Question about Gateway FPD2275W LCD Monitor
My monitor now looks yellow and won't go back to a white color? how can i Fix it.
  • 55 Answers
Isconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .also check you warrenty usually its for 3 years
also try to reset to factory settings by using the buttons on the monitor
Posted on Apr 23, 2010
4 Suggested Answers
SOURCE: monitor color changed
the cold cathode lamp iffy!
Posted on Jan 13, 2007
SOURCE: ViewSonic VE710b 17 inch yellowed photograph look
Hey I had a blue tint on my SVA VR-17S and the monitor VGA cord was what the problem was. But then after that i did auto-adjust and it look good for a second, then went yellow like your is doing. I went through the setting on my there is a Recall adjustment and it resets the factory settings and that fixed my problem.
Posted on Apr 22, 2008
  • 10406 Answers
SOURCE: why did my monitor's whites all turn yellow? Pages
WHITE is a mixture of the three "primary" colours.
When one of the primary colours is not being produced, then it cannot produce white.
Also, check that the "data" cable is securely-fastened to the monitor and to the video-card.
Posted on Feb 22, 2011
Rgb internal wires which ones can u use to convert it into red, white and yello at other end for tv
RGB is a term that means the guns in the crt or other display are only driven by amplifiers for that color. So you have to have seperate signals and inputs for red,green and blue. Those come from the source in that method. They are then fed into the monitor for which each of those colors has its own channel and amplifier. If you dont have something that is supplying the RGB singals then it is of no use. The colors that you listed as red white and yellow are for COMPOSITE video with AUDIO. The yellow is the whole video signal and the red and white are stereo sound signals. No attempts at making that work will correct this unless you buy a converter.
May 14, 2014 | Philips 107E66 17" CRT Monitor
How can i play ps2 on lcd without having a black and white screen ? how can i connect the cables ?.....when i look at the back of my lcd i find three ports (red white yellow) when i use them the screen is...
1) The set of input (Yellow= Composite video, Red= Right channel audio, White= Left channel audio). This set of input is for composite video.
2) The set of input (Red= Red video signal, Green= Green video signal + sync, Blue= Blue signal, Red= Right channel audio, White = Left channel audio (the Red and White will be grouped close together). This set of input is used for Component video for HD signal.
You should try using composite video source (Yellow RCA jack) from DVD player and feed to the monitor and see if it works OK with all color showing that way we acn find out if it is the video source problem or the monitor video signal processing problem. Try the PS2 on the TV if it works OK also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 20, 2011 | Samsung SyncMaster 940MG 19" LCD Monitor
Need to find out what color wires to use to fix my enforcer infared security camera the wires got cut. Color wire for splicing the wire on.
I have a small color security camera with infrared that is intact. This camera is an exclusive Harbor Freight Tools distributed product. I have attached pics of it, the last pic of the small connecting box looking into the connection starting from left to right are 4 wires 1=yellow 2=blue 3=orange 4=white. I hope this is of some help to you. I unfortunately don't have the other end of the connector and am looking for pinouts to hard wire it to my monitor. If some one has this info please pass it on to my email zimpmd at aol. Thank You Michael Zimpleman
Jun 05, 2011 | Cameras
Why did my monitor's whites all turn yellow? Pages on my monitor are yellowed where white is. All other colors are note effected.
Feb 21, 2011 | Samsung SyncMaster 245BW Monitor
Can't fix the color - really blue or really yellow.
Probably Blue CRT shot. Put tint back to center and turn color level to 0. Should look good black and white pic. If blue CRT shot, will look yellowish; usually more yellow around perimeter.
Apr 14, 2010 | Samsung HCM4215W 42" Rear Projection...
The screen color is off. It looks yellow, pink
Try changing the connecting cable. You seem to be connecting it with a composite cable which might have loose pins.
Sep 15, 2009 | KDS Radius RAD-7 17" Flat Panel LCD...
Monitor color changed
there may 2 problems
1 ) Problem with the Data Cable connector the Pins might be damaged try to arrange them if disturbed / bend . if Broken change the connector.
2) Open the monitor see the soldering carefully you can locate out the dry solders easily by seeing the flux colour around it . just put the solder over there..by soldering gun to all places where u can see the dry solder.
Sep 05, 2008 | Gateway FPD2275W LCD Monitor
Color problem
IT is 18 years OLD so has CCFL back lamps that all turn yellow.
is that it? if the OSD is yellow the (white looks yellow) that means the CCFL black lamp tubes are Shot.
i cant see what you see, no photos posted.
ok the monitor has and OSD, on screen display
i see you found that. but then fail to say what you saw there.
"you could see the background on the text as white. "
what does that mean,?
no matter what that is a bad Monitor.
the OSD works with no computer at all, so if the OSD fails
OSD brain, inside, then the monitor is bad.
all monitors worked previously so is not key to why its failing now.
only the tests now, matter. today/
my post above is for any monitor that fails the OSD tests
no PC turned off. or connected to any PC that works
the PC resolution must never exceed
1024 × 768 at 75 Hz Refresh Rate
on this old old dog. or the screen goes back with error
OUT OF RANGE.
Aug 27, 2017 | Compaq TFT5010 (Opal) 15.1" LCD Monitor
Monitor problem- colour changes to white appearance to yellow appearance
COLOUR MONITER BASE COLOUR IC SOLDING AND BASE SOLDING OR CHEAK DATA CABLE
Mar 18, 2007 | SAMTRON 55V 15" CRT Monitor
Gateway FPD2275W LCD Monitor Logo
164 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
