to defrost. but, if you get no water from that hose then you need a new water valve. more than likely its frozen in the door. thats common on ge models
Nov 26, 2007 | Whirlpool GS6NBEXR Side by Side...
Dishwasher does not start.
remove kick plate from below the door. youll see a white tray behind the kick plate there is water in the tray activating a over flow switch. using a towel remove the water. this will solve the problem
Nov 16, 2007 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
95 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
