Question about Dell Inspiron 530 Desktop Computer
I can't heard no music why? - Dell Inspiron 530 Desktop Computer
    Brigadier General:
  • 10,406 Answers
1. You're not playing any sound/music.
Access any YouTube video to look for sound-samples.
2. You have told your computer to "mute" the sound.
3. Start your Audio Mixer, and move each slider away from the "zero" level.
4. Plug in some speakers to the "line-out" (not "line-in" and not "microphone-in") connector on your sound-card.
5. If the speakers are battery-powered, change the batteries. If they are AC powered, plug in the AC adapter.
6. Turn the speakers "on", and turn the speaker-volume "up".
7. Try your speakers and matching AC adapter on another computer.
P.S. Did you _ever_ get "sound"? When was the last time that it did work?
Posted on Apr 23, 2010
  • Dell Master
  • 5,913 Answers
Several possibilities come to mind: speakers have failed (self-powered speakers have bad power brick, cable damaged, etc), speakers plugged into the wrong port (audio in instead of audio out), audio card or driver has failed.
If you recently had to restore your OS (or do a roll-back to a "known" good configuration), check your audio device (make and model) and make sure you have the latest driver installed. (Look at the website for your computer if it is a prebuilt system or look up your motherboard if it is an on-board audio device.) The device manager might have a yellow exclamation mark on the audio device if this is the issue (access from the Windows Control Panel)
Check for bad speakers by trying another set of speakers or plugging them into another computer. (Swap cables if that is possible.)
I hope this helps.
SOURCE:
How do I reset shazam to work properly again without losing my music?
hi you should be able to back up and even re install shazam. I have re installed app & not lost my music. I have heard of friends that have lost music.
May 15, 2013 | Audio Players & Recorders
BlackBerry bold 9700,its speaker phone not working,ringtones and music not heard,but if i put it near ear from back of the phone then music is heard.Please solve as this is my new phone
Your phone is set on handset mode.While playing music,press the blackberry button and select the activate speakerphone option on the list.This would work for you.
Mar 26, 2011 | RIM BlackBerry Bold 9700 Smartphone
I was cleaning my phone and I pressed on something and now there is music playing that i can not stop,I don't know how to stop the music,my phone is panasonic KX-T7730
Here are two methods to turn off background music, one of these should work depending on which Panasonic phone system your phone is connected to.
1) With phone idle, press the 1 key on the dial pad (turns off background music when it is on and turns on background music when it is off).
2) With phone idle, press intercom button then dial *751 on the dial pad followed by 0 on the dial pad to turn off background music(confirmation tone will be heard) and end by lifting handset and replacing in cradle. To turn background music on, press intercom button then dial *751 on the dial pad followed by 1 or 2 on the dial pad to select the background music source(confirmation tone will be heard) and end by lifting handset and replacing in cradle.
Feb 05, 2011 | Panasonic KX-T7730 Corded Phone
People can hear background noises on my PC but not my voice
Perform some simple steps as follows.
1. Double click on the volume control icon in the system tray, that is on the right hand bottom side of the screen. Check if the microphone is muted.
2. Right click on the same icon, and select "adjust audio properties." You will now get a window that says Sounds and Audio Devices Properties. Click on the tab named voice on top of that window, and check what is selected as the voice recording device. Check in the drop down menu to change the device and use the "test hardware" option to test the mic.
3. Make sure your microphone is working fine. Other people are not hearing your music from your microphone, but from your system itself.
Get back if you have additional questions.
Jun 15, 2009 | Logitech 250 Headset
Getting different music
You need to find a site that is compatible with the mix max. Most sites will work. You just pick the songs you want and download them. I would try a sample first before I commit to buying anything, just to make sure the site is compatable. However, music in a WMA format should be fine.
I've heard that the itunes store doesn't work on other players. Then I heard they changed that. Walmart.com and Amazon both have songs. They are usually around 99 cents.
Apr 17, 2009 | Disney Mix Max Digital Media Player
Music player low volume
i have sgh-e840 phone but its music player has low volume and also when the phone is kept in pocket the ring of the phone cannot be heard
Mar 22, 2009 | Samsung SGH-E840 Smartphone
Music troubleshooting
music on hold products are licensed and interface with office systems, so you may first want to check your music on hold interface....here is a link which may help
http://www.tmilimited.co.uk/music_on_hold.htm
Jan 07, 2008 | Panasonic KX-T7730 Corded Phone
Music track is heard, but dialogue is not
It sounds like your CENTER channel is not connected properly.
Check the connection to the speaker itself, and at the connection to the back of the Sony.
Jan 06, 2008 | Sony HT-DDW900 System
My coby dvd 925
Coby dvd plays background music and all previews( music and voices ) but the actual movie we cannot hear voices only back voices and music can be heard.
Ray
raybuhr@yahoo.com 469-438-3979
Nov 19, 2007 | Coby DVD-925 System
Dell Inspiron 530 Desktop Computer   Logo
96 people viewed this question
Clive
Clive
Alun Cox
