Question about Moyer Diebel 24 in. 301HT-40 Built-in Dishwasher
Moyer Biebel commercial dishwasher
When I turn my dishwasher on, water continuously pours out of the vaccum breaker. Do I need to replace this part, or could it be caused by something else. Thanks for the input.
Open the cap on the vaccum breaker. Check the float that is inside and insure that the seal on it is not worn or split anywhere. if it is, replace.
Posted on Aug 04, 2012
2 Suggested Answers
  • 86 Answers
SOURCE: Moyer Diebel Dishwasher arms are not spinning and doing lousy
Hello there
First to check is the water level is it just cover the round filter and no more, or is it much lower from the filter. It seem you have not enough water in the tank to do the washing that is why you have a lousy washing job, not enough water to spray upwards don;t talk about the top spray arm , the water doesn't reach there at all.
You can check it out by manually fill the machine with water up to the filter and start the machine up when the machine is running open the door and you can see the water spray up to the top be careful the water will spray out to your face too.
This is only to check to see the motor is running normally.
If the water level is good ( that is just touch the filter) and the problem still there, then the other cause the problem will be inside the pump motor the part call the impeller may need changing.
Do you have the manual book so I can show you which part we're talking about and let me know where your district so I can tell you where to get the parts from . My email address is dickson@lau.com God Bless Have a nice day, Dickson
Posted on Jul 02, 2009
Moyer dieble sw400 - is there. Way to lower pressure of water sprayers? The pressure is so high the floor keeps getting wet as the water is spraying through the curtains.
No there isn't, but if water is spraying through the curtains on a commercial dishwashing, ware washing machine. Check that there is nothing partially blocking the jets, and also replace the curtains if they are not in good repair.
You need the pressure to get everything clean.
May 08, 2016 | Dishwashers
Water comes out of the vacuum breaker when I use the dishwasher. I am not sure but seems to happen on rinse.
Possibly the seat in the vacuum breaker is not seating properly. Repair with a repair kit, which includes a plastic piston with a rubber seal. Could also leak if the water pressure is weak.
Jun 18, 2011 | Moyer Diebel 24 in. 301HT-40 Built-in...
The temp of the water is 200 degrees.How do I turn it down to 180
If the temperature was ok before, and no one has adjusted the thermostat, then that is an indication of a thermostat that needs to be replaced.
Dec 29, 2010 | Moyer Diebel 401HT Dishwasher
Heating Element not coming on
Check the heater wiring with a voltmeter. Should be around 208v to 240v. If ok then turn off power and remove one heater wire and check heater with ohmeter for continuity. Replace if no continuity.
Nov 08, 2010 | Moyer Diebel 48 in. SW400 Dishwasher
Water continually pours out of right side bottom
water continually pours out right side lower vent.dishwasher won't do anything else. no display lights on console.
May 05, 2010 | Viking DFUD042P Built-in Dishwasher
Moyer diebel 401 ht not reaching temperature ????
could be a number of problems. Checking with an ohm meter would determine the problem. Could be the booster high limit thermostat, a burnt wire, booster thermostat, or a heater element.
Oct 11, 2009 | Moyer Diebel 401HT Dishwasher
Champion dishwasher
if you turn the unit off from the circuit breaker will the water still run?if so the guts inside the solenoid valve are worn.you can call champion and get a kit to replace the worn parts and its not difficult to do.hope this helps.
Nov 07, 2007 | Dishwashers
Moyer Diebel 24 in. 301HT-40 Built-in Dishwasher Logo
159 people viewed this question
Top Moyer Diebel Dishwashers Experts
Are you a Moyer Diebel Dishwasher Expert? Answer questions, earn points and help others
