Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Will not fill up with water. It starts to run the water for about 3secs. and then locks the door after that it will not run anymore water. You can hear the motor running as if it were pumping the water.
  • 15,935 Answers
It appears your dual inlet water valve has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
The washer door will not lock so the load can start washing. What can be done to make the washer door lock and start washing?
check door switch is functional,will prevent filling and future functions until confirmation of door is closed and locked.Door lock switch will prevent further functions like filling etc if the door catch does not close this circuit.Someone with electrical knowledge should be consulted in conjunction with wiring diagram of same
regards frank
Apr 29, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Just bought a front load whirlpool wash machine. when i turn it on it locks door then unlocks door, it does this 2 to 3 times then the washer fills with some water only spins about 3 times then it waits...
This washer will stop and start a number of times during fill as it is sensing how much water it needs. Also you must hook both water line up and have both on. Also you must use HE soap and very little of it.
Feb 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: Whirlpool Duet Washer - Error F21 (What is this) ...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. Door locked? Press "end of cycle" for 3 seconds, wait for 2 minutes & try the door. F-21 filter blocked.
How abt a nice rating for the free help? Thnks
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Water in drum when washer isn't running
Water fill valve ..Also.try outlet pipe not too low, water could be comming from sink back into machine...
Sep 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water filling up in Front loading Whirlpool washer
sounds like you have a faulty water valve that does not close when the power is not supplied to the machine.or a problem with the cotrol board supplying power to the valve when the unit is not in use
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fills on its own door open or closed
I would bet the water inlet valve is weeping. It may not seal shut every time. It could have a piece of rest stuck in it also. It's cheap and easy to replace. The part # AP3128776.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LIGHTS ON WON'T TURN ON DL CODE
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
see this fix
Jan 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet Washer starts and stops.
door interlock faulty Close Ireland bye bye
Nov 21, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
