Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
How to remove ignition switch from steering column in a 95 chevy truck?
tripletauto
  • 1450 Answers
SOURCE: installing ignition switch for 87 chevy s10 Blazer 2.8L 4X4
you need to replace the electrical part of switch?If os it is down on column under dash will be two bolts holding on with the dimmer switch also
Posted on Aug 28, 2008
  • 337 Answers
SOURCE: changing key ignition need to remove old one and fix ignition rod
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528008f60e
Posted on Dec 01, 2008
csmock132
  • 4669 Answers
SOURCE: nned steerin column diagram
I don't have a diagram, But I have taken tons of these apart. Is there something I can help with?
Posted on May 04, 2009
  • 33 Answers
SOURCE: acc positions on ignition switch will not work on 95 Chevy Astro
ignition switch not lock cylinder may need to be addjusted it's on top side of steering column under dash
Posted on Jul 10, 2009
emissionwiz
  • 80407 Answers
SOURCE: how to replace an ignition switch on a 1989 chevy
go to link the year is diff but the procedure is the same. scroll to bottom of page
http://www.2carpros.com/forum/1994-chevy-s-10--ignition-lock-cylinder-vt197051.html
Posted on Sep 09, 2009
Need diagram steering column 1984 chevy
Two screws located on steering wheel back to remove horn assembly to expose steering wheel locknut to remove and then use steering wheel puller to remove the st wheel and expose switch.
Jan 07, 2014 | Nissan Cars & Trucks
How do you remove an ignition switch on a 2003 Chevy G3500?
the ignition switch located right side of the steering column. you need to remove steering column covers and drivers knee bolster
Oct 17, 2013 | Chevrolet Chevy Cars & Trucks
1989 chevy truck remove and replace steering column
you need first disconnect negative battery cable. you need steering wheel puller you have to remove steering.look under hood disconnect flange end of the steering shaft at the flexible coupling separate the coupling from the lower end of the steering column. you have to go inside vechicle remove lower steering column cover yoo have to remove steering column dash to panel screws then you have to remove shift linkages and remove disconnect electrical wiring connector to turn signal and ignition switch.your model truck shouldnt have the floor board mounting screw hold column to the floor.
Jun 18, 2013 | Cars & Trucks
How do you replace the ignition key switch for a '96 chevy diesel 1 ton 4wd pickup truck?
Ignition Switch Removal & Installation To Remove:
  1. Remove the steering column trim covers.
  2. Remove the wire harness from the retainers as needed.
  3. Slide the 2 connectors of the multifunction switch assembly out from the bulk head connector.
  4. Detach the key alarm connector from the lock assembly.
  5. Remove the ignition switch mounting screws and the ignition switch from the steering column.
Ignition switch removal/installation gm-08-00-1141.gif
To Install:
  1. Install the ignition switch on the lock module.
    • Tighten the screws to 42 lb in (4.7 Nm).
  2. Install the key alarm connector on the lock module.
  3. Slide the turn signal and multifunction switch connectors into the bulkhead connector.
  4. Install the harness in the original retainers.
  5. Install the steering column trim covers.
Ignition Lock Cylinder Removal & Installation To Remove:
  1. Disconnect the negative cable from the battery.
  2. Disable the supplemental inflatable restraint (SIR) system.
  3. Remove the steering column trim covers.
  4. Turn the ignition lock cylinder to the run position.
  5. Using an awl with a bent tip, insert the tip into the access hole of the ignition lock cylinder.
  6. Turn the lock cylinder to start and push down and hold the lock cylinder retaining pin.
  7. Release the lock cylinder to the run position and withdraw the cylinder from the steering column.
To Install:
  1. Align the slot in the steering column to the tab on the lock cylinder and install the lock cylinder until it locks in place.
  2. Install the steering column trim covers
  3. Connect the negative cable to the battery
  4. Check for correct operation
Oct 08, 2010 | Chevrolet 3500 Cars & Trucks
Where is the ignition switch on a 95 camaro
At the bottom of steering column on key side is the electrical ignition switch.
Aug 10, 2010 | 1995 Chevrolet Camaro
1992 Chevy Blazer Ignition Diagram
trying to remove the ignition from my steering column having problem getting the turn signal switch from the column
Oct 25, 2009 | 1992 Chevrolet S-10 Blazer
Acc positions on ignition switch will not work on 95 Chevy Astro
Jul 10, 2009 | 1995 Chevrolet Astro
Ignition switch cylinder replacement
take off the steering wheel, remove the plastic piece on the steering column and then the ignition should unbolt and slide off.
Jun 02, 2009 | 1995 Volkswagen Golf
Remove ignition tumbler
lock cylinder removal
Section 11-04: Steering Column 1996 Escort, Tracer Workshop Manual
REMOVAL AND INSTALLATION Ignition Switch Lock Cylinder Removal
  1. stf~us~en~file=ani_caut.gif~gen~ref.gif WARNING: THE ELECTRICAL CIRCUIT NECESSARY FOR DRIVER SIDE AIR BAG MODULE DEPLOYMENT IS POWERED DIRECTLY FROM THE BATTERY. TO AVOID ACCIDENTAL DEPLOYMENT AND POSSIBLE PERSONAL INJURY, THE BATTERY GROUND CABLE MUST BE DISCONNECTED PRIOR TO SERVICING OR REPLACING ANY DRIVER SIDE AIR BAG MODULE SYSTEM COMPONENTS.
    Remove the steering wheel (3600). Refer to the procedure in this section.
  1. Remove the multi-function switch (13K359). Refer to Section 11-05 for the removal procedure.
  1. Disconnect the ignition switch electrical connector.
  1. Remove the ignition/shifter interlock cable mounting bracket bolt and position the ignition/shifter interlock cable mounting bracket and the ignition/shifter interlock cable (3F719) aside.
  1. Remove the four steering column upper mounting bracket bolts and lower the steering column (3C529).
  1. Use a hammer and chisel to make a groove in the head of each of the two ignition switch lock cylinder bracket bolts.
  1. Remove the two ignition switch lock cylinder bracket bolts with a screwdriver and discard the bolts.
  1. Remove the ignition switch lock cylinder and the ignition switch lock cylinder bracket.
Installation
  1. Position the ignition switch lock cylinder and bracket and install two new bolts, tightening them only enough to hold the ignition switch lock cylinder in position.
  1. With the key in the ignition, verify the operation of the ignition switch lock cylinder. If necessary, reposition the ignition switch lock cylinder until it operates properly.
  1. Tighten the ignition switch lock cylinder bracket bolts until the bolt heads break off.
  1. Position the steering column and install the four steering column upper mounting bracket bolts. Tighten the steering column upper mounting bracket bolts to 9-14 Nm (80-124 lb-in).
  1. On vehicles equipped with tilt column, remove the upper mounting bracket retaining pin.
  1. Position the ignition/shifter interlock cable mounting bracket and install the bolt. Tighten the ignition/shifter interlock cable mounting bracket bolt to 4-6 Nm (35-53 lb-in).
  1. Connect the ignition switch electrical connector.
  1. Install the multi-function switch. Refer to Section 11-05 for the installation procedure.
  1. Install the steering wheel. Refer to the procedure in this section.
  1. Inspect the shift interlock system. Refer to Section 07-05 for the procedure.
Apr 07, 2009 | 1995 Mercury Tracer
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
1,036 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
