Question about Garmin Quest GPS Receiver
Rong turns i have a garmin quest and have endless problems with its mapping it always sends me to the wrong addresses and wants me to turn off where there is no roads
Hello, I also own a Garmin Quest GPS and I live in Australia, Invariably my quest sends me in the wrong directions, and also in the middle of a highway get a message do a U TURN. I only believe this error resides in the MAPSOURCE Software. and until GARMIN decides to fix the problem there is NO solution for the USER to FIX. I also do NOT believe any more the specification that garnin states with the quest GPS, I believe it can ONLY be bad Telemetry downloaded from the satellites or you have TOO MANY waypoints stored in your GPS. The Solutions I am about to give you are my way of fixing the GPS until the problem reoccures. I suggest you do OPTION 2.
none of the work arounds depend on any parts to be removed.
1. NO RECEIVING SATELLITE TELEMETRY. I beleieve this could be due to a number of reasons, but more so at sometime corrupted telemetry was the problem to fix this,
a turn GPS on when booted (initialised)
b. depress menu
select settings
select Time Setup
when in Time Setup depress MENU
Select SET DATE
Depress OK button
Depress OK button again on the numberic keypad that appears on the screen (DONE)
what this seems to do is resets the internal date/time clock and the unit starts to work again.
the Second workaround is this but takes hours to perform.
OPTION 2 Before you do this DO YOU KNOW HOW to RELOAD your MAPSOURCE MAPS.
Simply turn the Guest on and allow the battery to fully discharge, this is also a good practice to cycle the battery. usually this works to TOTALLY flush the Memory again, but on my unit I have to setup all the maps again, this is easy to perform, but just takes time. I hope this helps you.
phil
Posted on Jun 07, 2008
Will not locate a known address provided by map quest yahoo or google
Have you sent the address from map quest to your Nuvi online ? If you did it should be in your Favorites
On the mapquest page where it says Send .....send to gps have your gps connected to your computer before gong to mapquest
Oct 31, 2010 | Garmin nuvi 200W GPS Receiver
Garmin nuvi® 255W Car GPS Receiver. Problem: Reboots during Map
The simple way is to send the unit to Garmin they will load the maps for free.
If you keep trying - try this -
With your thumb in the lower right corner of the screen - pushing in - like there is an X there - [ push with your thumb before you turn it on] Turn it on -
when this screen comes up - push YES -
then try your maps.
If they do not load on your pc [ which must have the unit hooked up and a legit copy of the newest maps ] then send the unit to Garmin. They will load your maps for you FREE. 86278d7.jpg
May 11, 2010 | Garmin nuvi 255W GPS Receiver
"Detail maps Don't Support Routing" in Garmin Quest
I too have a Garmin Quest and yesterday felt like throwing it against the wall because of the above problem. I found the solution eventually. When you download the maps from the Garmin Maps page, where you select the maps download, make sure that the checkbox to "Include route calculation data" is ticked before downloading your maps. Also make sure that the total memory required for the number of maps selected does not exceed the available memory on your Quest. If you try to fit more information into your Quest than it can receive then you are bound to have some problems. The Quests seems to have different memory specifications. According to the USA spec the memory is only 128mb, the Garmin site says 115mb and the box that my Quest came in says that it has 243mb.
Jul 10, 2009 | Garmin Quest GPS Receiver
Garmin Quest: Not able to upload detail maps
hi bud, just had the same problem. hard reset i.e turn off unit, hold down ok, page and then the power button at the same time. it should then ask you if you want to delete all data. select yes and then you should be able to upload your maps again, this worked for me good luck
Feb 18, 2009 | Garmin Quest GPS Receiver
Screen froze up
"If your Quest locks up....on rare occasions, your Quest may freeze or lock up. In this case, reset the Quest by pressing the unit's Power key and the IN key at the same time. This will turn off your Quest. The unit will operate normally when you turn it on again."
Aug 02, 2008 | Garmin Quest GPS Receiver
Garmin Quest
Hello, I currently own a Garmin quest myself, and some time ago I had some strange problems myself, I am a electronics technician, and I do have a work around for you. I will explain the problems and a cure for you to try, none of the work arounds depend on any parts to be removed.
a turn GPS on
b. depress menu
select settings
select Time Setup
Select SET DATE
Depress OK button
Simply turn the Guest on and allow the battery to fully discharge, usually this works to TOTALLY flush the Memory again, but on my unit I have to setup all the maps again, this is easy to perform, but just takes time. I hope this helps you.
phil email pjb3103@bigpond.com
May 24, 2008 | Garmin Quest GPS Receiver
Garmin Quest is out of whack
b. depress menu
select settings
select Time Setup
Select SET DATE
Depress OK button
phil
Apr 04, 2008 | Garmin Quest GPS Receiver
Garmin Quest
b. depress menu
select settings
select Time Setup
Select SET DATE
Depress OK button
phil
Mar 21, 2008 | Garmin Quest GPS Receiver
Garmin Quest unlocking maps
i BOUGHT A QUEST ON E-BAY, WHEN I TURN IT ON AT THE BOTTOM OF THE SCREEN, " CAN NOT UNLOCK MAPS" HOW CAN i UNLOCK THIS UNIT SO I CAN PROGRAM IN CITIES AND STATES.......
Feb 06, 2008 | Garmin Quest GPS Receiver
Garmin Quest
If you have forgotten your PIN number, and your security location, send the unit to Garmin and they will reset it for you. You will have to provide proof of purchase.
Oct 13, 2007 | Garmin Map Source City Navigator
Garmin Quest GPS Receiver Logo
77 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
