Question about GE Profile JTP18 Electric Single Oven
When we press Bake on GE Profile oven, get a ''Loc'' light, no heat
When we press Bake on our GE Profile Oven, it displays an orange ''Loc'' light and a green ''on'' light on the control panel, but it doesn't heat up.
  • Jim Hylton Apr 24, 2010
    We reset the breaker but that didn't solve the problem.
    A neighbor finally showed me how to fix this. It did not involve either of the two suggestions: resetting the breaker or replacing the latch. Instead, I just had to hold down the 9 and 0 numeric keys for 3 seconds, and the "Loc" message disappeared. I appreciate your trying to help, but if I had replaced the latch as you suggested, it would have been wasted effort and would not have solved my problem. I don't think I should be charged for this solution because it was incorrect. Thanks.
  • 10,515 Answers
Try to Reset the Oven by Turning the Oven's Circuit Breaker. If Problem Persists, you need to Replace the Latch Assembly.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 23, 2010
  • taran_2005
    taran_2005 Apr 24, 2010
    Thanks for your response!!
    Then more often it is Faulty Latch Assembly ( 80% ).Check and Replace it.
    Let me know,if problem still persists after replacing Latch Assembly.
    Hope i helped you.
    Thanks
  • taran_2005
    I am glad that you Got it Fixed. The Solution that i gave to you is Based on my experience on these Machines and more often it is Faulty Latch Assembly.
    Regarding Payment, you could write an email to :-
    premium.support@fixya.com
    Let me know, if needed further assistance.
    Hope i helped you.
Take GE Profile Oven LOC from pannel
the control board is bad,replace it there is no sequence to rectify this problem the board is bad
Jun 17, 2012 | GE Ovens
The loc on light comes on when i push any button on my stove i do not know how to get it off
The LOC light indicates the front panel lock is on. This keeps you from starting the oven when cleaning the panel; it also keeps children from turning on the oven. To disable the lock, press and hold Bake and Broil Hi/Lo together for 2+ seconds until SF appears on the display. Then press Self Clean. Then press Start to exit the Special Functions menu.
GE appliance manuals are available from their site. Go to http://www.geappliances.com/service_and_support/literature/ and enter the model number of the appliance. Then click Search.
I hope this helps.
Jun 26, 2011 | GE Profile JTP18 Electric Single Oven
The LOC on messsage appears on the screen when we go toturn the oven on. NEED the OVEN. What could we do to fi it?
The control lock has been activated. This feature is useful when you are cleaning the panel so that you don't accidently start the oven or the self-cleaning cycle. Try pressing Bake and Broil Hi/Lo together for 2 seconds (or a bit longer). SF should appear in the display. Then press Self Clean and Start. (When you press Self Clean the LOC message should disappear.)
Manuals for most GE appliances are available here: http://www.geappliances.com/service_and_support/literature/ . Enter the model number and click Submit. The direct link to the manual for the JTP18WWWW is: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=981140017.PDF .
I hope this helps.
Jun 02, 2011 | GE Profile JTP18 Electric Single Oven
On "bake" my GE profile
make sure the display is correct put a thermometor in oven to get correct reading
Mar 18, 2011 | GE Ovens
The oven is stuck at LOC.
The locking motor has gone bad on the range. Common for this to happen after self clean. You will have to replace or have the lock assembly replaced for the stove to work again
Mar 06, 2010 | GE JKP45 Electric Double Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
Err on display when I try to set the bake temperature
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
or try doing this
1. Turn the clock selector knob to OFF
2. “Tweak” the oven control by turning the clock selector knob slightly to the left (counter clockwise). This may stop the flashing message/beeping and clear the display window.
Nov 12, 2008 | GE Profile JTP18 Electric Single Oven
Ge profile oven loc
hey - I figured it out! hold down the 9 and 0 at the same time for 3 seconds! or it might be another combination depending on your oven - it is probably the 2 keys that the messge is under
Yay!
Island2
Apr 22, 2008 | GE Profile JTP18 Electric Single Oven
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
GE Profile JTP18 Electric Single Oven Logo
187 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
