Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Fix top spring in whirlpool ultimate care quiet wash - removing washer top
  • 15,935 Answers
Http://www.youtube.com/watch?v=vogysB7XOc8
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Standard washing machine hoses dont seem to fit my Whirlpool Ultimate Care II washer? Do I need an adaptor of some sort....
The Whirlpool Ultimate Care II is an American top loading washing machine and requires different hoses available from Whirlpool.
May 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II top load skips agitation turns
I have the same problem, and i think it is a problem with the agitator i pulled mine off, (remove softener insert below that is a seal easily removed and then a 7/16'' bolt) seems a 'clutch' mechanism between base and upper agitators is shot.
Oct 15, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Where are the fuses to the water pump
Hi there......the water pump does not have a fuse...it is not controled by a fuse....it is controlled by the programmer....the whole machine is protected by a fuse in the plug top...water pumps or drain pumps usually suffer from a damaged impeller...or damaged coil windings...either of would require you to relace the pump
regards Sir Galahad
Aug 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator is weak
you need to remove the agitator, then pull the top half off, replace the dogs inside the cam, and re assemble it, you can find a kit online for a few dollars.
Feb 03, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer is leaking from underneath....
lean washer back against wall ck pump under front in center for leaks or dark gray area in pump face remove hoses remove clamp top and bottom of pump slide forward off shaft
Jul 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washer LSN3000PW4
tub is suspended from spring mounts
springs stretch over time tub sags
remove top cover
locate spring mounts and adjust tensioning bolts tighter on sagging side
Jul 11, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
169 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
